Old 05-11-2013, 02:22 PM   #1
Echolake OP
Echolake
Oddometer: 6
Bluhduh '72 R75/5-How to remove Ignition switch and terminal board inside headlight Bucket?
OK, I give up. Does anyone know the secret to removing the terminal board inside the headlight? I have searched this forum and every manual I can find. I am at a complete loss....
Echolake is offline   Reply With Quote
Old 05-11-2013, 03:19 PM   #2
Plaka
Brevis illi vita est
Oddometer: 4,615
Yeah...don't.
It is held in by folded metal tabs on the inside. unfold the tabs and they break when you try to re-use them, .
Plaka screwed with this post 05-11-2013 at 03:26 PM
Old 05-11-2013, 04:01 PM   #3
JonnyCash
turd polisher
Oddometer: 1,652
I've done it twice on mine over the 20 years I've had it, and I'm sure I could never get away with a third time. If I ever have to take it out again, I'll need to come up with another way to hold it in there, maybe weld some other tabs. My headlight switch is a little funky, but I'm going to live with it until it just won't work any more before I pull it apart.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 05-11-2013, 04:31 PM   #4
Echolake OP
Echolake
Oddometer: 6
Thanks for the replies...I took a chance and unbent 'em. Fingers crossed when I reassemble.
Old 05-11-2013, 04:49 PM   #5
Kanticoy
Oddometer: 331
I just did that since the original switch in mine just spun with no purchase. I replaced it with the aftermarket switch from Rocky Point. Much happier with it and couldn't be easier to install.
Kanticoy is offline   Reply With Quote
Old 05-11-2013, 05:13 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,541
I'm on my third removal in 40 years-- I think that next time will be _it_. I'm toying around with the idea of making a thin metal sleeve to fit inside the one in the headlight bucket that will have small screws to attach the switch board with.
--Bill
'73 R60/5 Toaster
Old 05-11-2013, 05:26 PM   #7
Chad M
Custom User Title
Oddometer: 801
Those tabs can be annealed to remove the work hardening done by the twisting motion. I've heard of guys using a 12v battery to localize the heat.
Chad M is offline   Reply With Quote
Old 05-11-2013, 07:21 PM   #8
spo123
Man About Town
spo123's Avatar
Oddometer: 853
Cool2 Bingo!
First prize for Chad M!
HOWEVER> DO NOT remove that board assembly unless ABSOLUTELY necessary.
Ensure good, clean connections from underneath and use a clean and non residue forming ELECTRICAL cleaner....Sometimes the ARM needs to be REFORMED (bent) slightly for proper contact....Sometimes the POINTS are burned and need to be BURNISHED.....Yes, POINTS.
You will see.
Troubleshoot everything up to the SWITCH BOARD first.
Good Luck.
In the last 58,000 miles, I have not needed to remove mine...
See 'ya,
spo
spo
1973 /5 LWB Toaster
spo123 is offline   Reply With Quote
Old 05-11-2013, 07:51 PM   #9
Bill Harris
Oddometer: 8,541
And Duane Ausherman has a good section on the care & feeding of the /2/5 switch plate:
http://www.w6rec.com/duane/bmw/ignkeys/index.htm
and beau coup other information...
--Bill
'73 R60/5 Toaster
Old 05-12-2013, 08:11 AM   #10
Echolake OP
Echolake
Oddometer: 6
Great info!
Hey everyone, Thanks for taking the time to answer. I think that this is the first time for these ears so I may just get lucky. This is my first BMW. She sat in a warehouse for 14 Years and I'm having a blast getting her back on the road.
Times are GMT -7.   It's 03:37 PM.
