Old 04-30-2013, 06:34 PM   #706
Mastodon
Mother F'n Dinosaur
Mastodon's Avatar
Oddometer: 661
Originally Posted by amanlikemike View Post
Yeeeeeeaaaaahhhhhh.... That'd do it!
The fasteners need to be fully flush, tightened and thread-locked. The abrasion on the inner liner is definitely a side-effect of them not being so, and it looks like just enough of the waterproof coating has been scrubbed off to allow moisture to wick its way in.
The packs need to be fitted as you would a car wheel (i.e. fasteners diagonally inserted across from each other and then tightened), so the corners of the bag can be pulled to fit (it needs to be a very tight tolerance to prevent them shaking off or wearing out over time). As you discovered, attaching them in pretty much any other order will make it all but impossible to line up the final couple of holes per bag. If - for some reason - it still proves tricky, you could always drill out the holes by another 0.5 / 1mm diameter to give a bit more tolerance. But that is a last resort and shouldn't be necessary.
Glad we got there in the end!
PM me your address and I'll stick seven sets of fasteners and a replacement liner in tomorrow's mail, so we can get this show back on the [off-] road.
Cheers,
Michael
PM sent! Just want to say that your level of support is pretty much unheard of in this day and age. I'll definitely be buying more Kriega products in the future
Mastodon is offline   Reply With Quote
Old 05-02-2013, 06:14 PM   #707
Woody2627
Skinny Decaf Latte Thanks
Woody2627's Avatar
Oddometer: 935
I'm looking for a backpack that will hold an Arai XD3, or 4, and a 14" laptop but not much else of any size, and can use as carry on for flying. Any suggestions?
Woody2627 is offline   Reply With Quote
Old 05-03-2013, 09:28 AM   #708
Jason Abbott
Long time Idaho rider
Jason Abbott's Avatar
Oddometer: 659
Overlander loops on KTM 500
I got some quick phone shots of my loop locations for reference.
I chose the locations by posing the bags, marking, then tweaking when I saw the plastic structure under the fender.
Per the advice here, I'll try mounting the bags in a higher position.
The trouble with the bags up higher is finding somewhere to anchor the bottom. I'll figure something out.
Originally Posted by Jason Abbott View Post
That makes sense. I will give it a shot when I get the one loop replaced. And I'll post up some pictures of my loop layout on the KTM 500. Thanks again.
Photo ride reports: http://trailimage.com/ _
Jason Abbott is offline   Reply With Quote
Old 05-06-2013, 04:42 PM   #709
amanlikemike OP
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 978
Inmate inkfx kindly sent us these shots of his new 990 kitted out with the Overlander 60 and RotopaX, from his recent Baja shakedown trip...
... And now back to work!
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 05-06-2013, 04:45 PM   #710
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,120
Got my overlander stuff last week, but havent even had a chance to open the box yet! I will, tonight, hopefully, after the kiddo goes to bed. Reading her stories usually is the kiss of death for me, though 3
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 05-06-2013, 04:52 PM   #711
amanlikemike OP
Oddometer: 978
Hey Woody,
Apologies for the delay in getting back to you.
To answer you question; Kriega doesn't make a bag specifically designed to accommodate a helmet. the packs are designed to perform when you need it the most i.e. while you are riding (and your helmet is being used). Making the packs bigger, or adding a helmet carrier is likely to compromise this performance. That said, depending on the size of your lid, it might be possible to fit it in an R35. I have a Large XD-4 and can't get it in, but Mrs. Kriega USA's Medium will. But that's with the peak removed.
And it would be quite a squeeze (depth-wise, at least) with a laptop in there.
That said, we do offer a superior helmet cover / carrier in the form of the US Skin:
http://www.kriega.us/us-skin-motocross-helmet-cover/.
This offers excellent protection, compared to standard helmet bags and comes complete with a short carry handle with plastic rings and longer shoulder straps to make toting your helmet around a little easier. It can be attached to a backpack pretty easily using a karabiner or similar. Even if it was carried separately, you could use it as your second piece of carry-on (in the US at least - not sure how many bags you're allowed in Oz). Bu
t this is not an official solution. Regardless, I strongly suspect that a backpack so big that it can handle swallow up an XD-4 and a laptop, would be a funny shape, not to mention a little unwieldy for riding with.
