Old 05-11-2013, 09:22 PM   #1891
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
Originally Posted by OhBoy View Post
The kit has only three of each size. Came close to needing four of the same. The Hot Cam Kit comes in .05 size steps. Could have used some mid sizes. Specs call for .08-.13. If your at the limits there isn't much wiggle room. I believe HD stocks every size. I may go with them next time. Meanwhile, I got lots of shims.
Pick a larger size and flat sand it to your exact spec.
Old 05-11-2013, 10:14 PM   #1892
k-moe
Oddometer: 2,870
No, don't. Shims are only case hardened; once that's worn through you're asking for trouble.
Shimming loose is better than shimming tight.
k-moe is online now   Reply With Quote
Old 05-12-2013, 07:11 AM   #1893
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,182
Sanding shims may or may not be a good solution.
My problems begin and end at not having a garage. I work in a condo parking lot. I am not comfortable leaving my engine open in a public parking lot while I go gallivanting around looking for the perfect size shims. Now, that I know more about what I need, I'll pickup a handful of shims ahead of time.
I had never been into the guts of this engine before and did not know the range of size shims I would be needing. I used 2-2.40 and a 2.45 and left in a 2.40 that was at .08 (the min).
Anyone need some bigger and smaller shims in the 1.85+ or 3.25- realm?
Start slow then easy off
OhBoy is online now   Reply With Quote
Old 05-12-2013, 07:17 AM   #1894
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
Shim under bucket, you can sand them all day long. Or my Strom with 35,000 miles on it has been asking for trouble for the last 20,000 miles.
Shim spot on, and quit your whining.
Old 05-12-2013, 09:37 AM   #1895
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
You needed a valve adjustment on your Wee with just 15k on the clock???
That is the lowest miles I have ever heard of a valve adjustment on a wee.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 05-12-2013, 09:42 AM   #1896
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
There were extenuating circumstances having to do with a leaky intake valve seal and a little bit of valve lapping.
But I also sanded my KLR shims, just was careful to install them sanded side down.
Boon Booni screwed with this post 05-12-2013 at 09:55 AM
Old 05-14-2013, 09:36 PM   #1897
ohgood
ohgood's Avatar
Oddometer: 2,998
I was just about to ask "doesn't anyone flat file anymore?"
Its not like a bike ever needs bigger shims...
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 05-18-2013, 04:58 PM   #1898
Tuna Helper
Rawrr!
Tuna Helper's Avatar
Oddometer: 766
Originally Posted by NJ-Brett View Post
They do have plenty of dealers, and some of the best help I ever got was at Harley dealerships.
I once had a guy dig out about 10 different sets of handlebars, and the ones I wanted were $25.00!
It just a shame they do not make anything new I would want to ride.
I should get an old sportster and make a general purpose dual sport out of it.
That would be loads of fun.
If I hadn't bought my Road Glide I would have bought one of these. I sat on it and it just felt right.
Originally Posted by dogjaw
I'm a bike slut, I love them all
Tuna Helper is offline   Reply With Quote
Old 05-18-2013, 05:30 PM   #1899
UnsureFooting
Title of User Here
UnsureFooting's Avatar
Oddometer: 6,386
I rode one at a demo day... it was very nice!
Because so much is riding on your tires.
UnsureFooting is online now   Reply With Quote
Old 05-19-2013, 09:00 AM   #1900
Zerk
DILLIGAF
Zerk's Avatar
Oddometer: 3,204
Is that a weld line on the gas tank? One thing Harley does extra the rest don't, is not have that line on the gas tank. Maybe it is just the picture.
Berserker
In my travelling heart, there's an urge to see
foreign lands and alien birds, hear stories that no ones heard-D.A.D.
Helmets are like rubbers, you know you should wear one, but its so much better when you don't-Me.
Zerk is offline   Reply With Quote
Old 05-19-2013, 11:25 AM   #1901
UnsureFooting
Title of User Here
Oddometer: 6,386
The white line? That's a reflection from the superior paint.
Old 05-19-2013, 12:58 PM   #1902
Zerk
DILLIGAF
Zerk's Avatar
Oddometer: 3,204
No. Above the front cylinder, by the frame. It likes a weld line like on the jap bikes. I wonder if Harley is cheaping out, or is it just the angle.
Berserker
Old 05-19-2013, 01:29 PM   #1903
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
yep, I am impressed. This has to be the best paint job from the factory ever. It is almost like glass, no orange peel that I can see. I watched a video and they said it is a 14 step process.
100mpg is offline   Reply With Quote
Old 05-19-2013, 10:51 PM   #1904
Mountain Cruiser
Oddometer: 1,204
No motorcycle manufacture does a better paint job than Harley Davidson.
Mountain Cruiser is offline   Reply With Quote
Old 05-19-2013, 11:00 PM   #1905
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
My current gold wing and previous ST1300 have amazing paint jobs. But this metal flake might have them beat. I would have to see one in person. and test ride it to make sure.
Times are GMT -7.   It's 01:14 PM.
