Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 05-08-2013, 10:15 AM   #16936
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,206
Originally Posted by swimmer View Post
The general consensus is that the arrow map will reduce your mpg by maybe ~20% (someone can correct me if they think my numbers are way off). Several people seem to be succesful in running various aftermarket exhausts (i.e. Leo Vince) with the standard map and that seems to not reduce mpg. I may go this route.
The Arrow pipe is SUPER expensive too. I have a Scorpion that sounds lovely (has a removable baffle for when you want a bit more stealth....nver fitted mine though ) and uses the standard map. I get about 47ish on my daily commute.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-08-2013, 10:49 AM   #16937
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,738
Originally Posted by lmychajluk View Post
Between breaking it in, winter/summer gas switchover, adding some farkles, etc... I've not been very consistent between fillups, but overall I'm averaging 44mpg so far over ~1500mi, with my last fill up at 53mpg (I was a bit surprised, actually). I've read that you'll start seeing some improvements after a few thousand miles.
All true.
Tiger 800 gas mileage does tend to continue to improve up to 5000 miles or more.
And this bike seems to be more sensitive than most to factors like air temperature, summer/winter gas blend, etc. I can get as low as about 35mpg when commuting in cold weather (winter gas, cold, dense air, 80mph on the highway for 20 miles followed by stop-start in-town riding). And I can get upwards of 50mpg while out for a long, moderately-paced ride on country roads in warm weather. For what it's worth, the latter is much more common than the former -- generally speaking, my Tiger is usually between 45 and 50mpg.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 05-08-2013, 12:18 PM   #16938
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
I get shitty mileage, and my rear tire tends to last about half the time as others. Hummmmm, I wonder if the 2 are related?
I blame the tire.
fbj913 is offline   Reply With Quote
Old 05-08-2013, 12:22 PM   #16939
lmychajluk
Oddometer: 2,098
Originally Posted by markbvt View Post
.... I can get as low as about 35mpg when commuting in cold weather (winter gas, cold, dense air, 80mph on the highway for 20 miles followed by stop-start in-town riding). And I can get upwards of 50mpg while out for a long, moderately-paced ride on country roads in warm weather. ...
--mark
Shouldn't we get better MPG with winter gas and cooler air?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 05-08-2013, 12:29 PM   #16940
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,678
I always seem to get better MPG in mountains, which I attribute to having to push through fewer air molecules. So, if that's true, then warmer weather (less dense air) means better MPG also.
Old 05-08-2013, 01:31 PM   #16941
fbj913
I ride
fbj913's Avatar
Oddometer: 2,360
no, the grade of gas in the winter isn't as good. they have to step up the grade because of the heat and effects on the atmosphere.
that's how someone at the gas station explained it to me once
Old 05-08-2013, 01:36 PM   #16942
Mercury264
Mercury264's Avatar
Oddometer: 22,206
Winter/Summer, makes no difference to me, I just love twisting the throttle and hearing that beautiful triple sing way too much to worry about fuel consumption
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-08-2013, 01:52 PM   #16943
ilbiker
Oddometer: 166
I have about 500 miles on mine and according to the computer in the dash, I'm only grtting 36 mpg with stock pipes, stock tune, and east throttle.
I don't suffer from my insanity, everyone else around me does...
ilbiker is offline   Reply With Quote
Old 05-08-2013, 02:00 PM   #16944
Mercury264
Mercury264's Avatar
Oddometer: 22,206
That seems kinda low but I'm sure as it loosens up some, that will get better.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 05-08-2013, 02:23 PM   #16945
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,728
winter gas contains ethanol (or more of it) in many states. Ethanol = bad mpg.
swimmer is offline   Reply With Quote
Old 05-08-2013, 02:35 PM   #16946
dljocky
Oddometer: 864
Good day all,
Thanks for all the replies to my question about MPG. I really appreciate it.
Although my enviro footprint, total cost of ownership etc are all important to me, I'm mostly concerned with how far I can go on a tank of fuel. Like Dirtmonkey said earlier, we ride in a lot of out the way places where fuel may not be readily available. I've ridden the Roadie and the XC and they seem like fantastic bikes!
dljocky is offline   Reply With Quote
Old 05-08-2013, 03:41 PM   #16947
orv
Busted butt
Oddometer: 443
Weeeell, IF I had to stretch the tank, I'm sure the mileage on mine would be above 50 mph. Normal hot rodding gets me over 46, but I live at 5400 feet and mostly ride higher. My normal range is about 230 to 240 miles.
Altitude improves mileage. Winter mixture cuts mileage on all vehicles by about 10%. Ethanol sucks in every way. It is not your engine's or the environments friend; but there isn't a corn farmer in the country that isn't driving a new truck!
orv is offline   Reply With Quote
Old 05-08-2013, 04:23 PM   #16948
Tonk
Frozen Adventurer
Oddometer: 148
Just did 370 miles today ( mixed 140 highway miles, the rest back roads ) and averaged 45 MPG ( per the computer ). 800xc with stock exhaust and tires. Did about 80 MPH down the highway with the panniers off. My reserve light comes on around 180 miles or so and it always takes 3.8 gallons at the pump. I'm guessing I could do 220-240 miles on a tank before I'm walking.
The Tiger's range isn't what I was expecting but it is an amazing bike. Its too fun and functional to complain about the range. For those looking for ultra range, get a Rotopax, strap it to the back, the front, side or anywhere it fits and go. Tank size shouldn't limit anyone's possibilities.
Tonk is offline   Reply With Quote
Old 05-08-2013, 04:41 PM   #16949
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
I hear that!
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 05-08-2013, 04:41 PM   #16950
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,045
Originally Posted by browneye View Post
It's been said there's not a road in the country with a fuel stop greater than 130 miles.
by who?
for example, out west in WY there are remote ADV routes that you need over 200 mi range till the next gas station.
with a loaded with gear 800 getting maybe 40mpg (or less) you could be walking w/o extra fuel along.
for alot of our interesting ADV rides/routes we do a 200mi range is the safe #. sure you can find gas earlier, but that involves a boring & long out and backs just to fill back up. if you have the range, you can go the fun way. they guy w/o a 200mi range is not invited.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 05-08-2013 at 06:10 PM
eakins is online now   Reply With Quote
Times are GMT -7.   It's 01:49 AM.
