Old 05-12-2013, 02:44 PM   #4756
xaman
Oddometer: 528
Thanks for the detailed pics!
I love your graphics, where did you find those?
xaman is offline   Reply With Quote
Old 05-12-2013, 03:25 PM   #4757
Tomdog
Mapaholic
Tomdog's Avatar
Oddometer: 338
Pre filter
Quote
In my opinion, the pre filter kit should come with a properly sized aluminum cover instead of that crappy plastic one. Maybe I'll fab one out of a alloy sheet some day
Thats what I did to get a good fitting pre filter.
Also be carefull when tightenening those three holding down srews. I dosn't take much force for those metal thread inserts (air box) to "let go".
07 X-Challenge--Sadly Sold
To the Dark side soon
Tomdog is offline   Reply With Quote
Old 05-13-2013, 02:49 PM   #4758
The Jester
The Jester's Avatar
Oddometer: 834
Originally Posted by jabroka View Post
You just reminded me.
As well as the TT tank and Scheffelmeier case saver I have advertised in the flea market, I also have a 10% oversize injector in the shed. PM an offer if you can use it.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 05-14-2013, 01:55 AM   #4759
SR6
XR's rule!
Oddometer: 35
Originally Posted by Tomdog View Post
Quote
I'll let you know on Friday arvo if you need to make two....
'07 G650X Challenge (2013-TBA)
'96 XR600R (2012)
'03 XR400R (06-For ever!)
'98 XR650L (00-01); '99 DR350S (99-00); '96 DR650SE (96-00); '89 DR250S (92-96)
SR6 is offline   Reply With Quote
Old 05-14-2013, 04:37 AM   #4760
Tomdog
Mapaholic
Tomdog's Avatar
Oddometer: 338
Hopefully we can welcome you into the fold, S___
Old 05-15-2013, 01:01 PM   #4761
Noillek
Nomada Portugues
Noillek's Avatar
Oddometer: 24
Hi,
Begining this year I bought and started to modify a very interesting Xmoto to be prepared for some trips in mind for this year.
Most of the information I'm getting from this forum so I taught that it was about time to show off and thank you all for the knowledge sharing.
Here goes some pics of my project bike... adventurization in process, rayz seat booked and a visit to hotwelding planed for some frame adaptation and front strut.
Using as template the ktm smt... I should make an interesting G650X for travelling.
By the way even with road tyres is a very easy bike to take off-road, no mud yet
Cheers
Sent from my GT-N7000 using Tapatalk 2
Noillek is offline   Reply With Quote
Old 05-15-2013, 04:21 PM   #4762
xaman
Oddometer: 528
Originally Posted by Noillek View Post
Hi,
Cheers
Congrats on a great bike.
Looking forward to watching your transformation progress!
Old 05-15-2013, 09:17 PM   #4763
Lotus1967
NorCalxPlant
Oddometer: 12
Bluhduh MPG- Gas Tank
So... hey there to all... this forum was instrumental in my purchase...
one thing, it seems my MPG has dropped from 60 to around 50...and that whenever my fuel indicator goes off, I no longer actually have the 0.5 gallon reserve...
this change happened several months ago, after I got caught being mesmerized by the rolling golden hills of West Sonoma County and drove off the damned road...
it killed the left plastic and the radiator was mauled...
ANY ideas would be muchly muchly appreciated...
Lotus1967 is offline   Reply With Quote
Old 05-15-2013, 09:28 PM   #4764
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
Check to see if your front brake is staying on while you're riding.
tbarstow is offline   Reply With Quote
Old 05-15-2013, 09:37 PM   #4765
Lotus1967
NorCalxPlant
Oddometer: 12
Thumbs down
will do...
am thinking also, somethig is up since whenever I refuel, it's NEVER more than 2.1 gallons.
capacity is sposed to be 2.6..
BTW, the thumbs down isn't directed at the response... just my fuel system...
Lotus1967 screwed with this post 05-15-2013 at 11:18 PM
Old 05-16-2013, 06:46 AM   #4766
slide
A nation in despair
Oddometer: 21,122
I have noted, over the life of my bike, a decrease in mpg going from a solid 75 to a current 68. I attribute it to more ethanol in the fuel.
Anybody else seeing similar? I don't think that's the cause of the guy you are responding to but it got me to remembering what I used to get mpg-wise.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 05-16-2013, 08:13 AM   #4767
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
will do...
75 & 68 mpg? Are you standing next to the bike and pushing it? Maybe pulling it behind a bicycle? Keep in mind that since the speedometer reads 10% high, so does your odometer.
The switch to summer gas blends will beat up your mileage, as well as running the crap California gas.
Old 05-16-2013, 08:47 AM   #4768
slide
A nation in despair
Oddometer: 21,122
Back in 07 when this was new, others reported similar mpg from theirs. Remember, mine is a Co which may make a diff.
As to speedo / odo, the info I have is that the TUV is so strict that BMW calibrate their speedos to read no less than the actual speed no matter what tire used meaning they calibrate about 10% high for stock tires. The odos are supposed to be spot on. I checked and confirmed this with the GS but not with the X.
Anyway, my readings of mpg are from the uncorrected odo.
Old 05-16-2013, 06:32 PM   #4769
xaman
Oddometer: 528
Forgive the newb question, but:
I'm looking at my rear brakes pads, after:
1.) my ABS light has been inconsistent lately. sometimes it stays lit, sometimes it is normal.
2.) it also seems like my rear brakes haven't been as grippy of late.
I was looking for the typical pad wear lines or grooves, and the front pads have them plain as day, but this is what I see in the back:
Out side:
In side:
The out side looks a little boogered up, chipped on the corner. Is this ok, anything to worry about?
Should I be seeing wear lines, or is this a different kind of pad?
BTW, bike is a 2007 xmoto, put in service in 09, has 6700 miles on it.
Old 05-17-2013, 06:49 AM   #4770
jabroka
jabroka's Avatar
Oddometer: 338
Its custom painted, I bought it that way from a friend. The bike also had the ohlins shock, excel rims, leo vince exhaust and some random TT stuff when I got it..
26k km on the oddo
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Times are GMT -7.   It's 08:04 PM.
