Old 05-17-2013, 08:01 AM   #4771
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,298
Originally Posted by xaman View Post
Forgive the newb question, but:
I'm looking at my rear brakes pads, after:
1.) my ABS light has been inconsistent lately. sometimes it stays lit, sometimes it is normal.
2.) it also seems like my rear brakes haven't been as grippy of late.
Check your brake fluid levels front and rear. You may need to flush and bleed the ABS unit.
tbarstow is offline   Reply With Quote
Old 05-18-2013, 01:24 PM   #4772
xaman
Oddometer: 517
Still working on diagnosing my rear brake problems:
Upon further inspection, I'm pretty sure I found the problem --- look at the dented (broken) ring:
See below, on the inside of the ring, where it's actually broken:
So, is this slotted ring part of the ABS system? What is it, I can't find it on the Bikebandit parts diagram...
xaman is offline   Reply With Quote
Old 05-18-2013, 01:29 PM   #4773
TobyG
be happy :)
TobyG's Avatar
Oddometer: 544
It's the rear sensor ring.
It gives you the speedo readings, is part of the ABS and afaik the MoDiTec somehow uses data from it as well.
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is offline   Reply With Quote
Old 05-19-2013, 04:38 PM   #4774
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Originally Posted by LTCOliverNorth View Post
Curious to see how you end up mounting the xtank to the TT subframe. The lack of charcoal canister mount points (which are used by the xtank) has stopped me from going that route.
George at Beemers uber Alles removed the subframe and Dan McNeely TIG welded the attachment points. George then reassembled the bike and completed the install.
mcgarrett is offline   Reply With Quote
Old 05-20-2013, 06:27 AM   #4775
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Tool kit
Any thoughts or experience with this tool kit?
http://www.advdesigns.com/ulcobmwg650x.html
Here's a cheaper alternative:
http://www.revzilla.com/motorcycle/c...1-bmw-tool-kit
I'm trying to put together a kit and would like to avoid getting everything piecemeal. I will get a separate tire repair/change kit.
Old 05-20-2013, 07:52 AM   #4776
khpossum
poster
Oddometer: 472
The first kit is nice, but hugely expensive. I wouldn't want to have it anyway, ever tried to get a allan bolt out with a bit and screwdriver adapter?
The second kit may go well with the XC, but the chances are it is not quit right. It seems really generic. I think you are better off putting a kit together yourself. That way you know you will have ALL the right tools just when you need it.
I don't see the 26 mm axle wrench in either.
KP
khpossum screwed with this post 05-20-2013 at 08:01 AM
khpossum is offline   Reply With Quote
Old 05-20-2013, 08:47 AM   #4777
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,175
The Cruz kit is available on amazon for 85 (free shipping). About two weeks ago it was only 65.
http://www.amazon.com/CruzTOOLS-RTB1...=cruz+tool+rtb
That being said, the convenience doesn't negate the price for me (especially the advdesigns kit). I piece together my own kit.
Originally Posted by VACommuter View Post
I'd be cranky too if I had to blow 500 horses!
VAC
You can bet your sweet ass and half a titty...
gastone is online now   Reply With Quote
Old 05-20-2013, 10:38 AM   #4778
jabroka
jabroka's Avatar
Oddometer: 338
Reprom help
Maybe someone can point me in the right direction.
I cant seem to find the cable routing (clutch and throttle cable) on the reprom manual.
Is it even there?
Both cables seem to be quite tight con my Xc (no risers - oem bar), so I think the cable routing must be wrong.
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 05-20-2013, 11:53 AM   #4779
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,377
I own the GS Adventure version of the advdesigns.com tool kit. The tools are american made and guaranteed for life. When it comes to tools, you tend to get what you pay for. Everything in the kit, including the roll is well thought out. I can hang the roll from the side of the bike using the hook & loop fasteners or the grommets on the top edge. I've supplemented some of my other tools into the kit, like lock wire pliers, a partial roll of Scotch 33+ electrical tape, specific feeler gauges for the valve clearances, and my 1/4" ratchet Wera set, the Rapidaptor. I have no problem working on all aspects of my bike using these tools.
Having said all of that, I had previously made my own tool kit, using my own tools I had in my tool box at home. I did my best to keep the kit as compact and light as possible, but it was more than twice as heavy as the advdesigns.com kit and not nearly as compact as their kit. I'm very happy with the advdesigns.com kit.
There is nothing worse than breaking a proper tool when you are working on a project, although being in the field and having it happen would just plain suck...
{drops two shiny one cent pieces on the table and saunters away...}
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia screwed with this post 05-20-2013 at 11:58 AM
macadamia is offline   Reply With Quote
Old 05-20-2013, 01:24 PM   #4780
Tomdog
Mapaholic
Tomdog's Avatar
Oddometer: 318
Tool kit
I use the Adventure designs kit brought over from my former bike (1200 GS).
Made a few supplements. For axle nuts, I have converted to KTM 27mm nuts and employ a "Motion Pro" lightweight 27mm tyre spoon (lever).
No problems at all with Allen bolts etc using this kit which may not be the lightest but its great quality.
07 X-Challenge--Sadly Sold
Tomdog is offline   Reply With Quote
Old 05-20-2013, 05:26 PM   #4781
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Tool kit
Thanks to everyone for your helpful inputs.
Old 05-21-2013, 11:13 PM   #4782
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
Is it even there?
Then re-route it so its comfortable.
I have 50mm risers on mine and a thorough re-routing of cables enables this.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 05-23-2013, 09:30 AM   #4783
jabroka
jabroka's Avatar
Oddometer: 338
and you're using OEM cables?
I'm getting the 20mm TT risers next week, being tight as they are now, I was planning to make custom cables.
Guess I'll try some new cable routing this weekend.
tnx!
1993 suzuki GSXR-R
jabroka screwed with this post 05-23-2013 at 09:57 AM
Old 05-23-2013, 01:19 PM   #4784
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,970
tnx!
yes all OEM cables
Not heard of anyone who has needed custom cables. The main re-routing is sorting out how it should flow around the bars and headstock.
Good luck with the TT risers ... they have a habit of bending or snapping bolts.
Old 05-23-2013, 02:59 PM   #4785
jabroka
jabroka's Avatar
Oddometer: 338
yes all OEM cables
Yeah.. I read that just after ordering
I guess I'll give it a try and carry a set of extra bolts just in case.
I saw a template/bracket on another thread that somebody made to fit a scotts steering damper. He said that it gave some extra stiffness to the whole unit, I may go that way if the bolts fails.
1993 suzuki GSXR-R
Times are GMT -7.   It's 06:15 AM.