I hope this info helps, but please feel free to drop me a line if you would like any more detail or feel I can be of any further assistance at this stage.
Cheers,
Michael
'Ave it.
BritKit LLC
amanlikemike screwed with this post 05-06-2013 at 04:57 PM
Old 05-06-2013, 05:03 PM   #712
amanlikemike OP
Oddometer: 978
Thanks, Jason.
If you want to get behind that forward side panel, you should be able to access a section of the subframe, where the strap can't slide vertically and wrap the daisy chain around that, so it looks a little like this:
Let me know how you get on once you've got that errant Rack Loop locked down.
Cheers,
Michael
'Ave it.
BritKit LLC
amanlikemike screwed with this post 05-06-2013 at 05:11 PM
Old 05-06-2013, 05:10 PM   #713
amanlikemike OP
Oddometer: 978
Putting the nipper to sleep so dad can go play with his new toys. Yup! That's about right!
'Ave it.
BritKit LLC
Old 05-06-2013, 08:37 PM   #714
Mastodon
Mother F'n Dinosaur
Mastodon's Avatar
Oddometer: 661
Got my replacement parts today. Probably came in on Saturday, since the mail lady came by after I checked the mail today. Put everything together, and loaded it up a bit too. I can keep all of my rain gear, and other auxiliary gear too, in one of the four bags, with room to spare!
Gear
Loaded up in the bag
Love the Overlander system. Lets my Scrambler be the bike I want it to.
Old 05-07-2013, 10:30 AM   #715
amanlikemike OP
Oddometer: 978
Gear
Excellent. Can't wait to see it on the Scram'!
"Lets my Scrambler be the bike I want it to." That is a great quote!
Cheers,
Michael
'Ave it.
BritKit LLC
Old 05-07-2013, 02:52 PM   #716
Happycamper
Have bikes, will travel
Happycamper's Avatar
Oddometer: 603
Question Overlander 60
Michael,
Do you know if the 60 is compatable with Holan's racks?
Thanks.
Happycamper
2009 F800GS
2014 KTM 690 Enduro R
Happycamper is offline   Reply With Quote
Old 05-07-2013, 03:16 PM   #717
amanlikemike OP
Oddometer: 978
Originally Posted by Happycamper View Post
Michael,
Thanks.
Fairly sure the Holan's are 'precisely the same dimensions' () as the Touratech racks, so shouldn't be an issue. If you can confirm the measurements of the rectangular 'hoop' and tubing diameter of the ones you have I can say for sure.
Cheers,
Michael
'Ave it.
BritKit LLC
Old 05-07-2013, 03:32 PM   #718
Mastodon
Mother F'n Dinosaur
Mastodon's Avatar
Oddometer: 661
Cheers,
Michael
Haha, thanks.
I wrote up a ride report about a weeks ago on a 1200 mile trip I did with the Scram. Good number of pics during the dry part. I was too cold and wet to stop during the rainy bits.
Three States and a Wedding
Old 05-08-2013, 02:22 PM   #719
Balkan Boy
Oddometer: 1,062
New kit:
R8.
Very well made. I don't know any other manufacturer (in and around motorcycling) that makes stuff of such quality.
This is as big waist-bag as you would want to carry. Short for the camping gear, it will hold everything you need to carry on a motorcycle. A lot of different compartments. It sags a little (with 2kg of stuff in it), but this will need further field testing.
As predicted, it will not go well with an R25, but this combination would be too much gear even for a paratrooper.
Theoretically, it could work with a waist bag facing front.
I sense a Hydro pack in my future.
Balkan Boy is offline   Reply With Quote
Old 05-09-2013, 11:49 AM   #720
salcar
Riding 4 Health
salcar's Avatar
Oddometer: 1,078
Our typical setup for one week ride in Nicaragua fits into a “US-40″, which is a combination of three bags:
  • Kriega US-20 in center holds all the clothes
  • Kriega US-10 on one side holds a toolkit and other items
  • Kriega US-10 on other side holds rainsuit, shoes, and a camp towel.
For a full packing description click here
Nicaragua motorcycle rental, tours and training NICAMOTO
Tent list (guest room) on ADV on HUBB
salcar is offline   Reply With Quote
Times are GMT -7.   It's 05:05 PM.
