Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 05-15-2013, 08:10 PM   #1
stormsearcher OP
Oddometer: 975
garmin 62 map help pls
i bought a garmin maP62 cheap online. being my first GPS unit i had no idea the 62 does not take an SD card but hass a built in memory of 1.71 g approx.
My friend loaded shonky australia topo on the GPSMAP62. It does notb seem to show up on the unit but it is there when i open the map files on the unit using the computer.
is there any trick to it being displayed? any suggestions please?
Don't tempt fate,TAUNT IT!
stormsearcher is offline   Reply With Quote
Old 05-15-2013, 08:16 PM   #2
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
On the map page open the menu and make sure map enabled.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 05-15-2013, 08:21 PM   #3
XRman
XRman's Avatar
Oddometer: 2,893
62 or 62S
my 62S has a card slot under the batteries for tiny little cards. I put OZtopo on mine and T4A.
XRman is offline   Reply With Quote
Old 05-15-2013, 09:58 PM   #4
Goosefeather
Captain Slow
Goosefeather's Avatar
Oddometer: 865
From the GPSMAP 62 series owners manual
"NOTE: The microSd card option is available only with the GPSMAP 62s and GPSMAP 62st"
"From the map. press MENU
Select Setup Map > Map Information - allows you to enable or disable the maps currently loaded on the device"
Goosefeather is offline   Reply With Quote
Old 05-15-2013, 11:36 PM   #5
mcguyver
mcguyver's Avatar
Oddometer: 1,276
From the map page
Menu
Setup map (enter)
Menu
Show shonky topo (enter)
If you also have any Garmin maps loaded you need to hide them from the same menu otherwise they will take precedence over the shonky mapset.
mcguyver is offline   Reply With Quote
Old 05-16-2013, 06:04 PM   #6
stormsearcher OP
Oddometer: 975
Originally Posted by mcguyver View Post
From the map page
Menu
Setup map (enter)
Menu
hi i cant see 'shonky' on the menu. there is birdseye global and some US/french/swiss etc maps but i cant find shonky. i have disabled all the maps.
on the comp i can see shonky in custom maps which i moved to birdsdeye but it is not visible in the map menu. any instructions pls?
Old 05-16-2013, 06:28 PM   #7
Goosefeather
Captain Slow
Oddometer: 865
Is it possible that your friend didn't transfer the Shonky map set to the GPS?
If using Mapsource, activate Shonky from the pull down list of available maps, pick the Map Tool (looks like a five sided polygon), select the required map tiles, then "Send to Device" (assuming GPS is connected and visible to MapSource)
I don't have BaseCamp on this PC so can't comment on the process there
Old 05-16-2013, 06:58 PM   #8
stormsearcher OP
Oddometer: 975
i think mapsource is used for PCs and he used an apple maC.
The shonky is on the unit but can view it only on the computer when i open the unit. cant find it on the drop down menu when the unit is unplugged from the comp.
maybe i should download mapsource on my comp , copy the shonky on my comp and redo the process.
hmmm its a great learning process now .
is there any online material like a manual that i can read and use to get to know my GPS better?
Old 05-16-2013, 08:03 PM   #9
Goosefeather
Captain Slow
Oddometer: 865
Google is your friend . . .
http://www8.garmin.com/manuals/GPSMAP62_OwnersManual.pdf
But that should have come with the unit.
Old 05-16-2013, 11:10 PM   #10
Muruk59
Muruk59's Avatar
Oddometer: 88
I have one of these also!
Use the software downoaded form garmin (Base camp) and map install. THen you use the free service openstreetmap.org from there you select the tiles you want (the tiles are the areas of map)
You will get an up to date download of all roads and select the option for the garmin set up.
Once downloaded there is a file you click on (cant remember the exact names but it is really obvious when you are looking at it) and that imports the maps into base camp. From there it is as easy as to download into the GPS and you can select the maps in base camp from the pull down.
PM me if you want to run through things in detail.
Muruk59 is offline   Reply With Quote
Times are GMT -7.   It's 06:17 AM.
