Closed Thread
Old 05-07-2013, 09:59 AM   #3331
Happy Wanderer
Day Dreaming.. .
Oddometer: 206
Originally Posted by Poolside View Post
That's just silly, HW. By what mechanism is the damage supposed to occur?
I am not an expert on engine fueling (that's your dept) but from what I have read I believe the correct answer is heat. Overly rich mixtures may cause unspent fuel to enter into the exhaust flow. When this hits the cataclysmic perverter it causes super heating. This can lead to melting of the honeycomb structure and the metals (catalyst) it is made of.
Happy Wanderer is offline
Old 05-07-2013, 10:22 AM   #3332
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,879
Agreed
Old enough to know better....
Young enough to try it again
GS Addict is offline
Old 05-07-2013, 11:00 AM   #3333
rdcyclist
rdcyclist's Avatar
Oddometer: 1,167
It takes much richer mixture than any fueling mod we're talkin' 'bout here to melt a cat. Think rich like two out of six in a car not firing and your wife drives it around town anyway, thinking it would blow itself out. DAMHIK...
rdcyclist is offline
Old 05-07-2013, 12:03 PM   #3334
RAL88
Marineboy
RAL88's Avatar
Oddometer: 77
Yes. The ECU always uses the air temperature input and barometric pressure to calculate air density. With that information it determines the length of the fuel injector pulse necessary to create the desired fuel/air density ratio.
Regarding the afterfire (aka backfire) popping from the tailpipe, that issue is primarily a function of the inconsistent Overrun Fuel Cutoff routine in the ECU.
Moving the throttle around within the range of fully closed to slightly decelerating is what creates the unburned combustible mixture in the exhaust tubing, and causes the backfires. Tailpipe popping can be greatly reduced or eliminated with careful operation of the throttle.
To describe the 'workaround' throttle operation as simply as possible, the throttle should be either holding the bike at a constant speed, or opened more to cause acceleration. If you want to decelerate at more than a slight rate, close the throttle fully. When you want to accelerate, or hold the new lower speed, open the throttle quickly and directly to where you want it.
The above takes practice of course. And I don't like the idea of having to adapt to the ECU. But without other electronic measures there's no way around it.
The reduced air temperature input has some slight effect on backfiring, I don't know that I'd call it significant, but there is an improvement. As you have seen however, some bikes experience more improvement than others. I ascribe the difference more to the rider, which I suppose is a good example of 'Your mileage may vary.' (YMMV)
Regardless the name, there are better ways around the problem of tailpipe popping, afterfire, or backfire.
Thanks for that great explanation. So what is the ECU doing when I completely remove the ccp and this stops the tailpipe popping?
Thanks,
Rich
____________
'96' K1100LT-SE
'97' R850GS-R
"If it ain't broke take it apart and make it work better"
RAL88 is offline
Old 05-07-2013, 11:39 PM   #3335
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Just bought 2, one for my 2012 GS/A and one for my 2002 R1100S Boxer Cup Prep...
I'd really like to receive them before the end of May if possible. I'm traveling to Alaska, leaving the first week of June, on my GS/A.
I'm even willing to help with the assembly, as I have stated in at least 2 pm messages sent... Let me know...
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline
Old 05-08-2013, 04:37 PM   #3336
frogy
frogy's Avatar
Oddometer: 811
Everytime you post I always get dizzy...no clue why
2002 R1150RT, 1985 Naked K100RT
frogy is offline
Old 05-08-2013, 04:39 PM   #3337
Hookapelli
Adventure-Junkie
Hookapelli's Avatar
Oddometer: 2,629
Every time he posts I get wood... not sure why....
I got nothin'....
Hookapelli is offline
Old 05-08-2013, 04:46 PM   #3338
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,548
Eek
every time he posts, i make sure my wife does not pass by and i dont know why
Cheers!
Dave
Racegun screwed with this post 05-08-2013 at 05:05 PM
Racegun is offline
Old 05-08-2013, 05:48 PM   #3339
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,519
I'm really a very slow putt-putt type of rider, lucky to get into third gear on most rides. Today was one such day, motoring along in 3rd, in the slow lane up Ashby. When all of a sudden I realized the bus to my left was changing lanes, into my space, man.
Looking back, I'm grateful for two things: A quick reaction to gas it right the hell out of there, and the sudden rush of acceleration that the ICEE AIRE gave me. Two to Engineering and Marketing.
Splitting lanes, and splitting hairs.
Andrew is offline
Old 05-08-2013, 07:29 PM   #3340
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
Wicked
Every time I post something, no one can remember what I ost... I don't know why either...
Old 05-09-2013, 08:06 AM   #3341
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,548
do you know who she is? ( besides well endowed)
Cheers!
Dave
Racegun is offline
Old 05-09-2013, 04:25 PM   #3342
frogy
frogy's Avatar
Oddometer: 811
Thank you, I was wondering when we were going to get back on subject.
frogy is offline
Old 05-09-2013, 08:56 PM   #3343
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,378
I'll tell you after I receive my items...
Old 05-10-2013, 05:49 PM   #3344
kimokk
kimokk's Avatar
Oddometer: 103
I would like mine by the end of May too! I ordered it in January.
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline
Old 05-13-2013, 10:51 PM   #3345
DidYouSeeThat
Uhhhh... Where?
DidYouSeeThat's Avatar
Oddometer: 189
OK, this has probably been asked or is posted were normal people should be able to find and read it easily... butt.....
Is the IICE Air I got for my 2009 F800GS compatible with the new 2013 F800GS?... not that I am officially looking ;)
Whoa... DidYouSeeThat!.. Uhh.. Where?...
www.slapdrum.com
09 F800GS - Yel/Bck, IICE Air, Bars, MotoSport Bags
08 TE250 - with 300cc Kit
10 Rubicon
DidYouSeeThat is offline
Closed Thread
Times are GMT -7.   It's 05:15 AM.
