Old 05-12-2013, 08:41 AM   #121
RsZk
RsZk's Avatar
Oddometer: 173
Originally Posted by CottonTop View Post
Wanna, the GIVI plate reuses the black plastic base that comes with the S-10. It takes the place of the plastic (silver) plate that comes on the bike and is almost twice the size. It has its own hardware and one extra bolt / support at the rear to give it more strength. The stock bolt you have to take out for the rear support has threadlock on it so you will need a 5mm hex socket and ratchet - or something of the sort. Or, you could try heating it up to soften the threadlock.
Just a heads up then CottonTop, we had a guy with a similar system where the rear tail piece OEM totally failed with his top box, as his mounting system resided on the OEM piece. At a dualsport rally he hit some frost heaves and pot holes and the whole box flew off the bike. I'm not sure if you go off-road with your Super T, but if you do be aware of this, especially if the box is loaded.
There are some vendors who sell a total replacement tail piece which is made from aluminum. I replaced mine with the Jesse tail piece which bolts directly to the frame of the bike. From there you could use any system such as your Givi mounting bracket. Here is a pic:
Cheers,
2013 ride report:http://advrider.com/forums/showthread.php?t=898211
2012 KLR 650, 2015 FJ 09
RsZk is offline   Reply With Quote
Old 05-12-2013, 04:29 PM   #122
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,404
Cheers,
Yamaha updated the original rack after a couple failures offroad in SA. Did your friend have this update (the new rack had a steel reinforcement rod in its base)?
twinrider is offline   Reply With Quote
Old 05-12-2013, 05:41 PM   #123
RsZk
RsZk's Avatar
Oddometer: 173
Good question. I am not sure about that. I will have to ask.
Old 05-15-2013, 07:09 PM   #124
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
The Kappa 33 l case came in. Wow - the is a nice piece. It mounts to the GIVI monokey system without issue. I like...
May 2013 070
May 2013 072
Super Tenere
CottonTop is offline   Reply With Quote
Old 05-15-2013, 08:32 PM   #125
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,947
Just got my ECU back with the 2nd gen update. Bolt on all the shit you want, but if you want your
bike to run like it deserves it the reflash is my #1 farkle recommendation.
pluric is online now   Reply With Quote
Old 05-16-2013, 06:50 AM   #126
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I have the updated stock rack with the metal brace and still plan on upgrading. My top box flops around, even empty.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 05-16-2013, 07:34 AM   #127
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,947
Originally I had mounted an alloy plate to my stock rack. The rack cracked.
I've since moved on to Altrider stuff. I like the cubby hole under the rack for
tire repair kit storage. Sturdy rack too.
Old 05-16-2013, 10:47 AM   #128
GatSS
Canadian eh
GatSS's Avatar
Oddometer: 284
Altrider
+1 on the Altrider rack. I have a Pelican case mounted on mine and it's rock solid. I also have their crash bars.
I think the ECU flash is next!
Mat
2012 Super Tenere
2002 XR400R - plated
2009 CRF50
GatSS is offline   Reply With Quote
Old 05-16-2013, 04:51 PM   #129
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,404
I upgraded to Givi's SR371 rack so I can run my E45 top box. Quality piece of kit at a very reasonable price.
Old 05-16-2013, 04:58 PM   #130
Red Dust
Oddometer: 463
Agree with the Altrider rack, believe even if I one day would go over a cliff or similar it still would be intact on the back with all the gear. Very, very good rack!
Red Dust is offline   Reply With Quote
Old 06-03-2013, 06:42 PM   #131
CottonTop OP
Rider
CottonTop's Avatar
Oddometer: 60
Originally Posted by RocketJohn View Post
I agree... and its fun... but one must be cognizant of the fact you can add material weight gains by bolting on too much stuff.
I added a couple of items over the weekend:
Altrider.com's side stand foot and the Pivot Pegs (MK3), both nice addons, especially for my size 12 boot.
I dig the pegs... Did quite a bit of forest service road riding a couple weekends ago. Really wanted a foot peg with a larger surface area and better bite. Anyone else got options?
Super Tenere
Old 06-04-2013, 06:22 PM   #132
RideDualSport.com
TPB all the way
RideDualSport.com's Avatar
Oddometer: 1,585
1. Safety Farkle, Admore Light bar. It does not prevent being rear-ended by a texting driver, but it does express my inner nerd.
2. The Awesome "Cup Holer" (available from JC Whitney Extreme ADV, and select 7-11 stores).
Staying hydrated while World Crossing the Outer Mongolian Desert never looked so cool.
3. nah... no more farkles. I think I will just turn the Super Tenere into a World Crosser Bobber Chopper Old Skool Sled.
"... I lock my rear up at least once every time I throw a leg over a bike."
The RideDualSport Forum
Mountain State Super Tenere Adventure
Alaska Deep Adventure
RideDualSport.com is offline   Reply With Quote
Old 06-09-2013, 02:04 PM   #133
Vbird
In Room 237
Vbird's Avatar
Oddometer: 784
Cheapest and easiest mod so far. Couldn't stand the glare of the silver anymore.
Vbird is offline   Reply With Quote
Old 09-04-2013, 04:19 PM   #134
Blue Mule
Persistent Slacker
Blue Mule's Avatar
Oddometer: 2,285
bump....
"The universe is wider than our views of it." - Henry David Thoreau
Blue Mule is offline   Reply With Quote
Old 09-05-2013, 10:19 AM   #135
RideDualSport.com
TPB all the way
Oddometer: 1,585
Other than my dorky light bar, no other modson my Super Canary.
I don't understand why I am even riding it, the bike is just so horrible without mods.
I heard the Rusty Nail mod to the factory ECU does wonders though...might take a hack saw to the frame and make a bobber out of it.
Just got back from here:
Times are GMT -7.   It's 09:53 PM.
