Old 04-28-2013, 09:58 PM   #31
Y E T I OP
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
Originally Posted by Mike Ryder View Post
Yup way to persevere.
Can I ask what sort of bolt do you plan to put back in there? I will likely bust mine when I try to remove it as it is very reluctant to turn. More heat I suppose.
My plan is to replace it with a stock bolt. I'm thinking Blue Locktite with a paint mark to make sure it isn't backing out.
The other option is a harder bolt. However, as I learned with my 800GS, that creates a whole new set of issues.
Definitely use heat when extracting your bolt. Mine was already broken, so it wouldn't have made a difference. But if yours is not already broken, definitely ease the process with heat.
Scott - Semper Fi
'04 BMW R1150GSA, '05.5 KTM 950 Adventure
Y E T I is offline   Reply With Quote
Old 04-29-2013, 07:04 AM   #32
biometrics
biometrics's Avatar
Oddometer: 141
Congrats on getting it out!
Glad you were successful.
Make sure you clean the threads in the hole, and don't use a bunch of locktite on the new bolt... just some. then mark the bolt so you can tell if it ever turns from the torqued position.
biometrics is offline   Reply With Quote
Old 04-29-2013, 07:14 AM   #33
GrouchyGeezer
GrouchyGeezer's Avatar
Oddometer: 971
GrouchyGeezer is online now   Reply With Quote
Old 04-29-2013, 02:56 PM   #34
Handler
Rider
Handler's Avatar
Oddometer: 5
Glad it worked out for you. Been awhile but as I recall, the replacement bolt from BMW has a lock patch applied to the new bolt.
Cheers,
-RIck
"We can always make more money but we can never make more time."
Handler is offline   Reply With Quote
Old 04-30-2013, 04:17 AM   #35
BigShow
Scallywag/Adventurer
BigShow's Avatar
Oddometer: 264
Sheared my nuts off...
Last summer we had one of the captains on a fire truck call in and said, "I have just sheared my nuts off"... To which the dispatcher taking the call responded in quite the deadpan voice, "Well, will you be needing a tow truck or an ambulance?"
ba da bump!
heehaw, heehaw...
Great job fixing your nuts and thanks for sharing the story and the pics.
George
aka Big Show
I see dumb people
BigShow is offline   Reply With Quote
Old 04-30-2013, 06:25 AM   #36
Y E T I OP
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
ba da bump!
heehaw, heehaw...
Scott - Semper Fi
Old 04-30-2013, 01:30 PM   #37
88NX250
Team USA
88NX250's Avatar
Oddometer: 725
Good job fixing the bolt! I had the same issue a couple years ago on my R1200GS and it was a mess.
To stop the problem from happening again, give special attention to steps 8 and 9 in this blog post. There is a floating spacer in the GS swing-arm that becomes seized in place. When the spacer doesn't tighten properly against the shock bushings, the bolt bends or breaks.
http://www.touratech-usa.com/Adventu...k-Installation
88NX250 is offline   Reply With Quote
Old 04-30-2013, 02:19 PM   #38
Y E T I OP
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
Interesting. Although the blog post you've linked referes to the 1200GS, it does look like my 1150GSA also has a bushing there. I looked to see if it could be removed easily and it didn't seem to want to come out.
Anyone know if that is a removable (and greasable) bushing on the 1150 like it is on the 1200??
Scott - Semper Fi
Old 04-30-2013, 02:25 PM   #39
mike54
You don't get me
mike54's Avatar
Oddometer: 13,370
I've got to wait 'til I get home to check but I've had that bolt in and out many times and don't remember the bushing being removable.
However a quick look at max's parts fische shows the bushing as a separate part on the 1150.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 04-30-2013, 02:34 PM   #40
Y E T I OP
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
So it does. Who knew? Anyone know how to remove it? Should it come out easily?
Scott - Semper Fi
Old 04-30-2013, 04:57 PM   #41
88NX250
Team USA
88NX250's Avatar
Oddometer: 725
On my bike it was seized petty hard. I had to use a socket that fit in there nicely and a hammer to pound it through. With the shock out, the spacer is short enough to come out of the swing-arm in the space where the shock absorber sits.
Mine took a good bit of sand paper on the spacer itself and the bore it sits in to get it moving smoothly. My friend's 1200 spacer slid in and out smoothly.
Old 04-30-2013, 05:45 PM   #42
mike54
You don't get me
mike54's Avatar
Oddometer: 13,370
Rather than pounding on it why not use a bolt a washer and deep socket or piece of pipe and pull it out? I hate hammering on stuff.
Old 05-01-2013, 04:32 AM   #43
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,498
Hammering is more fun!
Jim
JimVonBaden is online now   Reply With Quote
Times are GMT -7.   It's 01:57 PM.
