Old 05-12-2013, 01:25 PM   #16
Gtrpcknman124 OP
Oddometer: 9
Whoopsies...I was forgot and put my CT 125 in, and I'm the one that specified 2-strokes and put it in the 2T forum to begin with Forgive me guys! Pretty nice bikes coming in here--I'm enjoying it
Gtrpcknman124 is offline   Reply With Quote
Old 05-15-2013, 02:14 PM   #17
Shocktower
Shocktower's Avatar
Oddometer: 9,479
Originally Posted by Gtrpcknman124 View Post
I forgot to post a pic of my little Honda! It goes well with yours. It's a '77 CT 125:
That is a 4 stroke
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 05-15-2013, 03:19 PM   #18
Highside>Lowside
Hairier Than Thou
Highside>Lowside's Avatar
Oddometer: 1,065
Originally Posted by Shocktower View Post
That is a 4 stroke
00 M944,95 620RXC,82 FT500,85 V65 Sabre,01 1150GS,82 XJ650r,91 XV920r,82 V50 Monza,77 TT500, R75/6, etc...
Highside>Lowside is offline   Reply With Quote
Old 05-15-2013, 05:50 PM   #19
bogieboy
bogieboy's Avatar
Oddometer: 880
heres my pair of play bikes.... an 01 ke100 and a 75 f11 250cc... that 250 needs jetting and suspension work, but once its up in the rpms, it PULLS...... its scary as heck with no damping in the shocks front or rear...
bogieboy is offline   Reply With Quote
Old 05-17-2013, 09:03 AM   #20
Grreatdog
Grreatdog's Avatar
Oddometer: 11,735
I retired my first helmet on an F11. They were not hurting for power. But I could have used some suspension landing that dune jump.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 05-17-2013, 10:22 AM   #21
bogieboy
bogieboy's Avatar
Oddometer: 880
Haha yeah they pull hard for a piston port 250, especially without a true expansion chamber.... I would be scared to see what it would do with some porting and a true chamber....
Old 05-19-2013, 12:06 PM   #22
Gtrpcknman124 OP
Oddometer: 9
Laugh
Those are sweet! Haha Shocktower, got me on that one! I plumb forgot myself. I can sort of relate to you Grreatdog--I was out checking cattle one day on that 1977 CT 125 and went past my little motocross track. I thought, "I wonder if..." And just being the spontaneous kid I am, got a good long run at a 25 foot tabletop in 4th, and landed it perfectly I remember hearing a "clack" front and back when I came down though, as I suppose I am a touch big to be doing such on that bike at 6' 6" and 200 lbs!!! Stupidly enough... this is 100% true
Old 05-20-2013, 07:41 AM   #23
freetors
Oddometer: 950
This is going to be mine when it's done http://advrider.com/forums/showthread.php?t=884627 It might be too nice to play on though
freetors is offline   Reply With Quote
Old 05-25-2013, 05:28 PM   #24
Seavoyage
Seavoyage's Avatar
Oddometer: 133
Explore an alternative reality for playbikes...
My putters to supplement a street plated GasGas EC300... less expensive to maintain and operate than a current MX bike, and actually significantly improve riding skills.
Based on jse comments, got the 2002 Pro chassis for the quicker steering and lighter magnesium engine cases. The chassis was only made for 1-year and is a odd mix of parts. Currently weighs just over 145 lbs. wet.
Complete rebuild of engine top and bottom end. Installed S3 225cc kit, S3 Stars cylinder head with interchangeable compression insert (currently running high-compression insert), and GasGas UK flywheel weight.
Revalved (2-stage compression and rebound) and changed spring rate on Sachs rear shock. Installed shock upside-down with 4mm preload.
Installed Formula 'Factory' forks (adjustable compression, rebound, preload, and end-stroke) with GasGas anodized Ergal triple clamps. Installed ProTaper Hi bend SE handlebars with ProTaper Medium compound grips.
Completed restoration of 1995 JT35. Approximately 170 lbs. with a 327cc Big-bore motor: tons of torque, and will lug at idle, out climb most dirt bikes, and traverse a 6-foot vertical obstacle in the right hands.
This bike may have an interesting histor if built by Jon Stoodley AKA jse for Steve Darrow for the World Championship. Had cylinder head mods, and Keihin PWK carburetor.
