Old 05-15-2013, 09:20 AM   #15871
MrPulldown
MrPulldown's Avatar
Oddometer: 3,509
Originally Posted by MattR302 View Post
So over the weekend, I picked up a spare set of wheels for my 98 SE. These will be for dirt tires, my current wheels will have street tires.
My current sprocket & chain setup for my street tires is 15F/41R with a 108-link chain, these have only ~1000 miles on them. I'm going to buy a new rear sprocket for the dirt wheels.
Does anyone have any idea how many teeth I can go up to on the rear sprocket while keeping the 15 tooth front and 108-link chain?
Thanks in advance!
I have a 13, 14, 15 for front sprocket to chose from and a 41, 43 in the back. I can run all combos with the same chain, though 15,43 is pretty tight, If you want to keep the smae chain I would suggest not going past a 43, maybe a 44. Then you can drop the front sprocket down to make up for the length requiremnt.
MrPulldown is offline   Reply With Quote
Old 05-15-2013, 09:47 AM   #15872
Nortonbrian
Oddometer: 41
Originally Posted by daverbmxer View Post
I have a pretty new to me DR that I'm trying to get the clutch adjustment right on. When I first got it, it didn't seem to shift all that smoothly, especially the 1-2 shift. I got it better by taking out a bit of the free play in the lever, but if I rush the shift I still feel a bit of a "catch".. more clunk than I would like. So today I removed a bit more free play in the lever, but I am fairly sure I got it to slip a couple times, but coasting and going full throttle in 3rd or 4th gear. It did seem to shift a bit smoother then, but like I said, I think it slipped a bit. So I dialed it back to where I was before.. no slip, but not the smoothest shifts. Is there a lever that has more of a bow to it that allows for a longer pull? What is the proper thing to do in this situation? I really hope that my transmission is not buggered and I hope the clutch plates don't need replacing. I looked through the Clymer manual and I did not see reference to the angle of the clutch lever on the splines (the one on top of the case). On mine, it forms a 90* angle with the cable when the clutch is pulled. Should it be 90* then, or when the clutch is at rest (engaged)?
Rule of thumb on any cable operated arm, be it clutch or drum brake is that the angle between the arm and cable should never exceed 90 degrees. So when the clutch lever is pulled in the operating arm should be at 90 degrees or less, this will give the most efficient operation. If you take out free play at the clutch lever you will damage the release bearing and induce clutch slip. The DR clutch is not too bad, try a Triumph some time!
Nortonbrian is offline   Reply With Quote
Old 05-15-2013, 01:47 PM   #15873
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,353
Originally Posted by 8lives View Post
I went 1 tooth up on my 97 350 and it made the freeway good,and front sprockets are easy to change.
+1 Changing the front sprocket is the way to go. No need to change your chain and you can carry a different size for the trail and throw it on in 20mins.
Anonawesome is offline   Reply With Quote
Old 05-15-2013, 07:43 PM   #15874
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 480
Originally Posted by motolab View Post
Think the spec for fuel level is 1.5mm above the gasket surface, which should be obtainable with a 14.7mm float height.
Why am I thinking it is supposed to be 1.5mm under the gasket surface? I'm almost positive I read that in a few places.
jackanory is online now   Reply With Quote
Old 05-15-2013, 07:58 PM   #15875
motolab
motolab's Avatar
Oddometer: 2,845
I have only ever seen 1.5 above.
Regards,
Derek
motolab is offline   Reply With Quote
Old 05-15-2013, 08:54 PM   #15876
trippda
trippda's Avatar
Oddometer: 55
Originally Posted by Crenshaw View Post
+2. Not only that but the chain always bounces around a ton with no load on it. Have you actually tried riding it?
Is your chain extra long or stretched? Doesn't look like you have any adjustment left on the eccentrics...
I had it too tight in the pic. And with no load on it, it was jumpy like you suggested. Two clicks looser, and sat down vroom vroom!
PS
I am paranoid. and my other bike is a shafty
Get busy living, or get busy dying
'96 - DR350 -'04 Sherpa
trippda is offline   Reply With Quote
Old 05-16-2013, 01:30 AM   #15877
Anonawesome
Scenic Rider
Oddometer: 1,353
There's pretty much no situation that the float level needs to be adjusted. I've heard a lot of people give this as advice but the metal tab is not really something that's meant to be adjusted. Unless you're really convinced that the PO did something to it, it's very unlikely to be the issue.
Old 05-16-2013, 06:50 AM   #15878
2old2Bbold
was 2bold2getold
Oddometer: 1,906
Well, maybe. But most of these carbs have been apart a few times, and if you aren't carefull it's easy to bend that little tab with out even knowing it. Higher or lower fuel level will probably cause performance issues (rich/lean). once you understand how to set the float level it's pretty simple to get it right and worth checking every time.
2old2Bbold is offline   Reply With Quote
Old 05-16-2013, 09:04 AM   #15879
MrPulldown
MrPulldown's Avatar
Oddometer: 3,509
I would tend to agree with Anonawesome.
Most carb problems seem to be related to worn slide (on a pumper) and wrong jetting air/fuel mixture.
Go through rugged exposures ordeal. After he tore through his entire bike, his buddy fixed his bike by dramiticly changing the jetting.
Not saying that the float level is not worth checking...
Old 05-16-2013, 09:07 AM   #15880
MrPulldown
MrPulldown's Avatar
Oddometer: 3,509
about to route a decomp lever. Where does it go on the handle bar.
Old 05-16-2013, 09:13 AM   #15881
Greg Bender
Oddometer: 1,233
Check out my photos starting here and then scroll down, you can see how I've got mine mounted.
http://thisoldtractor.com/gtbender/d..._-_tusk_d-flex
I hope this helps!
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 05-16-2013, 09:57 AM   #15882
MrPulldown
MrPulldown's Avatar
Oddometer: 3,509
I hope this helps!
Regards,
Gregory Bender
Low. This is how I remember seeing most of them mounted. The FSM says high though. I think I will go the low route. Thanks.
Abuddy of mine is coming up this weekend. I am goig to try to get the spare DR running so we can go for a little ride.
Old 05-16-2013, 12:17 PM   #15883
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,998
Low. This is how I remember seeing most of them mounted. The FSM says high though. I think I will go the low route. ...
Mine is high. I might try low. Not sure it matters as long as you can reach it.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 05-16-2013, 12:23 PM   #15884
Greg Bender
Oddometer: 1,233
Agreed. I think I ran mine underneath because I like the feel of it there and the cable routing seemed better to me at the time. As long as it works...
Regards,
Gregory Bender
Old 05-16-2013, 12:29 PM   #15885
yotatoy
Oddometer: 126
Regards,
Gregory Bender
Greg,
I didn't realize the man behind "thisoldtractor" was a member here on ADV. Thanks for your site and hosting the repair manuals. A huge help for me.
Cheers!
Chad
1990 Suzuki DR350 "dirt"
1983 Yamaha RX50 special
1994 Suzuki JR 50
yotatoy is offline   Reply With Quote
Times are GMT -7.   It's 07:33 AM.
