Old 05-01-2013, 05:01 AM   #241
CNRED
It'll be OK
Oddometer: 621
Originally Posted by DirtbagHB View Post
I have an 08 230L that i got used (242 miles, now 4000). it is now my turn to change my rear brake pas and the ones I ordered off the interwebs are too thick, though it is possible that im not depressing the brake caliper piston enough, its depresses easily with a screwdriver and feels like it bottoms out. tried to make it go that last bit with a c-clap to no avail. so my question is: when yall go to change pads, how far should the piston depress. should it be flush or does ~1/8-1/16 of an inch of the piston remain exposed.
http://www.sixity.com/2008-2011-hond...f230l-f-r.html
these are the pads i got, should fit, but dont. i need mere hairs for clearance.
what am i forgetting or did i just end up getting brakes that dont work like a doof
thanks to whom ever responds for your input
Looks like you ordered the right pads to me.
I've yet to change pads on my 230, but I've done a few others. Try opening the bleder while compressing the caliper piston. A small amount of brake fluid will be lost but can be refilled after the job is done. This should get you the room needed to get the pads in and over the disk. The piston should go almost flush with the caliper body. Becareful not to compress it too far or it may slip past the top piston seal.
2011 WR250r
2007 BMW f650GS
1988 Honda NX650 - X2
1982 Honda GL1100 - X2
CNRED is offline   Reply With Quote
Old 05-01-2013, 07:51 AM   #242
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 533
Actually, this is a good chance to put in fresh brake fluid after changing the brake pads.
I did my rears (totally used up) at 8800 miles. As you know, the small pads go in the rear.
I installed speed bleeders the first time that I replaced the brake fluid, that makes it a bit simpler. (SB8125L M8 x 1.25 <-- same bleeder front and back).
The front pads were still good, but, I replaced them at the same time simply as a precaution.
John
2009 Honda CRF230L (L'il Red Piglet)
2014 Honda CB500XA (Daily Rider)
jsonder is offline   Reply With Quote
Old 05-16-2013, 12:35 AM   #243
Chuck289
Air cooled
Chuck289's Avatar
Oddometer: 2,273
Haven't been in here for a while, Been almost 5 years with this bike
-Charles
"This is an environment of welcoming, and you should just get the hell out of here" - Michael Scott
Chuck289 is offline   Reply With Quote
Old 05-16-2013, 06:22 AM   #244
dankatz
Oddometer: 352
nice pic!
Beautiful picture! What tires do you use?
On another note, any easy/simple/inexpensive modifications to boost power a little? Not looking for anything earth shattering...if I can get another 2 hp would be ecstatic!
dankatz is offline   Reply With Quote
Old 05-16-2013, 12:27 PM   #245
Chuck289
Air cooled
Chuck289's Avatar
Oddometer: 2,273
Thanks. Those are Michellin T63's
-Charles
Old 05-17-2013, 01:17 PM   #246
mb300
mb300's Avatar
Oddometer: 68
Dunlop D803 Trials Tire WILL fit, just barely
FYI you CAN put a D803 trials tire onto the 230L.
The only two gear ratios that I KNOW will work are 13/48 (106 links) and 13/51 (108 links).
13/46 won't fit
13/47 - unknown didn't have one
13/48 FITS, but the rear tire barely clears the mud flap
13/49 won't fit
13/50 won't fit
13/51 FITS, but the axle is at the very back of the swingarm slot with only 1 or 2 adjustments left for chain wear on the snail adjustors.
13/52 - unknown didn't have one
Hope this helps.
mb300 is offline   Reply With Quote
Old 05-17-2013, 04:06 PM   #247
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 533
The pic is stock drive sprocket and a 48-tooth rear, wearing Dunlop 606 tires.
http://advrider.com/forums/showpost....&postcount=236
John
Old 05-18-2013, 05:24 AM   #248
CNRED
It'll be OK
Oddometer: 621
[QUOTE=Chuck289;21419601]Haven't been in here for a while, Been almost 5 years with this bike
5 years with one bike is quite a stretch. They are excellent bikes fun to ride and durable.
Have you or anyone else on this thread found a suitable replacement for the stock air filter. My Honda dealer tells me the stock filter is not serviceable and has to be replaced rather then cleaned.
Had anyone tried to service the stock filter or is everyone just popping for the Honda replacement each time it gets dirty?
2011 WR250r
2007 BMW f650GS
Old 05-18-2013, 09:46 AM   #249
grnd0
Oddometer: 136
You can just cut the paper element out of the stock
cage and get some uni bulk foam, cut to fit, and
then run some wire over to hold in place. Very
easy job. I think I got the green and red. Fine
close to motor, course out.
http://www.motorcycle-superstore.com...lter-Foam.aspx
grnd0 is offline   Reply With Quote
Old 05-18-2013, 10:57 AM   #250
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 533
I do a lot of solo trail riding. New filters can be purchased for under $20 from some online sources. I just figure that it's better engine protection to buy a bunch of OEM filters and change them with each valve clearance check. For my use, they aren't too dirty after 4K miles.
John
Old 05-20-2013, 12:56 PM   #251
mb300
mb300's Avatar
Oddometer: 68
$10.73 w/free shipping at Amazon
search "Uni Green Fine Foam" at Amazon
$10.73 free shipping
Old 05-25-2013, 04:24 AM   #252
v30
Oddometer: 1
Hi folks,
New crf230l owner here. Picked up a 2011 with 645 miles on it about a month ago. Great little bike that I use about 80% trails. I have it on the highway occasionally and with my 225lb frame and with a hill or headwind, its definitely underpowered but that's ok, since I ride the highway for only very short stints to get to or from a trail. Love how lightweight this thing is. No problem to pull it out of the mud or turn it around on the tightest trails. Really impressed with the gas milage too. Getting about 118 miles on the tank before hitting reserve. The only things I'm planning on doing to it is getting rid of the stock trailwing tires and putting a set of kenda 760's on it......and I'm going to try a 14 tooth front sprocket to see if it lowers the revs a bit at high speed and makes 1st gear a bit longer. Here's a few pics:
v30 screwed with this post 05-25-2013 at 04:42 AM
v30 is offline   Reply With Quote
Old 05-25-2013, 07:19 PM   #253
grubbie
grubbie's Avatar
Oddometer: 144
I Love the T63s,....I run them on my WRR. The wife hasnt worn out the trail wings on the crf yet, when she does it will have T63s as well.
2008 CRF230L, 2010 WR250R, 2011 HD Streetglide, 2015 Suzuki DR650
grubbie is offline   Reply With Quote
Old 05-26-2013, 02:37 PM   #254
Jon
Jon's Avatar
Oddometer: 1,291
As of this afternoon I have joined the 230L club. I picked up a good condition '08 with 5,700 miles on it. So far I am impressed with it after the 50 mile ride home. It is smooth, shifts well, is amazingly light, and cruises nicely at 55 mph. Why did I go 230? My girlfriend will be getting her license soon to tag along with me and I wanted something affordable, reliable, and with a low seat height. I think this hits all the marks. Hopefully, I can positively contribute a bit to this thread.
Jon is online now   Reply With Quote
Old 05-26-2013, 03:20 PM   #255
dankatz
Oddometer: 352
Out of curiosity, I have 3100 miles on the original tired on my 2009. Mostly asphalt I suspect. I am thinking it is probably time to switch tires, but can't tell on the knobby's when it is time. How much do people typically get out of the original Trailwings 27/30?
Times are GMT -7.   It's 11:18 AM.
