Old 01-17-2013, 09:14 AM   #286
BFG
BFG's Avatar
Oddometer: 77
Originally Posted by GZPainter View Post
I really like the following idea. Did the capacity of the box reduced with the addition of the pad?
and if yes by how much? keep the patrons...I believe that some people from over here they will need them..
Have a look at this, post 384 and follow SmugMug link to pictures. Lined the panniers hardly any reduction in size. Think they are better for it as well les chance of marking helmet etc.
http://advrider.com/forums/showthrea...836894&page=26
Or on UKGSer. From post 12
http://ukgser.com/forums/showthread.php?t=136812
Money isn't everything. But it keeps the kids intouch
BFG is offline   Reply With Quote
Old 01-17-2013, 09:38 AM   #287
LaurelPerryOnLand
Oddometer: 3,482
Originally Posted by ElMartillo View Post
Well, I like making money as much as the next guy, I enjoy fabrication and problem-solving. I could price it reasonably I'm sure.
You have a broken one you could send me? Ideally I'd need the piece(s) that broke off, ultimately ideally the bike for fitment, but we could get around that if necessary.
Cheers!
PM sent with pictures.
LaurelPerryOnLand is offline   Reply With Quote
Old 01-17-2013, 10:56 AM   #288
Panzerkampfwagen
Panzerkampfwagen's Avatar
Oddometer: 9
A Humble contribution to this thread. Led daytime light, just beneath the beak.
Nothing to deal with those great works above, but I tried to do my best.
Panzerkampfwagen screwed with this post 01-17-2013 at 11:13 AM
Panzerkampfwagen is offline   Reply With Quote
Old 01-17-2013, 11:21 AM   #289
Panzerkampfwagen
Oddometer: 9
Sorry. Wrong post.
Old 01-18-2013, 03:26 PM   #290
everycredit
everycredit's Avatar
Oddometer: 272
I made a tail pipe extension for my 1150GS with Jesse bags.
I know there are a lot of threads out there on this, but I decided to do it myself after being annoyed by this:
I got 1 3/4" ID exhaust pipe and used some throttle return springs and nuts that I had.
I removed the silencer end, using 8mm socket.
Then cut the pipe so it fits under my left turn light.
Dry fit
Measured the springs so I know where to weld the nuts to hold the springs.
Welded the nuts using a cheap harbor freight welder I've owned for several years. Does the job, but not weld (please don't judge my welds--I know they suck, but they hold).
Here it is fitted
With my pannier back on. Need to cut the end for fit.
Used an angle grinder to sharpen the edge, so in a pinch it can be used as a weapon
Went for a ride, doesn't rattle or leak. Hopefully it will keep all (if not most) of the hot exhaust gasses off my pannier.
everycredit is offline   Reply With Quote
Old 01-18-2013, 07:22 PM   #291
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,576
Dry fit
Here it is fitted
Looks good! The only change I would make is possibly heavier springs not stretched so much. Otherwise very nice!
Jim
JimVonBaden is online now   Reply With Quote
Old 01-18-2013, 08:06 PM   #292
everycredit
Oddometer: 272
Jim
I'll have to look for some. They aren't good springs and will probably be unsprung by the heat.
Old 05-19-2013, 11:20 PM   #293
bmw-gs-rider
Oddometer: 50
Relay controlled power outlet on my BMW R1150GS
For more information about the relay controlled socket check my blog: http://www.gsrider.net/2013/05/relay...on-my-bmw.html
my blog: http://GSrider.net/
bmw-gs-rider is offline   Reply With Quote
Old 10-08-2013, 11:33 PM   #294
dxamet
dxamet's Avatar
Oddometer: 47
crash protectors
dxamet is offline   Reply With Quote
Old 10-09-2013, 01:31 AM   #295
funinthesun
funinthesun's Avatar
Oddometer: 236
$20 dollar hardware store parts pillion plate and pelican case. all plastic and stainless.
plastic t handles and a few bolts and spacers on 3/8 sheet of abs plastic. works great
If you didn't crash at lease once, you were not having enough fun!
funinthesun is offline   Reply With Quote
Old 10-09-2013, 01:37 AM   #296
funinthesun
Oddometer: 236
and a clearance rear caliper guard from cyclegear for $1.99 turned into a pot guard.
Old 10-09-2013, 02:15 AM   #297
Jorik
Jorik's Avatar
Oddometer: 71
Originally Posted by dxamet View Post
It is Great!
Jorik is offline   Reply With Quote
Old 10-09-2013, 03:41 AM   #298
luca9277
luca9277's Avatar
Oddometer: 254
I made a tool tube...
luca9277 is offline   Reply With Quote
Old 10-09-2013, 04:12 AM   #299
slipknot
slipknot's Avatar
Oddometer: 859
Originally Posted by Jorik View Post
It is Great!
+1
But the Starbucks crowd (and it is a rather large crowd) is heaving their doughnuts in the parking lot.
In congressional testimony during the 2008 Crash, Greenspan admitted that the Ayn Rand mutant capitalism ideology had failed America: “I made a mistake..." said the Idiot.
slipknot is offline   Reply With Quote
Old 10-09-2013, 06:50 AM   #300
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,414
Modified my Jessie mount and added stainless extensions to keep from cooking things in the left pannier.
Thinking about TIGing on some gun sights for kix.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Times are GMT -7.   It's 08:29 PM.
