Old 05-10-2013, 04:55 AM   #1
blaster11 OP
Up and Operational
blaster11's Avatar
Oddometer: 6,947
Chain Tensioner Tool?
A while back I was watching someone tighten their chain on a japenese dual-sport bike with this style of tensioner (#24 or #29 in pic).
The tool was like a wrench that grabbed th nub on the tensioner, and rather effortlessly click it up a tooth. I wish had I asked him who made it, or where he got it. It's got to better than the screwdriver and hammer method.
So, anybody got intel on the tensioner tool?
blaster11 is offline   Reply With Quote
Old 05-10-2013, 11:11 AM   #2
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,843
When you loosen the axle nut, the entire axle/wheel assembly should be so loose, that you just scoot the rear wheel back a little and advance the snail adjuster one click, then kinda hit the rear of the tire to scoot everything back forward/tight. I always would use a Sharpie to mark the original position on the snail cam. If you are having to use a hammer to move the snail adjuster one click, something is too tight on your bike.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 05-10-2013, 08:34 PM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,315
I believe the tool you are looking for is an "adjustable hook spanner wrench"
GreaseMonkey is offline   Reply With Quote
Old 05-15-2013, 04:28 PM   #4
tundradirtbiker
Oddometer: 328
Using chain tension to hold snail adjuster in place
Set the adjusters as described above. Put a small punch in the back sprocket btwn chain. Rotate the wheel back til it tensions the chain on adjusters and tighten the axle bolt.
'05 450 EXC
tundradirtbiker is offline   Reply With Quote
Times are GMT -7.   It's 10:55 PM.
