Old 05-17-2013, 11:45 AM   #15901
boardforever
boardforever's Avatar
Oddometer: 234
I just put one of these on my DR, got it from procycle.us
Similar to KTM folding mirror, seems good so far.
1999 DR350SE
2006 Kawasaki ZZR600 [sold]
boardforever is online now   Reply With Quote
Old 05-17-2013, 11:45 AM   #15902
motolab
motolab's Avatar
Oddometer: 2,858
Originally Posted by Anonawesome View Post
There's pretty much no situation that the float level needs to be adjusted.
The float height should be adjusted whenever the float needle is replaced. Additionally, float height is a tuning parameter on CV carbs, having a very similar effect to changing emulsion tube size. It can therefore be used to counter the effects of emulsion tube wear (to an extent).
Regards,
Derek
motolab is offline   Reply With Quote
Old 05-17-2013, 11:49 AM   #15903
motolab
motolab's Avatar
Oddometer: 2,858
Typically the float needle sits just at the base of the metal tab, so usually bending it does nothing.
2mm is about the limit, however 2mm makes a noticeable difference in CO% on the dyno.
Regards,
Derek
Old 05-17-2013, 12:19 PM   #15904
Ghostyman
Ghostyman's Avatar
Oddometer: 256
Originally Posted by FireDog45 View Post
Big +1 on the Doubletake mirror!
+2 on the Doubletake mirrors. Great design and worth the money.
Ghostyman is offline   Reply With Quote
Old 05-17-2013, 01:05 PM   #15905
Rich667
Rich667's Avatar
Oddometer: 178
Originally Posted by Greg Bender View Post
Yes, that is my DR350.
The Ken Sean dual sport mirrors are the best I ever found - until my friend (Mike Sonzini) showed me the Doubletake mirrors he was using on his bikes. I think the Doubletake is superior because it stays in place better and is *much* easier to adjust. Last year I replaced the mirror in the photo with the Doubletake mirror, and I really like it. I'm going to fit another one to my right side soon.
The Doubletake mirror and requisite mounts are certainly more expensive than the Ken Sean mirror, no doubt about that.
Here is a link to the Doubletake website:
http://www.doubletakemirror.com/
Or, if you want to buy them from my friend for the same price, just send him a PM via ADVRider (username: quota).
You can also purchase the correct ball mount and 3" arm through some place like GPS City:
https://www.gpscity.com/ram-mount-m1...inch-ball.html
https://www.gpscity.com/ram-mount-me...am-b-201u.html
I hope this helps!
Regards,
Gregory Bender
Those Mirrors look really cool but WOW 50 bucks is a lot for a mirror.
Rich667 is offline   Reply With Quote
Old 05-17-2013, 01:20 PM   #15906
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 836
The initial hit is steep but the RAM parts are pretty much indestructible and the mirror arm has a lifetime guarantee so the only part you would have to buy is the mirror itself. Add in the convenience of adjustment without tools and, in my case, the better rear visibility and its a lot easier to justify the cost.
I initially used a $5 junk yard mirror to be legal but couldn't see anything but my arm. I then tried a Ken Sean and it was better but I was still seeing mostly an arm. Installed the Doubletake and all is good now.
FireDog45 is offline   Reply With Quote
Old 05-17-2013, 01:23 PM   #15907
Ghostyman
Ghostyman's Avatar
Oddometer: 256
They are certainly pricey but you get what you pay for. I'm a cheap kid and even I am running (one of) these.
If you just need to be legal, throw on the cheapest folding mirrors you can find. If you want to upgrade a mirror, get this and skip the middle ground.
I guess I'm a mirror snob now.
Old 05-17-2013, 01:53 PM   #15908
Greg Bender
Oddometer: 1,235
I forgot I had photos of the Doubletake on my website:
http://thisoldtractor.com/gtbender/d...tm#gtb_mirrors
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 05-17-2013, 02:02 PM   #15909
2old2Bbold
was 2bold2getold
Oddometer: 1,915
I don't know what carbs you guys are working on, but on every carb I've worked on if you bend the float tab that rests on the needle, it makes quite a bit of difference in fuel level.
2old2Bbold is online now   Reply With Quote
Old 05-17-2013, 02:42 PM   #15910
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,973
absolutely
plugeye is offline   Reply With Quote
Old 05-17-2013, 02:48 PM   #15911
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 480
On this particular carb the float needle placement is quite a bit back from the end of the tab. So bending it doesn't do a whole lot unless you could bend a little step into it.
I will post a pic when I have it apart again.
jackanory is offline   Reply With Quote
Old 05-17-2013, 03:20 PM   #15912
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 5,006
I have NEVER had to make any significant adjustment to fuel level on dozens and dozens of bikes I have owned and worked on ... UNLESS some previous owner had fucked with it and I needed to undo their meddling. Even then, I've not attempted any float level adjustments until I've made absolutely certain the needle valve and seat (including any O-ring seal) are in good condition.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is online now   Reply With Quote
Old 05-17-2013, 04:12 PM   #15913
2old2Bbold
was 2bold2getold
Oddometer: 1,915
Agreed, but I,ve had a few that were "off" a little. The DR was good, but the Transalp and old "86 Reflex were off quiet a bit. My FZ1 was all screwed up. Someone had bought a jet kit for it and got the main jets in the choke/starter jet holes, and bent the floats. It started kinda funny. I just check the manual for the correct float heigth and make a little guage out of a plastic butter tub lid that will rest on the carb body/bowl parting line and just touches the float at the correct heigth. Cheap, free, and fool proof (maybe).
Old 05-17-2013, 05:42 PM   #15914
Rich667
Rich667's Avatar
Oddometer: 178
Regards,
Gregory Bender
Thats a cool site BTW, there is a lot of good info about DR 350's nice job
Old 05-18-2013, 04:41 AM   #15915
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,360
Unless the fuel level is so high that it's draining into the overflow tube, or so low that it's below the jets, there is really no reason to adjust the level. As long as it's in that (large) range, the jets and float needle will accept the exact same amount of fuel. In other words, it will be very obvious when the fuel level needs an adjustment. And if the tab doesn't look clearly tampered with, you probably have another issue like the floats containing debris, the small spring in the float needle is stuck, etc.
In my experience, I've found that usually the fuel level being off won't cause anything but drastic issues.
Anonawesome is offline   Reply With Quote
Times are GMT -7.   It's 11:34 AM.
