Old 05-14-2013, 01:49 PM   #1
BadTA OP
BadTA's Avatar
Oddometer: 66
Clutch hard to turn
I am rebuilding my KTM 625 LC4 and am at the point where I am re-installing the clutch. I have put the clutch basket in and then the inner hub. At this point the inner hub turns freely. Now, when I tighten down the hex nut to the specified torque (60 ft.lbs.) the inner hub is now hard to turn.
Any thoughts?
BadTA screwed with this post 05-18-2013 at 12:44 PM
BadTA is offline   Reply With Quote
Old 05-14-2013, 04:42 PM   #2
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,218
Perhaps you're missing some sort of thrust washer behind the clutch hub/basket?
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 05-14-2013, 05:52 PM   #3
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,087
assuming the clutch parts list is the same as the 640, #28 seems to the thrust washer. or lack of. if that is the case, you have tighten the basket on to the thrust brg #32 and now that would be damaged...
or not
shipwrek12001 is online now   Reply With Quote
Old 05-14-2013, 09:30 PM   #4
BadTA OP
BadTA's Avatar
Oddometer: 66
I can confirm that there is indeed a washer (#28) and it does exist in my installation.
Any other thoughts?
Old 05-15-2013, 01:27 AM   #5
Captain115
Captain115's Avatar
Oddometer: 282
Any other thoughts?
Just to double check: you don't have any of the plates in right, its just the inner and outer baskets?
Captain115 is offline   Reply With Quote
Old 05-15-2013, 08:41 AM   #6
BadTA OP
BadTA's Avatar
Oddometer: 66
That's correct.
Old 05-16-2013, 10:10 PM   #7
BadTA OP
BadTA's Avatar
Oddometer: 66
I'm running out of ideas here. The inner hub turns freely until I tighten down the hex nut, then it becomes difficult to turn. I have gone over the service manual and the micro fiche. I can't find anything obvious.
Please help.
Old 05-17-2013, 10:05 AM   #8
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
Old or new parts?
If old, check if there is any markings witch way thrust washer was installed before rebuild.
Seikkailu_R is online now   Reply With Quote
Old 05-17-2013, 10:34 AM   #9
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,698
with or without the O ring on the inside of the plates?
wrk2surf is online now   Reply With Quote
Old 05-17-2013, 10:36 AM   #10
Seikkailu_R
Oddometer: 839
No plates, only inner and outer basket.
Old 05-17-2013, 12:28 PM   #11
BadTA OP
BadTA's Avatar
Oddometer: 66
The washer is original and shows no real differences on either side.
This is what I am dealing with. The outer hub sits on the collar/needle bearing, then the washer, next the inner hub goes on and then the hex nut.
From what I can gather, tightening the hex nut pushes against the washer which pushes against the collar which pushes against the bearing in the case.
So, where is the binding happening?
Old 05-17-2013, 12:48 PM   #12
Seikkailu_R
Oddometer: 839
Check that collar/needle bearing/washer combo without any other parts, is there enought room for bearing.
Some times these washers can be installed both ways when new, but after some use only one way works.
And all parts on main shaft bearing are ok?
Can kickstarters idler gear installed wrong side out?
Old 05-17-2013, 01:54 PM   #13
BadTA OP
BadTA's Avatar
Oddometer: 66
I have checked the idler gear. I tried it both ways. I will try the install as you mention later today.
Thank you for your help!
Old 05-17-2013, 07:00 PM   #14
BadTA OP
BadTA's Avatar
Oddometer: 66
Some more pictures. The local shop thinks there is something wrong within the transmission. A washer out of place or something. If I put the collar/needle bearing on, and just the inner basket, I can tighten the hex nut and the hub spins happily. It is only when I include the outer hub.
Old 05-18-2013, 07:38 AM   #15
Seikkailu_R
Oddometer: 839
No washer after roller bearing?
Times are GMT -7.   It's 11:33 PM.
