Old 05-22-2013, 07:06 PM   #7696
davek181
davek181's Avatar
Oddometer: 929
It should fit fine. You could have a red headed stepchild.
He says it is in good shape after 27 years of riding, but the head and exhaust studs look freshly painted.
Looks usable from the photos, cam and rockers look ok from the photos too.
davek181 is offline   Reply With Quote
Old 05-22-2013, 08:12 PM   #7697
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,957
It's only $270 + shipping. The head work is almost twice that Did all the early XLs drop seats or just the early ones? I'm not gonna buy if it's just gonna drop another seat.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 05-22-2013, 08:15 PM   #7698
joexr
Oddometer: 3,773
Name change , huh?
Old 05-22-2013, 08:41 PM   #7699
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,957
Yeah Dracus124 was my online game handle. I dont play video games no more
Old 05-23-2013, 06:49 AM   #7700
davek181
davek181's Avatar
Oddometer: 929
I have a later one '87 with over 40K on the clock and it's valve seats are still stuck tight. I do hope they improved as time went on, i don't want to have to go through that ordeal. I just want to ride.
Old 05-23-2013, 08:10 AM   #7701
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
I would go the engine dynamics route. Tell them you are on a shoestring. Last thing you want to do is buy junk on ebay if you dont have too and still need to do work. If you need a good XL600 exhaust valve, I have one you can have for free.
Hate gets you nowhere.
Old 05-23-2013, 09:10 AM   #7702
mcma111
mcma111's Avatar
Oddometer: 12,443
Last year I fixed a fellas 1993 XR650l that dropped a seat. Took out the piston, the head was so cracked it wasn't worth the repair. Big money fix. Even though he had re-jetted the carb he was running it on the freeway like a CB1000. Then he moved farther from work and blew up the motor again running it so hard. I talked him into a multi cylinder bike.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-23-2013, 10:22 AM   #7703
davek181
davek181's Avatar
Oddometer: 929
Right you are , but I use my XL as a commuter too. Luckily it is a short commute of 18 miles one way. I do have a couple of multi's I can ride, both vintage too, CB750K1 and a KZ750N. I keep the bikes at the shop and have enough cars that I can pretty well cherry pick my days. If the weather turns nasty at either end I can grab a car and run with it.
That being said when the time comes to choose my steed for the commute home I choose the 600 almost every time due to the fact that it is just more fun to ride even though it is not as well suited to the highway. If I have to take a longer trip with limited gravel exposure the multi is really the answer, though I would still think long and hard before abandoning the single. I also find it interesting that the 600 is geared higher for the road than the KZ. It turns less RPM per MPH than the KZ, although the Kawi does have a lot wider and more comfortable seat, making it the long range choice on the highway.
So far I have been lucky with the big single, other than a freak broken crank it has taken my abuse of it's design limitations. The option is always there with the XL of taking the long graveled road home too.
Old 05-23-2013, 11:39 AM   #7704
Reposado1800
Juicy J fan!
Oddometer: 5,797
Was that guy running an oil cooler?
Old 05-23-2013, 01:44 PM   #7705
mcma111
mcma111's Avatar
Oddometer: 12,443
I don't think so. He was running at 75 mph or better daily and the XRL really isn't the proper tool for that job. When I took his engine apart the second time he had gotten the piston SO hot that a 1"+ diameter of the piston crown had almost melted and it was deeply dished. Still have that piston on the work bench.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-23-2013, 02:43 PM   #7706
Reposado1800
Juicy J fan!
Oddometer: 5,797
On the build note, do wiseco pistons like to slap once in a while when cold?
Old 05-23-2013, 02:59 PM   #7707
davek181
davek181's Avatar
Oddometer: 929
In my own personal limited experience with my XL, 102.4 Wiseco was noisier than stock when cold, but not too objectionable considering how much better it ran.
Replaced crank with XR, then installed JE 102 piston in a rebored XL jug. Runs absolutely fantastic but it makes more noise than the wiseco ever did. finally quiets up at about 180 degree oil temp.
Old 05-23-2013, 03:18 PM   #7708
mcma111
mcma111's Avatar
Oddometer: 12,443
Shouldn't. Guess it depends on how much clearance the machinist gave the piston.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-23-2013, 04:29 PM   #7709
ret1614
Oddometer: 23
So, the new CDI unit fixed the red hot exhaust problem... The old one was retarding the timing. Got the new one in, and it runs like a dream again.
Life is good again.
1985 XL600R
1981 XL185S (ret.)
1978 Trail 90 (ret.)
ret1614 is offline   Reply With Quote
Old 05-23-2013, 05:08 PM   #7710
davek181
davek181's Avatar
Oddometer: 929
I had a long discussion with my machinist when we did the JE, I wanted it as tight as we could get it without fear of sticking. We read and reread and remeasured and ended setting it up at the minimum allowed clearance minus a little. Specs were .003" with piston diameter measured 13mm up the skirt. I think we settled on .00275" for fear of seizure. Set ring end gap at minimum too, It hasn't stuck, runs great, just noisier than I like until warmed up.
davek181 screwed with this post 05-23-2013 at 05:22 PM
Times are GMT -7.   It's 07:38 AM.
