Old 05-04-2013, 01:14 PM   #556
pglc
2B1ask1
pglc's Avatar
Oddometer: 41
PM sent
pglc is offline   Reply With Quote
Old 05-06-2013, 11:59 AM   #557
mountainpete
Outdoor use only
Oddometer: 19
Ordered a set last night for my 2012 V-Strom. Will post up pics after the install.
mountainpete is offline   Reply With Quote
Old 05-06-2013, 10:09 PM   #558
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,301
Anyone mount these to a '13 800GS? Looking for ideas.....
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is offline   Reply With Quote
Old 05-07-2013, 04:32 AM   #559
pglc
2B1ask1
pglc's Avatar
Oddometer: 41
Anyone mount these on a 02-09 Vstrom DL1000. Looking for the install directions and pictures if you have.
Old 05-07-2013, 04:35 AM   #560
pglc
2B1ask1
pglc's Avatar
Oddometer: 41
Install MM10
I don't know if there is much difference between a 09 and a 12, but I'd like to see the pictures as you do the install. I'm in Italy on my way back to the states that's when I'll do the install. Pete
Old 05-07-2013, 02:12 PM   #561
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,178
Originally Posted by pglc View Post
PM sent
replied
thanks,
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 05-07-2013, 02:13 PM   #562
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,178
Looking forward to the pics
Thanks,
-Brian
Old 05-07-2013, 02:15 PM   #563
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,178
Goodcat8 posted a some pics a few clicks back of the Bullets on his DL650...
Originally Posted by goodcat8 View Post
Here we go.
Fender mounted Bullet lights, 06 Vstrom 650.
Old 05-08-2013, 11:28 AM   #564
jmardy
Atheist for a reason
jmardy's Avatar
Oddometer: 17
What about lighting conrollers such as the Skene 170?
The MM-10s look fantastic, I ordered a pair yesterday. Wondering if anyone has used the Skene Intelligent Lighting controllers with these and what your thoughts are.
http://www.lights.skenedesign.com/IQ_175.shtml
jmardy is offline   Reply With Quote
Old 05-09-2013, 01:09 PM   #565
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,178
I cant personally speak for the Skene controllers, but I do know that there are more than a few out there that have the MM10's connected using a Skene.
FWIW - we are working on a plugin for our harness that will pulse the lights in a set sequence. Its still in the testing/prototype phase and we hope to have it ready in 3 - 4 weeks. Price will be in the $20 - $25 range.
thanks,
-Brian
Old 05-10-2013, 12:29 PM   #566
jmardy
jmardy's Avatar
Oddometer: 17
thanks,
-Brian
Thanks Brian,
I ordered one of them. Will post my results and install pics.
Old 05-10-2013, 05:43 PM   #567
headshrink
headshrink's Avatar
Oddometer: 55
After reading through this and other thread,, I finally decided to register here (no more lurking), AND put in my order. Can't wait.
headshrink is offline   Reply With Quote
Old 05-12-2013, 08:35 PM   #568
jmardy
jmardy's Avatar
Oddometer: 17
2005 Aprilia Tuono install complete!
So after looking at various possible mounting points, I finally decided on using the frame sliders.
It was pretty easy to grind a flat spot then mount the brackets.
I also installed the Skene Designs Intelligent controller referenced earlier.
The cool thing about the controller is that you can have multiple brightness settings, one for the switch "off" position, one for the switch "on" position and one for high beams active.
There is also an alert feature that gets invoked when you flash your high beams twice.
Anyway, I'm really impressed with the build quality of the Mondo Motors lights. The whole package is really well thought out. I haven't ridden with them yet, hopefully I don't irritate other drivers, these things get BRIGHT (and a bit glarey to be honest).
Old 05-12-2013, 09:27 PM   #569
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,010
Off the frame sliders a pretty cool idea
Angle them properly and traffic won't be hindered at all.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 05-13-2013, 06:40 AM   #570
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,178
Agreed
Thanks for posting up the pics.
-Brian
Times are GMT -7.   It's 09:54 AM.
