Old 05-12-2013, 04:26 AM   #1
stormsearcher OP
Oddometer: 976
how to load Topo maps on a garmin map62
I bought a map62 cheap without realizing the memory can't be expanded with a SD card.
I Want to load topo maps. when I tried it says does not have enough memory.1.71 g is available. any ideas from GPS gurus? This is my first Off road GPS.thanks
Don't tempt fate,TAUNT IT!
stormsearcher is offline   Reply With Quote
Old 05-12-2013, 07:47 AM   #2
250senuf
250senuf's Avatar
Oddometer: 2,315
Try sending a smaller selection of map segments (tile).
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 05-12-2013, 08:43 AM   #3
wbbnm
wbbnm's Avatar
Oddometer: 2,055
Yes you will only be able to load 1.7 GB of maps at any one time.
This is actually quite a lot.
In Mapsource when you are selecting maps to send to the unit, the program lists the maps under the map area in the left hand pane. It also tells how much memory you have used. So stop a little before 1.7g.
There is also probably a limitation on how many segments you can have. Try to keep it under 1000.
Once you are ready to send the maps hit the send to unit icon.
Then go find something else to do for several hours, especially if you used the whole 1.7 g.
But I would recommend starting small with just a few map segments to get the process down.
wbbnm is offline   Reply With Quote
Old 05-12-2013, 06:07 PM   #4
stormsearcher OP
Oddometer: 976
thanks
got a garmin topo maps SD card from the net.
or can i load my friends maps that have been created.(this is actually what i need)
dont need a map for established roads.
Old 05-12-2013, 08:18 PM   #5
Countdown
Oddometer: 5,323
Originally Posted by stormsearcher View Post
got a garmin topo maps SD card from the net..
Very few motorcycle rider hand held owners use Topo maps. There are just way too many lines on the small screen. OK for hiking or to consult when stopped on bike but for riding, R & R or City Nav are much more popular.
Jerry Counts
Countdown is offline   Reply With Quote
Old 05-13-2013, 04:27 AM   #6
stormsearcher OP
Oddometer: 976
Well here in oz my friends use the topo to ride off piste.follow the pink line is what they say.still learning the GPS ropes.
Old 05-13-2013, 03:54 PM   #7
Countdown
Oddometer: 5,323
Pink line sounds like a Route. Off highway more people use Tracks which you can set to any color and again topo lines make it very difficult to know a road intersection from crossing an elevation line. Give em all a try.
Jerry Counts
Old 05-13-2013, 05:15 PM   #8
250senuf
250senuf's Avatar
Oddometer: 2,315
Australia has topo (lines)??
Old 05-15-2013, 08:10 PM   #9
stormsearcher OP
Oddometer: 976
help pls
my friend loaded shonky australia topo on the GPSMAP62. It does notb seem to show up on the unit but it is there when i open the map files on the unit using the computer.
is there any trick to it being displayed? any suggestions please?
Old 05-15-2013, 09:43 PM   #10
250senuf
250senuf's Avatar
Oddometer: 2,315
Locked maps? But I'd expect that you would get a "notice" from the unit re locked.
Old 05-16-2013, 06:33 PM   #11
stormsearcher OP
Oddometer: 976
maps
its not locked. i cant seem to find it on the unit.
Old 05-16-2013, 07:30 PM   #12
Goosefeather
Captain Slow
Goosefeather's Avatar
Oddometer: 856
Look back at Post #3 and wbbnm's notes
Goosefeather is offline   Reply With Quote
Old 05-16-2013, 10:14 PM   #13
Countdown
Oddometer: 5,323
No one from east of Colorado ever complains!
Jerry Counts
Old 05-17-2013, 06:56 AM   #14
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
What's the name of the shonky file on the GPS?
How did your friend "load" it to the GPS. (Via Basecamp, Mapsource, etc)
I reckon the shonky maps are a good intro to a GPS. Not auto-routing, but not as messy as the Garmin Topo maps.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 05-18-2013, 08:53 AM   #15
stormsearcher OP
Oddometer: 976
When I connect the GPS to a computer I can open the files and see the shonky.but when I disconnect the GPS and switch it on I go to main menu - maps select I can see all the Original maps but can't see the shonky.I even disabled the others.but still no go.
My fend used an Mac which uses base camp. But base camp/ map source is for creating tracks from what I understand.
We look up a track on Google earth.mark it and load it onto the gps unit using base camp.
If I follow the arrow on the GPS it will get Me to the marked designation.the track might be redundant/ washed out but if the arrow is followed it will get us there.that's what we do in Australia.
HTML code is Off
Times are GMT -7.   It's 09:55 AM.
