Old 05-01-2013, 08:54 AM   #16
charlie264
charlie264's Avatar
Oddometer: 8,258
Seems a common problem, correct fork install is the key. A mate builds forks for speedway bikes, he has 2 meter long vernier calipers, measures both forks at rest and marks.
Old 05-01-2013, 04:10 PM   #17
ipaulog OP
ipaulog's Avatar
Oddometer: 43
Originally Posted by gefr View Post
This was a problem with early bikes. That black sticky coating was trouble. I removed it with sandpaper and grease thoroughly. I also fabricaled a cylinder that bolts in the axle and can be taped to drive the axle out.
Cheers.
I started rubbing down the rough patch on the side where the bearing had bonded to the axle and it revealed pitting so I just polished the whole smaller diameter section and greased with Silkolene RG2. I will be checking it again before too long.
ipaulog is offline   Reply With Quote
Old 05-01-2013, 04:21 PM   #18
ipaulog OP
ipaulog's Avatar
Oddometer: 43
I will check again but I no longer think fork alignment to be the issue here. Everything was ok but one bearing surface was badly corroded and forming a bond with the axle. I now have SKF bearings and a polished/greased axle (and a puller installed)...
Old 05-01-2013, 09:37 PM   #19
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,946
The handle for the axle nut spanner makes a good drift for the front axle, without damaging the threads.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 05-01-2013, 10:09 PM   #20
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,789
i pulled the axle on day one and greased it with a good waterproof grease. That said it has not been an issue since. If done when new dont think it will be an issue. Polishing the axles after the fact and then greasing it would also serve the same purpose.
Just my .02
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 05-02-2013, 12:52 AM   #21
ipaulog OP
ipaulog's Avatar
Oddometer: 43
Just my .02
Unfortunately the first 20,000 miles were on the clock before I bought this bike and although I read up on the major things to look out for I missed this one.
Times are GMT -7.   It's 09:28 PM.
