Old 04-28-2013, 01:50 PM   #1
jameslawson OP
Oddometer: 76
Thinking about Bar Risers for my 990R
Hi All
After riding my new 990 Adventure R for a week now i'm definitely in need of some bar risers.
I'm 6'4'' tall and not at all comfortable standing. I've moved the stock bars as forward as i'm comfortable with which obviously raises the stock bars a little, however they are still far too low.
I think i'd be more comfortable with +2"
Questions: Which are the best to go for? I've seen the Rox Risers and they look good. but I know nothing about them (quality etc).
What do others use?
Can i still get away with stock Brake lines and cables if i go +2"?
Thanks for your help
James
jameslawson is offline   Reply With Quote
Old 04-28-2013, 02:11 PM   #2
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,776
I used the cheapest ones I could find- 19.95US on ebay. Then I went to Renthal 608 (I think) bars.
Difference in standing is amazing- much more confortable with that combination, and needed no cables/brake line changes.
Do it.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 04-28-2013, 03:02 PM   #3
Orangecicle
Orangecicle's Avatar
Oddometer: 2,458
Just FYI. I went with the KTM risers on my old 950. The throttle cables were too tight running through the left side of the frame head. However, it's very easy to reroute them through the right side of the frame head, which gives you plenty of cable. It doesn't help the brake lines, but it fixes the throttle problem.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 04-28-2013, 06:23 PM   #4
Sumi
Sumi's Avatar
Oddometer: 1,780
I have 2" Rally Connex risers on my bike.. throttle cable is turned upside down - it fits fine this way:) but you can also reroute the cable to the right of the frame as said.. I don't know about the 990R, but the brake line is Ok on the 950.n
Sumi screwed with this post 04-29-2013 at 03:15 AM
Old 04-29-2013, 01:38 AM   #5
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
Originally Posted by Sumi View Post
I have 2" Rally Connex risers or my bike.. throttle cable is turned upside down - it fits fine this way:) but you can also reroute the cable to the right of the frame as said.. I don't know about the 990R, but the brake line is Ok on the 950..
2" will work just fine if you turn the throttle cable upside down. Either the RAlly Connex or Rox will work.
Tried it also with the throttle cable on the right of the steering stem; but had the idea that it is twisted too much that way, turning it over feels better...
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 04-29-2013, 03:19 AM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,880
I have these installed
http://www.advrider.com/forums/showt...144803&page=16
Cheers
Old 04-29-2013, 03:40 AM   #7
Sumi
Sumi's Avatar
Oddometer: 1,780
Originally Posted by gefr View Post
That's the Rally Connex riser, isn't it?
Old 04-29-2013, 12:46 PM   #8
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 555
Originally Posted by jameslawson View Post
Hi All
James
I had the Rox and I liked the wide range of motion they gave. You can rotate them forward or back to fit your needs. Quality and finish are very high. They are well made and have some advantages over the standard risers.
However, they never stayed in place. I mounted them with a forward angle, but after riding off-road, they would always end up rotating back to a direct line stock mount. No matter how much I tightened the clamp screws, they would always end up rotating back.
Eventually, I replaced them with 1.25" risers from BlackDog.
Hope this helps.
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is offline   Reply With Quote
Old 04-29-2013, 02:03 PM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,880
Yes, that's right.
Seems the production has stopped.
Cheers
gefr screwed with this post 04-29-2013 at 11:29 PM
Old 04-29-2013, 11:17 PM   #10
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
50,000 miles with the ROX risers and no issues.
The wide range of adjustment is great to have
especially if you end up changing out your bars for a different
bend. As others stated flip the throttle housing upside down and you are good to go.
Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Times are GMT -7.   It's 10:01 PM.
