Old 05-12-2013, 08:51 AM   #1
Stephen Daudelin OP
Oddometer: 19
Backfiring On Front Cylinder
HELP!!!! My 2006 950 Adventure is backfiring on the front cylinder! It was running fine when I put it away for the winter and now this. I took the carbs off and sprayed carb cleaner in them, changed the very dirty spark plugs, put it back together. When it started, it was running great for a few minutes with full compression coming out of both exhausts. Then it started popping and backfiring again on the front cylinder. You can see flames in the carb. Any ideas what it could be and what should I check????
Is it the valves?? An air leak?? Or what??
Stephen Daudelin is offline   Reply With Quote
Old 05-12-2013, 09:02 AM   #2
Katoom72
Katoom72's Avatar
Oddometer: 912
Excessive lean condition? Check airleaks and fuel
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 05-12-2013, 09:10 AM   #3
DirtyADV
DirtyADV's Avatar
Oddometer: 2,377
Only time I have had flames come back up the carb one of the choke cables was not seated fully.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 05-12-2013, 09:34 PM   #4
skianreid
Boulder Moto
Oddometer: 108
Check to see if the O2 screw in the pipe fell out.
"get outside have some fun and enjoy the backcountry"
skianreid is offline   Reply With Quote
Old 05-13-2013, 09:31 AM   #5
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,061
Maybe the coil is breaking down, is it heat related?
Other thing to check is spark plug to make sure no losse carbon found its way back into the gap post cleaning?
The only other obvious may be check the top of the coil connections to make sure they are not loose.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 05-13-2013, 11:56 AM   #6
v303x
Oddometer: 135
Clogged pilot jet? Take the pilots off and use a strand of copper from a piece of cable to clean it. Spray them with carb cleaner and blow them dry with compressed air.
Better yet get new ones.
Cheers,
David
v303x is offline   Reply With Quote
Old 05-13-2013, 05:08 PM   #7
Racer111v
Racer111v's Avatar
Oddometer: 862
I had the same problem with my new to me bike. The threaded tip of the spark was corroded (rusted) where it connects into the coil. The temperary fix was to clean up the end with some sandpaper and cover it with some dielectric grease. Then I bought new plugs and a used coil off Ebay. Of course I did all the carb stuff before I pulled the plugs.
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is offline   Reply With Quote
Old 05-13-2013, 06:55 PM   #8
Stephen Daudelin OP
Oddometer: 19
Thanks Gents!
I currently have new plugs, I've cleaned the carbs and jets.
Where is the O2 screw? It only occurs once it's warmed up. It runs fine when cold. It's certainly running lean.
Old 05-13-2013, 06:59 PM   #9
Stephen Daudelin OP
Oddometer: 19
It's only got 20,000kms on it too.
Old 05-13-2013, 07:12 PM   #10
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,382
If the plug thing does not turn out to be the issue you need to pull the jets out of the carbs and clean them. This has happened to me a number of times over the years and I pull all of them and clean them while I have the carbs off.
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 05-13-2013, 07:13 PM   #11
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,149
I would bet that you have a vacuum leak on the front cylinder. Maybe a cracked boot. Maybe you didn't get the carb all the way into the boot. Maybe you have a vacuum line that is loose. I had this for many days and just couldn't figure out what was wrong, and then I found that one of the vacuum plugs I'd put on was blown off. That causes a super lean condition on one cylinder, and it will backfire into that one carb all day long. I'd put money on a vacuum leak.
Orangecicle is online now   Reply With Quote
Old 05-13-2013, 07:36 PM   #12
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,061
You can buy a new tube of vacuum but make sure it is black
norsesweger (Tobi) had an issue with a cracked manifold boot per Orangecicle but that is a fair way in so simple stuff first.
Old 05-14-2013, 11:25 PM   #13
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 595
I had this on my 950. Twas a coil. Fine when cold, then missfire comes as it gets hot. Swap them around and see if it moves to the other cyl.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 05-15-2013, 07:10 PM   #14
Stephen Daudelin OP
Oddometer: 19
Thanks for all your help Gents! I will try to see if I have an air leak first. One thing I forgot to mention was that I installed new Leo Vince pipes two years ago. It ran fine until now with this issue.
Times are GMT -7.   It's 05:12 AM.
