Old 04-29-2013, 12:20 AM   #4321
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
just got home from a 1500km ride , more later
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 04-29-2013, 01:02 AM   #4322
Dash65
wherethefarkarewe?
Dash65's Avatar
Oddometer: 302
Laugh
XT660Z Tenere - 2010
Honda XR250 - 1985
Growing old is inevitable, Growing up is optional
Dash65 is offline   Reply With Quote
Old 04-29-2013, 03:57 AM   #4323
Scotty4x4
Oddometer: 132
With the standard suspension has anyone played around with the settings? I weigh 95kg about 100kg with my bike gear and camelbak. And I found the suspension to soft and saggy lately.
Anyone brought it up and can recommend a good setting?
Thanks.
Scotty4x4 is offline   Reply With Quote
Old 04-29-2013, 04:48 AM   #4324
Tomack
Tomack's Avatar
Oddometer: 160
Thanks.
Im roughly the same weight as you & all Iv done is wind up the pre load (10mm) on the front & rear. Its made a small differance but I'll have to see a suspension guru when the funds allow.
My next priority is to fix is the cush drive problem
Tomack is offline   Reply With Quote
Old 04-29-2013, 04:51 AM   #4325
Dash65
wherethefarkarewe?
Dash65's Avatar
Oddometer: 302
Suspension Upgrade
Well I'm slightly heavier than you and I had my suspension redone by Suspension Smith here in Canberra, made a HUGE difference in how the bike feels, if you can spare the cash get a suspension upgrade done. It is worth it.
Thanks.
Honda XR250 - 1985
Dash65 screwed with this post 04-29-2013 at 04:54 AM Reason: Spelling
Old 04-29-2013, 04:53 AM   #4326
Dash65
wherethefarkarewe?
Dash65's Avatar
Oddometer: 302
cush drive
If you get a "fix" for this please let me know, sick of buying replacements.
Honda XR250 - 1985
Old 04-29-2013, 04:59 AM   #4327
Tomack
Tomack's Avatar
Oddometer: 160
This link was a few pages back
http://www.youtube.com/watch?v=M2rse...75T5J&index=27
Iv got a mate with a lathe
Its annoying that its not done in the Yamaha factory
Tomack screwed with this post 04-29-2013 at 05:14 AM
Old 04-29-2013, 05:08 AM   #4328
FLICKIT
FLICKIT's Avatar
Oddometer: 876
Noticed this on their site the other day:
Machine Tenere Cush drive hub - $200
http://www.teknikracing.com/Machine-...drive-hub.html
FLICKIT is offline   Reply With Quote
Old 04-29-2013, 06:13 AM   #4329
TB650
Would be Adventurer
TB650's Avatar
Oddometer: 784
I posted that, you will need a large 4 jaw chuck because of the four lugs on the rear of the drive. 200 large including parts is ok when you consider the price of rubbers and the damage to the bearing surface in the Cush hub if ridden with worn rubbers . Once the rubbers wear the bearing get twist loaded and the next bearing falls in and out of the hub ( I have done over 56k on these now, on my second) its an easy fix. Why didn't Yamaha do it, if they did everything we think up we couldn't afford one. The collar needs modifying as well remember. I had my new one done there last week and he built an Ohlins shock for mine. The shocks old and new were run on the shock dyno. When I get back from the Simpson and SA I will post it up very very interesting
TB
XTZ660, WR250R Prerun bike awesome!, ex GHR XR650, A second XR650R and the mighty CT110
www.rideadv.com.au
TB650 is offline   Reply With Quote
Old 04-29-2013, 01:44 PM   #4330
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
Thanks.
In short, NO , Im about 100kg, the standard spring rates & damping are crap, only fix is to get it modded.
I'll give a full report on my new suspension when Im home from work tonight
Old 04-29-2013, 11:32 PM   #4331
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
well my new Teknik suspension is great and has transformed the Ten, she is much more balanced and the forks dont blow through the travel any more at the slightest touch of the front brake .
The forks are very nice, probably as good as skinny damper rod forks can be, not as good as some nice adjustable USD's but very nice.
The Yacugar shock is pretty good, much nicer than an unmodded stock shock, still got some tuning to do, its got a bit of a kick on sharp bumps I havent been able to tune out yet. I may take it back at some stage for a revalve to get it exactly how I like it, Im a fussy bastard , I had my ohlins on the AT revalved 3 times to get it how I like it.
She is much more stable though still a bit more flighty than Im used to with the AT's long wheelbase and steering damper, its fine for a while now but a damper is definately in my future.
I fitted some 15mm lower pegs from SW motech as well, they are fantastic and make the bike much more comfy for me, I'd still like some more height in the seat though.
re the pegs - 1 prob is I cant now get the gear & brake levers low enough, I'd like 1 more spline lower on the gear lever but the sidestand mount gets in the way, its livable though. The brake lever is a pain, its all the way down on the adjustment and still too high , on the AT it had a spline but the yam is just on a bush so it may come to cutting , bending & welding the lever to get it how I like it, we'll see.
Just got a high screen from Peter at Screens for bikes, will fit that before my next ride
Old 04-29-2013, 11:35 PM   #4332
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
a few more pics from my ride;
Old 04-30-2013, 06:12 AM   #4333
Scotty4x4
Oddometer: 132
Thanks for your help everyone. Definitely gonna look into upgrading the suspension then. And fix the Cush drive with the inner tub. 8000km and its rooted!
Old 04-30-2013, 01:51 PM   #4334
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
couple of questions,
I seem to have lost the rear bolts from the B&B bashie mount, it was fitted before I picked it up, is it 2 bolts or 1 long one ??
ALSO
EVERY time I get off the bike the bloody rear blinkers have popped out, anyone else get this or have a cure ???
Old 04-30-2013, 04:54 PM   #4335
FLICKIT
FLICKIT's Avatar
Oddometer: 876
2 x 8mm hex/allen head, about an inch long, with spring washers... The mount is threaded, no nutz needed...
The original rears aren't on my bike, the previous owner put a tail-tidy on due to vibration issues, the number plate kept cracking up apparently....
I have an issue with the fronts popping out though, when I'm pushing though overgrown scrubby tracks.... I'm going to put a good dob of silicon sealant on the inside to help keep them in there....
FLICKIT screwed with this post 04-30-2013 at 10:15 PM
Times are GMT -7.   It's 10:02 AM.
