Old 05-01-2013, 11:08 AM   #1516
Mugwest
Mugwest's Avatar
Oddometer: 6,343
Originally Posted by tdrrally View Post
i will agree with that sir
one less shock and muffler to buy
The entire KLR Philosophy summarized in 7 words
Mugwest is offline   Reply With Quote
Old 05-01-2013, 11:30 AM   #1517
tdrrally
tdrrally's Avatar
Oddometer: 3,349
1997 DR350se
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 05-02-2013, 06:08 AM   #1518
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,688
Originally Posted by DiabloADV View Post
Here's my conversion to single muffler. Next up is to weld the mounting tabs to the subframe and bolt the muffler in place. Then finish the hookup to the crossover I made.
Conventional wisdom says the cross over increases efficency by allowing the cylinders to share the mufflers, increasing the muffler volume available to each cylinder.
Why are you adding a crossover to a single muffler design?
Am I misunderstanding your use of "cross over" and you mean the same as junction box or "Y" pipe?
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 05-02-2013, 06:20 AM   #1519
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,257
I don't know about power, but the crossover definitely reduces noise on the GS.
Old 05-02-2013, 06:21 AM   #1520
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,512
It also allows the cylinders to share the volume of both headers. Just because a bike has a single muffler doesn't mean that the crossover won't have any effect. BMW put crossovers on both the R100GS and R100R - both single muffler models.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 05-02-2013, 06:43 AM   #1521
AntonLargiader
Oddometer: 4,257
Old 05-02-2013, 12:26 PM   #1522
Toaster.Tan
Toaster Rider
Toaster.Tan's Avatar
Oddometer: 159
Question Cross-over / joined exhaust effects
I noticed they place the cross-over where both headers are the same length. When two exhaust headers with no cross-over are joined into a single prior to the silencer - does one header being longer than the other before the merge effect performance of one jug over the other? How do you 'balance' the effect if it does?
ToasterTan
Custom Top Brace: http://www.pbase.com/toastertan/top_braces
72 R75/5 Toaster~
80 CBX-SuperSport~91 R100GS-PD~04 R1150RT
Bobber project using 1203cc Thunderbolt engine.
Toaster.Tan is offline   Reply With Quote
Old 05-02-2013, 01:22 PM   #1523
DiabloADV
Semi-Occasional
Oddometer: 2,305
There is the existing crossover at the front, which I'm going to bother eliminating.
I was referring to the "Y" that I made to bring the right side to the left side.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 05-02-2013, 04:23 PM   #1524
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,761
Once again, i invoke what i heard from the the mouth of Paul Rooney, whose opinion it was that the crossover pipe was there for when the bike was at idle. It was an idle assist, for whatever reason.
Thi came up because i noticed he'd cit his off on the R65RR and welded plugs over the holes, and i wondered why. He said it wasnt built to go at idle, and every little bit cuts weight :)
Unintentional psychokinesis.
Stagehand screwed with this post 05-02-2013 at 04:28 PM
Stagehand is offline   Reply With Quote
Old 06-30-2013, 04:42 AM   #1525
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,906
Had a great day, a few dozen water crossing, lots of narrow rocky trails....the airhead took a beating and keeps on ticking
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is online now   Reply With Quote
Old 06-30-2013, 06:30 AM   #1526
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,576
Originally Posted by Deadly99 View Post
That's the way they're supposed to look.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 06-30-2013, 07:16 AM   #1527
CrazyIvan
Vonkentrekker
CrazyIvan's Avatar
Oddometer: 151
First careful testride today!
CrazyIvan is offline   Reply With Quote
Old 07-01-2013, 08:50 AM   #1528
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,906
Agreed, I just got the bike a couple of weeks ago aftet years of lurking here and I have to say i'm impressed. I've got a head full of ideas and plans for it...fortunately I have a very good platform to build from. previous owners have done most of the mods I would have. I intend to give it a more "rally" look and the ergos need to be adjusted and it's requires mods to enable it to become a submarine..mechanically wise she runs like a dream.
Extended swing arm
Cams upgraded
Pistons coated
6000 miles on engine
Hpn transmission
Hpn style frame
1040cc
Etc
I feel very spoiled and I'm loving it
Roaming Rally 2015
Old 07-01-2013, 09:39 AM   #1529
Airhead Wrangler
Adios Mexico
Oddometer: 6,512
Extended swing arm
Cams upgraded
Pistons coated
Hpn transmission
Hpn style frame
1040cc
Etc
I like. Where did it come from? Who built it? Got any close-ups of the frame work? You realize we're not going to let you off the hook with one photo, right?
Old 07-01-2013, 09:59 AM   #1530
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,558
That's a good enough reason to have it for me. I must be one of those boring BMW guys.
+1 I can't believe that in this day and age people still build motorcycles without telling the world about it on the internet. Selfish jerks
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Times are GMT -7.   It's 04:08 AM.
