Old 04-19-2013, 11:43 PM   #241
Pete-NZ
Pete-NZ's Avatar
Oddometer: 737
Originally Posted by plodalong View Post
Looks good Pete, you must have one of the most modified xtr's around.
lets see....
Gillimoto 22.5L tank..
Metal Mule high 2 into 1 pipe..
Rekluse clutch...
Pivot pegs...
Braided brake lines...
Kev's fueling mods X2...
Showa USD forks , re-valved...
Steering damper...
320mm front wave rotor..
Rear wave rotor..
Rally Raid screen/fairing..
B&B bash plate..
Engine bars...
Soon to come..
Ohlins or Wilers rear shock... still trying to deside what one...
Dam I'm going to need a new bike soon... running out or things to do the the XTR...
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 04-19-2013, 11:51 PM   #242
motormail
Supermoto Posty
motormail's Avatar
Oddometer: 448
Originally Posted by Pete-NZ View Post
lets see....
Rekluse clutch...
Pivot pegs...
Steering damper...
Rear wave rotor..
B&B bash plate..
Engine bars...
Soon to come..
Hey Pete,
Got any photos with the rally raid screen?
thanks
Robo
motormail is offline   Reply With Quote
Old 04-20-2013, 12:01 AM   #243
Pete-NZ
Pete-NZ's Avatar
Oddometer: 737
Originally Posted by motormail View Post
Hey Pete,
thanks
Robo
not of my one... its 300km away at my place in blenheim....
but it's one of these ===> http://www.rallyraid.co.uk/shop/prod...?prod=RRXR650F
$180nz on my door step...
Old 04-24-2013, 04:11 AM   #244
DaleC
DaleC's Avatar
Location: London - Adv Motorcycle Capital of the World [sic]
Oddometer: 20
Luggage racks
Originally Posted by Whorepedo View Post
I did not know this thread existed until just now. I've had my 660R for a couple years now and love it. I think I'm the only one in the states unless theres another one lurking around.
What kind of luggage rack is that? I've looking for something like that but its next to impossible to find anything 660 related over here.
Whorepedo - apologies for the delay in responding, I'm in Morocco at the moment. However, Tod below nailed it.
Originally Posted by Süsser Tod View Post
It's a Metal Mule rack with Givi pannier racks.
The Givi pannier racks are cheap and fairly light at 3kg and I wouldn't want to hang anything serious from them. I use them simply to hold soft luggage away from the bike and for this purpose, they are OK, if not a bit too far from the bike making it unnecessarily wide. I have crash tested them a couple of times at low speed or in sand with no ill effects.
The rear luggage rack is Metal Mule and is doing it's job. I carried tyres (tires) from UK to Morocco (1,500k over 4 days) with a chunk of weight on the rack and it did the job OK.
Keyboard Adventurer
DaleC is offline   Reply With Quote
Old 05-15-2013, 12:53 PM   #245
thumpervibes
Oddometer: 6
My Project
Here is my XTX as it is now. Half way through retro/scrambler project:
thumpervibes is offline   Reply With Quote
Old 06-02-2013, 11:55 PM   #246
Pete-NZ
Pete-NZ's Avatar
Oddometer: 737
yet another peice of the jigsaw puzzle arrived the other day..
from OTR in Germany...
Ohlins S46DR1 sprung for a 70kg rider...
NOW if that guy would get my USD forks finished...
EDIT...........................
Bloody finally got the forks back.... now I can start the suspension rebuild..
forks have been re-valved , sprung , travel reduced.. I couldn't see much point in
forks with 300mm of travel on a bike with 250mm of ground clearance..
let the fun begin...
Pete-NZ screwed with this post 06-14-2013 at 07:42 PM
Old 09-05-2013, 03:58 AM   #247
motormail
Supermoto Posty
motormail's Avatar
Oddometer: 448
Hey Pete,
Any photos with all the gear on yet?
Old 09-05-2013, 10:42 PM   #248
Pete-NZ
Pete-NZ's Avatar
Oddometer: 737
Hey Pete,
I have been slacking off a wee bit.... have got this far
Old 09-13-2013, 04:51 PM   #249
Süsser Tod
Süsser Tod's Avatar
Oddometer: 999
The more I ride my XT660X the more I love her!
