Old 04-29-2013, 07:44 AM   #3721
Achtung
Wicked Pisssah Adventurer
Achtung's Avatar
Oddometer: 976
Originally Posted by Aquatic View Post
What is the cost of the HoH axle kit?
Including the caliper bracket?
I'm not sure what the final cost will be, the one I bought was the last in some old stock that they had, I'd hate to quote a price and be wrong.
Originally Posted by WayneC1 View Post
Have emailed HOH to ask for some details and when the kit will be available so I can update the info and links I have online. Will post the response here
When I talked to them they said they had parts being machined so hopefully they'll have everything soon. Rick and the rest of the people over there were really great to deal with. A+
Achtung is offline   Reply With Quote
Old 04-30-2013, 08:31 AM   #3722
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
From Richard at HOH "
On the RAD/Hawk adapter parts: "Do you think you can get 5 commitments right away??? we are very close but I need to order a large quantity to get these at lower price" Kits will be anywhere from 550 to 700 plus forks.
On the forks: "My fork mods are 425.00 incl rebuild and revalve and prog fork springs."
Seems the $550 is group buy worthy so those on the fence or midway may want to start a buy group.
nomad5326 screwed with this post 05-01-2013 at 04:58 AM
nomad5326 is offline   Reply With Quote
Old 04-30-2013, 03:03 PM   #3723
Aquatic
Aquatic's Avatar
Oddometer: 1,640
Do you think you can get 5 commitments right away??? we are very close but I need to order a large quantity to get these at lower price".
"Kits will be anywhere from 550 to 700 plus forks. My fork mods are 425.00 incl rebuild and revalve and prog fork springs."
What does $550 buy you?
Axle, washer and nut
Calliper relocation bracket
Aquatic is offline   Reply With Quote
Old 04-30-2013, 03:33 PM   #3724
LoJack
LoJack's Avatar
Oddometer: 1,606
Yeah, even for small runs it seems a little spendy.
LoJack is offline   Reply With Quote
Old 04-30-2013, 09:07 PM   #3725
WayneC1
Oddometer: 2,585
Email I received from Richard
"Still waiting on final for kit -- have 3 people working on it -- the revalve mod , prog spring rebuild , lower etc on my end runs 425.00 complete"
Seems the numbers will need some clarification
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 05-01-2013, 04:56 AM   #3726
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
I think the $500ish mark is comparable to what Hawk had going w/Rads mod. Maybe price will drop if the Dakar/Sertao crowd get more interested.
The $425ish for the fork rebuild is same quote I got.
That and the adapter parts and your stil under a grand using your own GS front end. Adding up the YAM front swap to include wheel, brakes, etc can run close depending on the deals you get.
Old 05-04-2013, 10:31 PM   #3727
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,851
tire
i know a lot of you guys are running an 18" rear rim.
do any of you run this tire AND size :
Heidenau K60 150/70 18
if so , any issues with clearance or chain adjustment ?
thanks
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 05-06-2013, 06:42 AM   #3728
mothra
Rally Driver
mothra's Avatar
Oddometer: 820
I think the caliper relocation bracket they are fabbing is pretty elaborate (lot's metal and machining). Does anyone have a picture of this part they can post.
Matt Smith
'02 F650GS Dakar
'09 HUSBERG FE450
mothra is offline   Reply With Quote
Old 05-06-2013, 07:47 AM   #3729
Aquatic
Aquatic's Avatar
Oddometer: 1,640
Old 05-06-2013, 09:04 AM   #3730
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Did anyone else need to get bar risers for the hand guards to clear the cockpit and give enough room for steering side to side?
I ordered the Pastrana FMX high bars and hoped it would give enough rise and sweep but I think it put the HDB guards really tight to the cockpit. I had to adjust the steering stops way too much and have no turning radius.
Looking to get some risers and get some more clearance. Since I have the HDB top clamp I might use the old top clamps from the Aplied Racing triple as a poor mans riser and see how that works.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 05-06-2013, 09:33 AM   #3731
WayneC1
Oddometer: 2,585
My bars are a relatively straight bar, very little rake and they are mounted with risers but in total height are 1/2" lower than stock. I sculpted a little out of the screen each side to get clearances, The side benefit is i no longer have any helmet buffetting which was a problem stock
It is the excessive rake in the stock bars which give the clearances on the screen but cramp the rider up when up on the pegs
Old 05-06-2013, 09:57 AM   #3732
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Hmmm.... I have a couple of other sets of bars I can try out with the Yamaha stock bend and CR High bend. I'll have to test fit and see what will work.
Old 05-07-2013, 08:42 AM   #3733
Barnman
Barnman's Avatar
Oddometer: 209
18 inch wheel
Just found this on ebay, but can't find any information on the rim spec anywhere.
Its a trials rim, so not sure if it would be strong enough for use on the dakar, but excel rim and tubless sounds great for the back - what am I missing?
Its 18 x 400 , so not sure how that would compare with 18 x 2.5 inch that I need - Anybody know?
Barnman is offline   Reply With Quote
Old 05-07-2013, 02:41 PM   #3734
Aquatic
Aquatic's Avatar
Oddometer: 1,640
You going to need a special hub for that rim. The spokes are the opposite way round.
Good idea though. Super strong rim and tubeless.
Old 05-07-2013, 03:36 PM   #3735
swamp
swamp's Avatar
Oddometer: 1,851
yep. i have a trials bike too.
also, the disc brake is going to be tiny .
Enduro Earth
YOUTUBE
Times are GMT -7.   It's 11:11 PM.