Originally Posted by jse
The JT35 with stock base gasket and stock timing is a beast to start isn't it? You better have committed cajones to kick start a JT35 (or JTR370)... my Keihin jetting seems spot on, so it isn't a question of if my JT35 will start on the 1st kick; it's if you can successfully kick start it.
If you aren't committed the JT35 will 'bite back' and either break your foot.or throw you over the handlebars.
Very linear power and more than enough torque to plow a field - just don't stall it while hill climbing.
I think the GG factory designed the GT35 and JTR370 like the Honda factory did with the old CR480/500. It's actually a competence test, if you can't start it, you shouldn't be riding it..... The 370 was quite interesting as it was a 338cc, high-compression engine but had "370cc" cast on the outside of the cylinder. I'm guessing the prototype was 370cc's so they kept the casting mold but they reduced the capacity after it totally flogged more than a few test riders...
I'm trying to remember if Steve rode that bike at the World Round at Donner, he may have. He was mechanically inclined and took extremely good care of his bikes. Steve was a big guy (an Assistant Chief fireman and in good shape) and he had a hard time lightling that bike off so he asked me to make some changes. I re-machined the combustion chamber, which really helped, and he said it was a lot easier to start and ran smoother with no loss of power.
I agree, the 35 and 370 did not reward the timid. Like Steve's 35 and my 370, they were great bikes for Donner at 8200 ft. altitude and we never had a problem with power loss. My 370 was stolen years ago and disappreared completely. Few of them were ever imported here and they are quite rare (if you see one, look for the "JSE" engraved on the cylinder and lots of one-off special parts). I told the investigating Sheriff deputy taking the report to look for a criminal with a broken right kneecap.......
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter. -Ernest Hemingway
Seavoyage screwed with this post 05-27-2013 at 09:45 AM
Seavoyage is offline   Reply With Quote
Old 05-25-2013, 05:58 PM   #25
bogieboy
bogieboy's Avatar
Oddometer: 880
Very nice! My 100 only weights 185 wet....LOL now if only it had a bigger engine, vintage style trials bike? LOL
Old 05-26-2013, 08:01 AM   #26
Seavoyage
Seavoyage's Avatar
Oddometer: 133
One of the inmates, hmb, had a 234 lbs. CRF150F which she had difficulty picking up if dropped on a nasty single track or gnarly terrain.
We introduced her to Trials, and found her a 150 lbs. Sherco ST2.0 (2-stroke) from another inmate that was much less expensive than her CRF150F. http://advrider.com/forums/showpost....6&postcount=16 Once she realized the huge advances in performance and how much her riding skills improved; I don't think she's ever going back to the 'play bikes' offered to the mainstream.
Seavoyage screwed with this post 05-26-2013 at 08:53 PM
Old 05-26-2013, 10:09 AM   #27
bogieboy
bogieboy's Avatar
Oddometer: 880
Originally Posted by Seavoyage View Post
On of the inmates, hmb, had a 234 lbs. CRF150F which she had difficulty picking up if dropped on a nasty single track or gnarly terrain.
We introduced her to Trials, and found her a 150 lbs. Sherco ST2.0 (2-stroke) that was much less expensive than a CRF150F. http://advrider.com/forums/showpost....6&postcount=16 Once she realized the huge advances in performance and how much her riding skills improved; I don't think she's ever gong back to the 'play bikes' offered to the mainstream.
I would love to have a trials bike, but my degenerative disk desease wont let me... I need to be able to sit sometimes...
Old 05-27-2013, 11:14 AM   #28
dpforth
no inline fours
dpforth's Avatar
Oddometer: 325
There may be solutions for you, like this or this.
Trials bikes are awesome playbikes, unless of course you feel the speed. Even then, 5th or 6th gear can get you moving along.
This species has amused itself to death
dpforth is offline   Reply With Quote
Old 06-02-2013, 05:47 PM   #29
Valvesarefortoilets
Oddometer: 77
[QUOTE=Seavoyage;21492215]Explore an alternative reality for playbikes...
Those trials bikes are nice! I can why Monster energy sponsors the guy fred!
Valvesarefortoilets is offline   Reply With Quote
Old 06-02-2013, 05:54 PM   #30
Valvesarefortoilets
Oddometer: 77
Me and My Pops' Playbikes! Im the proud owner of the 87 KDX200 and pops is on the good ol' 76 hercules 175GS 7 speed!
Both bikes are no garage queens and both have their share of dents (one more than the other ) including some replacement triple trees for the herc!
Times are GMT -7.   It's 10:22 PM.
