Thread Tools Search this Thread Rating: Thread Rating: 279 votes, 5.00 average. Display Modes
Old 05-01-2013, 06:16 AM   #376
Whorepedo
Whorepedo's Avatar
Oddometer: 501
Originally Posted by Steve W View Post
I had one of mine (478) replaced with a refurbished unit last month. No trouble with transferring my Lifetime maps, no issues with registering the new unit with myGarmin.
AFAIK, Garmin policy is to replace the unit with a refurb and then repair the faulty unit to new spec. At that point it becomes part of the replacement inventory. In the case of the 276c, this continued until Garmin ran out of parts.
I'll probably have my second unit done this winter.
Thats great to know! I did notice on the list of repair rates the 276c says not supported while the 478 says $170. If $170 gets me a factory refurb'd unit, I'm all in.
2000 Suzuki TLR; 2012 Yamaha Super Tenere; 2005 XT660R; 1993 TDM850; 1977 Kawi KE175
Whorepedo is offline   Reply With Quote
Old 05-01-2013, 07:32 AM   #377
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,768
Originally Posted by Whorepedo View Post
I've got a 478 that I bought used off of craigslist. The thing works great when its plugged in at home, but if its plugged into a car or the motorcycle, it cuts off every few miles. I've even used the exact same AC adapter in my truck and it still cuts off. The cable on the motorcycle is brand new and even that cuts off. The battery is charged so it looks like it would just switch to battery power but it doesnt.
Edit - One other caveat, when you turn the power off on the bike, it goes back to battery power?!
My concern is, I want to send it to Garmin and just pay the $170 for service but I have had the unit open to check the cables and try to make sure it wasnt just a loose connection. Its not under warranty so I guess that shouldnt matter.
The other thing, with the unit being so old will they even attempt to repair it or just take my $170 and tell me I need a new unit?
That would happen on my 478 also. Seems that intermittent losses of power (from the bike's wiring? from a loose / failing battery?) would shut the unit down.
I took care of it with software. I selected the "don't shut off if power is disconnected" option somewhere in the system menu.
All good now.
Gracie's Gold
Lobby is offline   Reply With Quote
Old 05-01-2013, 07:50 AM   #378
Whorepedo
Whorepedo's Avatar
Oddometer: 501
All good now.
Mine is already on that setting. And it fails on the bike wiring, the cigarette plug, and even the AC plug in a vehicle (my Jeep has an AC outlet) - All three are different harnesses. The crazy thing is when you plug it in indoors - with the same AC plug - and shake the shit out of it, it wont fail.
Old 05-01-2013, 07:54 AM   #379
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,786
Does it just wink off?
Probably a vibration issue that you can't replicate by just shaking it.
Boon Booni is online now   Reply With Quote
Old 05-01-2013, 07:56 AM   #380
Whorepedo
Whorepedo's Avatar
Oddometer: 501
You're probably right. Its on... and then its off. No warning or anything.
Old 05-01-2013, 10:56 PM   #381
crazybrit
crazybrit's Avatar
Oddometer: 8,559
Has anyone ever tried replacing the built-in maps on their 478 with a custom set?
Mapinstall (it seems) would install maps into built-in storage, if there was space, which there of course isn't. It doesn't seem to show what maps are installed or have an option to delete them.
Without a removable memory card installed, I'm not entirely sure what happens if you select a range of quads in Mapsource and try to "send to device". I assume it fails?
It's pretty easy to convert from Mapsource to an .img and supposedly "Webupdater.exe /upload_file path={pathto}.img" will upload the img to the built-in but a) it's not clear if it works on the 478 b) I'd read it erased all maps so I assume I'd lose the base autoroute and marine maps as well as the citynav?
crazybrit is offline   Reply With Quote
Old 05-02-2013, 05:21 AM   #382
mpatch
Oddometer: 1,044
Yes it's possible but you will lose all of your maps other than autoroute. That's how I installed all of city nav.
mpatch is online now   Reply With Quote
Old 05-08-2013, 09:59 PM   #383
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,568
Yeah, you can overwrite the maps in internal memory, but its not a trivial exercise. Lot's of trial and error to squeeze as many map segments as possible. I did it successfully last summer. I thinbk it was the instructions from here that worked: http://www.noeman.org/gsm/garmin-tut...eetpilots.html
Good luck.
joefromsf is online now   Reply With Quote
Old 05-13-2013, 10:45 AM   #384
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,826
Anyone else notice "ghosting" of your displayed custom Mapsource generated route on the 478 screen? In other words, If I build a route, upload it, then run it. I sometimes see a abnormality. A second straight line route leg as well as the proper, conformed to road leg. If I zoom out, it corrects. GPS direct though is always correct, you just ignore that errant route line.
My buddie has the same issue with his Mapsource generated custom routes on his 478 as well. Odd
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 05-13-2013, 11:58 AM   #385
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,339
Yep run into this a lot on mine on both the 478 & 376c. I still haven't figured out what causes it, but I'm much more likely to see it on routes that I've spent a lot of time manipulating on the MapSource. You are right that you only see it at specific zoom levels. Usually if you zoom out some, it fixes it.
I know one of the GPS programs, GPSBabel or the other one has a specific feature to remove these oddity's from your routes.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 05-13-2013, 01:49 PM   #386
DockingPilot
Oddometer: 9,826
Tell me more
Frank Reinbold
Old 05-13-2013, 04:29 PM   #387
BlueLghtning
Oddometer: 5,339
Tell me more
I knew as soon as I said it, I wouldn't be able to find it. :
I use both WindGDB3 & GPSBabel a lot, and I really thought it was in one of these, but I just looked and no luck? Maybe it was in an older version and got taken out. I have both WindGDB3 V3.63 & V3.70 and GPSBabel 1.3.3, 1.3.6 and just downloaded v1.4.4, but no luck in any of those.
When I find it again, it will dawn on me and I'll come back to this thread to post it. I know it was something like "fix erroneous route errors" or something to that effect.
Old 05-13-2013, 04:53 PM   #388
DockingPilot
Oddometer: 9,826
Ok thanks. Appreciate it
Frank Reinbold
Old 05-20-2013, 04:00 PM   #389
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,786
Huh, There's a new firmware update for the 478.
LINK
Adds "Support for new 010-10517-02 battery pack"
Old 06-20-2013, 08:42 AM   #390
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,786
Ah geez, after much soul searching and reviewing the Montana thread, I bit the bullet and went and got the russian 2 gig card and upgraded my 478 to the latest version of City Navigator North America.
Times are GMT -7.   It's 01:50 PM.
