Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-19-2013, 01:23 PM   #1
johnyred OP
Johnyred
Oddometer: 17
1190 Adv Tubeless Wheels
How do 1190 wheels become tubeless?
I see they dont use arrangement of spoke nipples like BMW or Aprilia.
Do they use special sealing nipples like Alpina wheels?
Or is it just the rubber gasket inside the rim that seals it?
I wonder if 990 wheels can become tubeless using 1190 R parts?
I know a different (tubeless) front rim is needed anyway but can i just put a rubber gasket on the rear and make it tubeless.
I think KTM uses just rubber gaskets to make 690 SM wheels tubeless.
johnyred is offline   Reply With Quote
Old 05-19-2013, 01:25 PM   #2
Tancakar
Tancakar's Avatar
Oddometer: 370
i guess they change their system to bmw
Tancakar is offline   Reply With Quote
Old 05-19-2013, 01:57 PM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,668
Its not the BMW (BEHR) system of external nipples, its a sealing band.
The 990 Adv uses a 4,25X18 rear rim, the 690 SMC and 1190 Adv use 5,0X17" rims - although they are not the same rim and not the same tubeless sealing band.
The 5" rim has a wide flat part around the nipple area, the 4.25" rim does not.
Peanuts is online now   Reply With Quote
Old 05-19-2013, 07:42 PM   #4
eizrah
eizrah's Avatar
Oddometer: 64
1190R 21/18 wheelset
I was thinking the same too.. Do the 21/18 wheelset from the 1190R fit on our 990? By juz looking it seems the hub will fit... Anyone can confirm on that? Its great to have a tubeless set on the 990 if the 1190R wheelset is direct fit...
eizrah is offline   Reply With Quote
Old 05-19-2013, 08:19 PM   #5
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,985
Same!
As the Yamaha Super Tenere.
RED CAT is offline   Reply With Quote
Old 05-20-2013, 01:38 AM   #6
johnyred OP
Johnyred
Oddometer: 17
In any case the front rim of the 990 should be changed for a rim that has a bead. I guess hubs are identical but i cannot confirm that.
The question is if the 990 rear 4,25'' rim can be sealed using only, the 4,5'' rubber gasket of the 1190R and the air valve stem.
KTM makes rubber gaskets for 3,5'' x 17'' (front 690 SMC), 3'' x 19'' (front 1190Adv), 5'' x 17'' (rear 690 SMC), 4,5'' X 18'' (rear 1190 Adv R), 5'' x 17'' (rear 690 SMC and 1190 Adv).
Can someone, with 1190 check the spoke nipples if they have some rubber sealing? Alpina uses such nipples without the rim rubber gasket.
Old 05-20-2013, 01:49 AM   #7
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Same!
They are different.
PPiA is offline   Reply With Quote
Old 05-20-2013, 02:36 AM   #8
jon6.0
jon6.0's Avatar
Oddometer: 546
Why not just do the Alpina tubeless conversion?
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 05-20-2013, 05:52 PM   #9
DiasDePlaya
DiasDePlaya's Avatar
Oddometer: 636
Why not to use sealant and duct tape? I used this in my old Honda Africa Twin and worked OK for 5 years.
DiasDePlaya
"Ya veras como quieren en Chile al amigo cuando es forastero"
Traditional song
DiasDePlaya is offline   Reply With Quote
Old 08-02-2013, 11:21 AM   #10
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,410
I've been researching this subject lately and found this cut-away of the KTM tubeless rim design. Note the added recessed channel for the sealing band. If I had to guess I'd say that the new 1190 rims will work on the older bikes, but you'll need the rim, seal and valve stem...
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 08-02-2013, 12:27 PM   #11
Frog uk
Oddometer: 287
You guess wrong.
It's a glorified elastic band.
Not sure I'd trust it with a few winters of good old British road salt corrosion under the wheels.
Much better systems out there, this one at best is a cheepo bodge.
Frog uk is offline   Reply With Quote
Times are GMT -7.   It's 04:06 AM.
