Old 05-19-2013, 04:59 AM   #1
jas123 OP
jas123's Avatar
Oddometer: 115
Anyone seen this? new 990r shift problem
Hi guys,
I bought a new 2012 adv 990r and have 1350 miles on it in the past month.
So I started out in first gear and went to shift into second, miss the shift. Click it again it went to second and and then third. Something didn't feel right with the shifter,like if was loose and falling off. When I stopped to downshift to first, I somehow ended up in 6 gear. And the shift lever travels from the standard 9 o'clock position to straight up 12 o'clock and is stuck in top gear.
The lever is attached to the shift shaft, but feels like the shift detent (arresting cpl) is not connected. Anyone experience this?
[IMG][/IMG]
I realize this is a warranty issue, but wondering if this is as simple as remove the side cover and putting the shift shaft together, or there is major transmission damage.
It's a new bike, and the snow has finally melted, and I want to ride!
jas123 is offline   Reply With Quote
Old 05-19-2013, 05:07 AM   #2
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
sounds a lot like your missing a pin in the right hand side case, on the selector drum end. easy fix in that case.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 05-20-2013, 12:09 PM   #3
Leodis41
I wanna Orange one!!
Leodis41's Avatar
Oddometer: 65
The weld on the selector fork behind the clutch cover has been known to fail.
I've seen photos on here of it before.
Leodis41 is offline   Reply With Quote
Old 05-20-2013, 12:49 PM   #4
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,847
Originally Posted by jas123 View Post
Hi guys,
[IMG][/IMG]
No big deal- they all do that.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 05-20-2013, 12:50 PM   #5
Sumi
Sumi's Avatar
Oddometer: 1,813
It's because you are riding it like a harley
Old 05-20-2013, 01:14 PM   #6
jas123 OP
jas123's Avatar
Oddometer: 115
Is this fairly easy to fix from behind the clutch cover?
Times are GMT -7.   It's 04:16 PM.
