Thread Tools Search this Thread Rating: Thread Rating: 414 votes, 4.93 average. Display Modes
Old 05-12-2013, 05:44 PM   #7771
Chip Stevens
Oddometer: 118
I wish someone was looking over my shoulder. Talking with this forum is as close as I can get. chip
Chip Stevens is offline   Reply With Quote
Old 05-12-2013, 06:59 PM   #7772
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
You could share your desktop through a remote session. I used to do that a lot when I worked on the help desk at a community college. Even Garmin took over my desktop last Fall to help me sort out a map upgrade issue.
Old 05-12-2013, 07:22 PM   #7773
Chip Stevens
Oddometer: 118
Sounds good to me. Chip
Old 05-13-2013, 03:58 PM   #7774
TrotterD
Geek
TrotterD's Avatar
Oddometer: 17
Bug found that crashes device
Hello, hope you are well.
I wonder if anybody else can replicate the same device crash as me. Or if its just specific to my device. I have detailed model and firmware version but may happen to other devices and map/firmware versions.
Montana 650t.
Firmware version 4.9
Europe CNNT 2013.10
Worldwide DEM Basemap, NR
power on device
Open draw
Select track manager
Open archived tracks
Choose a track
Click elevation plot
Scroll to a point in the elevation, I chose the highest point.
Click the three bars at the bottom, then view map
When map displays, click three bars at the bottom and choose setup map
Choose select map
BOOM, flash of white and powers off.
I don't think this is by design. I have no need to do the above key sequences while viewing a track but it crashes every time.
If anyone else could test this to see if its a global device issue or just mind. I would appreciate it.
Regards
Dave
Look where you want to go, not where your going.
TrotterD is offline   Reply With Quote
Old 05-13-2013, 04:00 PM   #7775
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Montana 650t.
Europe CNNT 2013.10
power on device
Open draw
Choose a track
Choose select map
Regards
Dave
Please report to Garmin Software Team as outlined here.
If I, or two more users can duplicate this, I will add it to the bug list at the Montana wiki.
Crash #17 Added.
atlas cached screwed with this post 05-13-2013 at 04:39 PM
atlas cached is offline   Reply With Quote
Old 05-13-2013, 06:23 PM   #7776
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,469
Reset the Ommeter
I tried a search and not getting any info. Does anyone know How to reset the Total Ometer? I can reset the Trip Ometer but the Total is not reseting.
A '00 KLR 650 40,000 miles, A '07 1250S 74,000 , A '03 5.3L Chevy Truck 78,000 + '43 style dude , Simper Fi ;-)
achesley is offline   Reply With Quote
Old 05-13-2013, 06:54 PM   #7777
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Here is how but be very very careful
Select trip computer then the triple lined box at the bottom. Then select reset and " reset trip data"
DO NOT SELECT " Reset ALL Settings" like I did, this does the same as a master reset. It should not be there under trip computer, stupid frigging Garmin
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 05-13-2013, 06:56 PM   #7778
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Odometer reset requires a master reset of the gps unfortunately.
The info below is from the Garmin Montana Master Reset page.
Performing a master reset will reset all settings. While user data* are not likely to be erased, a backup of data is recommended; refer to the FAQ article "How do I back up user data from my outdoor GPS with a USB interface?" before performing the master reset.
To perform the master reset:
Power Montana off
Press and hold finger on upper left side of display (be done in portrait or landscape mode)
Power on device
Continue holding until the Do you really want to erase all user data? message appears
Release finger from upper left side of display
Touch Erase
Allow device up to 20 minutes to acquire satellite data with a clear view of sky
Old 05-13-2013, 07:02 PM   #7779
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
That won't reset the Odometer.
Here's another Garmin Help page on the subject.
"The Odometer data field will be an ongoing recording of all trips performed on device. This cannot be reset using the Reset Trip Data option. A master reset will be required to reset the Odometer. Click the appropriate link below for master reset instructions."
Old 05-13-2013, 09:23 PM   #7780
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,469
Thanks for the info on the reset. I was hoping for something else besides a master reset. But, looking like that's the only way to do it. I had already tried every thing else I've read on the matter.
Sheesh! I'm missing the 276C already.
Power Montana off
Power on device
Touch Erase
Old 05-14-2013, 03:01 AM   #7781
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
A reset on the Montana is far less disruptive than it would be on older gps units. Not much will change.
Old 05-14-2013, 07:22 AM   #7782
SteveAZ
SteveAZ's Avatar
Oddometer: 1,209
The greatest thing I miss about my 276 (vs. the Montana) are the routing tools, in particular searching POI's near a route and ability to manage multiple vias on-the-fly. I'm not sure why the Montana is limited to one via and why we can't search POI's near a route.
I'm continually hugely annoyed by not being able to do a "find" ("where-to") while map panning like *every* other POI unit I've had in the past. This bites me every day I use the unit.....
Other than those very annoying issues, there's not a lot about the 276 that were big improvements over the Montana IMO. The Montana takes too many presses to do a find....this really should be a menu item in the map page menu which would also deal with the horrible map panning "find" issue. I still like having buttons and think there is absolutely a place for them on GPS's, even those with touchscreens, but Apple has successfully shifted the paradigm on just about everything away from buttons.....although even the iPhone has more buttons than the Montana!
SteveAZ is offline   Reply With Quote
Old 05-14-2013, 07:30 PM   #7783
Chip Stevens
Oddometer: 118
SteveAZ
I have never had a 276 but I have a similar 496 in the dash of my airplane to back up my Garmin aviation stack. In addition to the thing you pointed out I miss a couple of other features with the Montana. 1) Routes I down load from BC can't be reversed. If I lay out the route on the Montana I can reverse it. 2) If I have a route lets say with 10 waypoints and part way through I want to skip a waypoint and go to one farther down in the list I can't. On the 496 I can go to the route list pick any waypoint and go to it.
Old 05-15-2013, 02:39 AM   #7784
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,469
Yes on wishing the Montana had buttons. With gloves, it is easy to just barely miss the + or - . I still have two 276's but only one working. I use it on the KLR for local roaming as it goes to 1.2 scale and still has max info. And ,. +/- buttons. Bought my first 176 in '95 and had been with that platform ever since.
I don't care for the Montana's drawn out search procedure for fuel station and motels.
But, with the 276 not even being able to be repaired by Garmin any more, may as well learn the Montana.
Old 05-15-2013, 02:45 AM   #7785
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 800
But you can set up shortcuts that will do these searches. I'm still learning my way through this thing but feel I'm getting better at it. It does have a steep learning curve...
FireDog45 is offline   Reply With Quote
Times are GMT -7.   It's 04:11 PM.
