Old 05-04-2013, 06:00 PM   #16966
graygoat657
Oddometer: 317
Wonkyy BD DS kit
So I joined the Porcine Patrol with the purchase of a 2003. Did a quick shake down shred, and found a out the DS kit the previous owner installed has some errant behavior. If I flick the right blinker on, works (pretty much) like it should. Flick the left blinker and the head light blinks. On top of that no brake or tail light (have yet to put a meter on things), and the whole system likes to have a bit of throttle to operate. The battery still seems alive (strong horn when engine off).
Any one run into something like this? Thinking its going to be some hours of poking and prodding.
graygoat657 is offline   Reply With Quote
Old 05-04-2013, 08:37 PM   #16967
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,969
Originally Posted by jwalters View Post
Thanks guys for the input, I appreciate it.
Lean it out. Do you have a screen kit on the airbox cover? Take it for a quick whip without the cover on it, I bet the stutter is gone. Or drop the needle.
larryboy is online now   Reply With Quote
Old 05-05-2013, 11:56 AM   #16968
PeteN95
PeteN95's Avatar
Oddometer: 2,786
Originally Posted by larryboy View Post
I think you're getting into that gigantic main jet too soon, I'd start dropping the needle if you want to run it that rich.
That is what happened when I added a header and cam, I had to drop the needle and go up 3 jet sizes, currently 180, because it went lean on top and fat in the middle. That last dyno run he said it needed another bigger jet and a pilot, now at 70.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 05-05-2013, 01:08 PM   #16969
XR650Gnar
Oddometer: 14
Thermostat?
I just rebuilt pretty much the whole bike including the engine, ended up modifying the side panel for airflow and going with a stage 1 cam which required me to go to the third clip on the B53E needle and bumping from a 165 main to a 170, it seems to be running great, good power througout the throttle range, minimal popping on decel, decent idle. throughout the break in Ive been a little nervous that my water temp sensor wasnt working so Ive been doing short runs to keep the temps low, today I finished up with the rest of the odds and ends and took it for a ride, well ill be damned it started to register the temp! Which means its either been staying below 100*F or the thing actually wasnt working and now is. I did go with some larger chinese built ebay radiators that Im actually quite pleased with but now they seem to be working too well, I couldnt get the temp to break 130*F. I was running without the T-stat before the rebuild as it was running hot, but I assume I should run one now? I think running temp should be around 190-200 right?
XR650Gnar is offline   Reply With Quote
Old 05-05-2013, 02:17 PM   #16970
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,300
I believe the thermostat opens at around 180.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 05-05-2013, 03:14 PM   #16971
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,311
Great feedback, thanks! Maybe I over compensated.
Originally Posted by slickwill View Post
My bike is built way beyond what you're describing and I run a 70s pilot. I've had it on the dyno at 600ft and the A/F was perfect. I think you'd have a hard time coming up with a situation where you'd ever need a 72 pilot if my bike doesn't need it. For comparison I run a 192 main jet most of the year, 190 when it's REALLY hot and humid, 195 when it's really cold.
Sent from my DROIDX using Tapatalk 2
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 05-05-2013, 03:25 PM   #16972
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
Quoted a post, but it grabbed some other post!
This was for for the guy with the XR600 rebuilt to 628 getting hot.
Did you up size the jets after the rebuild?
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr screwed with this post 05-05-2013 at 03:31 PM
Trl Rdr is offline   Reply With Quote
Old 05-06-2013, 07:02 AM   #16973
crypto666
Oddometer: 1,342
Originally Posted by Shibby! View Post
How's that suspension working out for you?
I love XRR's with black wheels. I know that's pretty petty, but they make the bike look so gnarly. The grey forks with black wheel and gators set it off.
I have strange tastes...
Sweet. I hit a set of whoops the other day while day dreaming at around 60mph. Then only thing that slowed me down was fear, the bike sucked it up perfectly.
crypto666 is offline   Reply With Quote
Old 05-06-2013, 07:08 AM   #16974
crypto666
Oddometer: 1,342
Originally Posted by cragdweller View Post
My 2000 has its rearend pushed to the left when viewing from behind.
When you crash, you need to go down on the right side and it will correct this.
Old 05-07-2013, 11:11 AM   #16975
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Jwalters & Flyguy,
I seem to remember the floatlevel is 18mm in the books but 19mm cures a dribling carb when parked over on the stand.
Hence that mentioned 16mm sounds awfully wrong?
BuRPsa is offline   Reply With Quote
Old 05-07-2013, 04:56 PM   #16976
ride4fun562
ride4fun562's Avatar
Oddometer: 209
Does anyone live near Southern California , Long Beach more specifically. I want to compare my piggy to someone else's and I don't know anyone who has one. It would be awesome to go on a little ride and compare if you have it plated, gas would be on me, send a PM.
ride4fun562 is offline   Reply With Quote
Old 05-07-2013, 05:35 PM   #16977
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,311
The Clymer service manual also calls for 16mm. That seems to be the general consensus. I'll play around with it, and report back. So much easier working on the one carb, than my Honda CB750. All 4 got tedious! :-)
Originally Posted by BuRPsa View Post
Jwalters & Flyguy,
Old 05-07-2013, 06:01 PM   #16978
Shibby!
Oddometer: 1,658
Anybody have a tanker brace they are willing to part with?
My buddy scored a tank without the brace.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 05-07-2013, 08:29 PM   #16979
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 671
Ditto. I'm hoping Hodakaguy will make another batch sometime soon - buy if someone is sitting on a spare, drop me a line ( after contacting Shibby first of course).
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 05-08-2013, 02:19 AM   #16980
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Ah, my bad. Then add 1mm ie 17mm and rid yourself of leaking fuel when lent over on the sidestand.
Times are GMT -7.   It's 07:14 PM.