BUT I'm also convinced that when Yamaha engineers were desigining these bikes, they came up with the XT660X. Then they went to present the new bike and in a meeting they realized "this bike was supposed to be a dual sport", so they went back to the drawing board and 10 minutes later they came up with the XT660R.
The XT660X is brilliant for what it is, but the XT660R really needs lots of mods and then it ends up being better than the Tenere
Süsser Tod is online now   Reply With Quote
Old 09-13-2013, 07:20 PM   #250
Pete-NZ
Pete-NZ's Avatar
Oddometer: 737
I wish it was possable to get a few kgs off the bike...
but a lot of the XT's weight is in the motor..which is
why they are pretty bullet proof..
I have looked at cutting the rear sub frame off & building a
alloy one .. Theres a lot of heavy looking steel in the
XT sub frame.. that would also give the option to lower the seat..
Old 09-18-2013, 11:31 AM   #251
Crazydog
aka Andy660
Crazydog's Avatar
Oddometer: 20
Cush Drive Rubber Mod Fixed Finally !
Like all of us that have the XT660`s , the cush drive rubbers wear is a pain.
I found an article some time ago on the XT660.com thread.
The chain drive sprocket takes a tremendous load from the power of the engine , which causes the rear wheel bearing to wear excessively , even wearing the Chain Drive Hub Housing ,
The bearing will become loose in the housing at a later stage,
I fitted a double row bearing as apposed th the std single row bearing.
And with Polyurethane rubbers .I got 56 000km without changing the rubbers again.
You only have to machine the rear hub bearing housing 5mm deeper /
The Bearing I used is still the same dia. as the original.
And machine the inner spacer also 5mm shorter.
It stll uses the Standard Yamaha Seal
New bearing no. 62304
Crazydog screwed with this post 04-10-2014 at 10:56 AM
Crazydog is offline   Reply With Quote
Old 09-21-2013, 05:47 PM   #252
motormail
Supermoto Posty
motormail's Avatar
Oddometer: 448
Awesome mod Crazydog.
Thanks for sharing that one.
Any chance you can give us the bearing number?
Robo
Old 09-21-2013, 07:04 PM   #253
FLICKIT
FLICKIT's Avatar
Oddometer: 864
Robo
3205-2RS (25x52x20.6 mm)
Most bearing shops "should" have them.. .if not they're on ebay-au, about $22aus delivered from the UK...
http://www.ebay.com.au/itm/Double-Ro...-/200823601350
Some info from xt660.com:
http://www.xt660.com/showpost.php?p=169627&postcount=40
A few Dutch riders (I'm one of them) have modified the sprocket-carrier such that it can take either a double Yamaha bearing or a single wide BMW wheel
bearing, with good results.
Here's a link to some photo's showing the double Yamaha bearing solution: http://www.motor-forum.nl/forum/list...46525#21446525
This is the BMW part no. 36 31 2 310 972 (used in some BMW front wheels)
inner size is 25 mm
outer size is 52 mm
with 20,6 mm (5,6 mm more then standard and with double row bearingballs)
You'd have to make a new socket!
€32,-
It's actually a INA 3205-2RS F0712 or SKF 3205-2RS
like http://www.amazon.com/32052RS-Bearin.../dp/B002HARCP2
HJ
FLICKIT screwed with this post 09-21-2013 at 07:14 PM
FLICKIT is offline   Reply With Quote
Old 11-19-2013, 05:29 PM   #254
jdfowl
Oddometer: 27
output shaft seal dimensions
Anyone have the dimensions (OD, ID, width) handy for the seal hiding behind the front sprocket? I'm trying to bypass the Yamaha dealer...usd80 here in Brazil, and still not easy to get ahold of at that price.
Josh
jdfowl is offline   Reply With Quote
Old 11-27-2013, 09:05 AM   #255
morena67
morena67's Avatar
Oddometer: 65
Sorry, haven't seen any seal hidding behind the front sprocket... maybe a pic would help... or I'll take a good look at the bike later...
2005 YAMAHA XT660X
"My mouth was drier than an Egyptian’s sandal and my palms sweatier than a fat girl’s bra". Jamie Robinson.
morena67 is offline   Reply With Quote
Times are GMT -7.   It's 02:54 PM.
