Old 05-09-2013, 09:46 AM   #1
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Motion Pro - BeadPro Tire Bead Breaker and Lever Tool
So I gave these Motion Pro tools a try today for the first time BeadPro Tire Bead Breaker.
So will it break the bead on the rear wheel of the Adventure? Yep sure will, quite well in fact. You have dick about a bit to get "fork" part in far enough, but it once there it pops it off straight away.
Is the lever part any good? Not really to broad and flat - I reverted to my normal spoons.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema screwed with this post 05-09-2013 at 06:56 PM
ciedema is offline   Reply With Quote
Old 05-09-2013, 10:05 AM   #2
howl
990 Adventure
howl's Avatar
Oddometer: 98
Hi
I have an Abba bead breaker ,great bit of kit.
http://abbastands.co.uk/product_details.asp?id=11
howl is offline   Reply With Quote
Old 05-09-2013, 10:11 AM   #3
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Originally Posted by howl View Post
Hi
Yeah but that is a bit big to throw in a tool bag
I actually brought these for on the road, travelling. For that purpose they work well.
Old 05-09-2013, 10:33 AM   #4
triplenickel
triplenickel's Avatar
Oddometer: 2,430
The Motion Pros are nice but don't accomplish anything that 3 stubby irons won't.
07 SE
PG007
Old 05-09-2013, 01:05 PM   #5
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Your a better man than me! I can't break the bead with stubby tire irons or even my spoons - and don't really like using the stand to do it.
Old 05-09-2013, 01:33 PM   #6
bigkuri
bigkuri's Avatar
Oddometer: 879
I'm really not trolling, or trying to cause a heated whatever... But why do you need to use a bead-breaker? Just plonk the wheel down on some soft ground, put your heel on the bead-wall, and let your body weight do it all?
Or am I the only one that is 100kg (+)? Been doing this since a kid though, and never a bead not broken.... Getting the damned bastard things to seat and pop correctly is a different story..!
Sorry to hijack, just really curious as I see this all the time and have never understood.
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R (build thread at http://www.ktmforum.co.uk/adventure/...venture-r.html )
bigkuri is offline   Reply With Quote
Old 05-09-2013, 01:51 PM   #7
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,971
I can do that with anything other the 4" rim on the back of the Adventure, generally not even that extreme, a quick lever under the edge of the rim and bang it is done, but I can't do it this rim due the safety bead. I could be to unco though :)
Getting it to seat is no problem, little soap and they will sometimes pop on at 20psi, mostly a little more.
I actually like changing the tyre, once the bead is broken comes off and goes on really easy.
Old 05-09-2013, 02:46 PM   #8
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,856
Craig was mounting and dismounting Hidenau K60's which have really stiff beads.
"Experience alone is not the great teacher; Experience has to be multiplied by intelligence to yield sustained progress." Phil Schilling
Deuce is online now   Reply With Quote
Old 05-09-2013, 03:30 PM   #9
el queso
toda su base
el queso's Avatar
Oddometer: 768
I just learned an easy way to pop the bead on a K60 - just have a blowout at 70... By the time you stop, both sides are broken, so you only need to change your shorts and thrown in a new tube.
el queso is offline   Reply With Quote
Old 05-09-2013, 03:51 PM   #10
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Front wheels are easy :-) It is rears that are hard.
Old 05-09-2013, 06:28 PM   #11
triplenickel
Oddometer: 2,430
It's easy you could do it for sure, put three irons in the bead a few inches apart, push down the outer two and pry up with the middle one it's the same principle as the MP units.
07 SE
PG007
Old 05-09-2013, 06:49 PM   #12
KTMbageera
Oddometer: 89
Proper tire bead removal procedure
WOW, Have to pack extra shorts for this drill. Not sure I want to "practice" this move. Glad you survived with only your shorts a casualty.
KTMbageera is offline   Reply With Quote
Old 11-19-2013, 04:43 PM   #13
crazybrit
crazybrit's Avatar
Oddometer: 8,554
I just bought a pair of these, had $40 of gift card credit @amazon and $53.46 wasn't as obnoxious as the list-price. I've tried the side-stand trick and it's worked sometimes (but not always). I figure I'll try these. If they are no better I can turn-em around in the Flea Market.
[edit: also saw this guy raves about them (about half way down): http://www.advrider.com/forums/showp...&postcount=180 and if you look at the video of Schofield Pass embedded in the previous thread post: http://www.advrider.com/forums/showp...&postcount=149 you'll see that they all know a thing or two about bikes]
crazybrit screwed with this post 11-19-2013 at 05:18 PM
crazybrit is offline   Reply With Quote
Old 11-19-2013, 05:45 PM   #14
Martynho
No more Chilegringo.
Oddometer: 408
I dont get it
Every time I see this and other threads about bead breaker solutions, I simply just don't get it. Why the ferk do you want to spend money, or lug shed loads of weight in the case of some solutions out there??? Motion pro forged ally spoons are the bollocks. These supposed tire breaker spoons are not, don't fit in yer hand nice or give you the leverage the proper tools do. They are an abortion frankly.
Guys. The side stand solution. Works. Every time. I am a slim 51 year old and I can do it alone. In the bush.
WTF bother?
WTFV online, just put it in a youtube search.
Case closed.
Next....
Martynho is offline   Reply With Quote
Old 11-19-2013, 05:49 PM   #15
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Originally Posted by Martynho View Post
Case closed.
Next....
I think by now, EVERY person understands that the side-stand trick exists. WE GET IT. We don't need another post stating it. This thread isn't titled "what technique should I use to break the bead", it's titled " Motion Pro - BeadPro Tire Bead Breaker and Lever Tool".
Please try to honor the topic/spirit of a thread, if you can't, then noone is forcing you to post on it.
Times are GMT -7.   It's 05:03 PM.
