Old 05-10-2013, 03:24 AM   #1456
LukasM
Oddometer: 5,425
I also prefer the dual pickups in the caliper bracket as they are better shielded in the back. As I've still managed to rip out a cable back there, additionally I now use the protector from Rally Raid Products:
http://www.rally-raidproducts.co.uk/...o-speedo-cover
Old 05-21-2013, 10:03 AM   #1457
MakS
MakS's Avatar
Oddometer: 84
For
navigation tower for BOANO fairing.
MakS is offline   Reply With Quote
Old 05-21-2013, 10:28 AM   #1458
Brimstone
Super Duper n00b!
Brimstone's Avatar
Oddometer: 620
MakS,
That fairing support is looking SWEET! I would recommend a radius on the inside of the triangle cut outs though. The sharp corners will develop stress cracks no? Should be easy since you will likely get it laser or water jet cut anyway...
Brimstone
Okanagan Valley - KVR Day Trip - First RR!
Brimstone is offline   Reply With Quote
Old 05-21-2013, 10:33 AM   #1459
MakS
MakS's Avatar
Oddometer: 84
Originally Posted by Brimstone View Post
MakS,
I make on CNC the milling machine.
Let's prolong wasn't with metal tension.
Old 05-23-2013, 12:09 PM   #1460
Muecke
Muecke's Avatar
Oddometer: 75
Originally Posted by MakS View Post
For navigation tower for BOANO fairing.
How did you make this foam?
Muecke is offline   Reply With Quote
Old 05-23-2013, 12:32 PM   #1461
tehdutchie
tehdutchie's Avatar
Oddometer: 1,870
My roadbook set up worked well, most of last weeks riding, that was until I flipped the bike, roadbook first into the ground. Ouchie..
https://www.dropbox.com/sc/t2dgqq4b7ij1a0x/dz4z1330od
tehdutchie is offline   Reply With Quote
Old 05-23-2013, 02:01 PM   #1462
waldecker
Oddometer: 158
Looks nasty- hope you are ok.
At least your ciggies seem to have survived....
Waldecker
waldecker is offline   Reply With Quote
Old 05-23-2013, 02:29 PM   #1463
tehdutchie
tehdutchie's Avatar
Oddometer: 1,870
Waldecker
I had a little rest after ;)
Bike flipped end over end, luckily my kneebrace took the impact when I went flying over.
Old 05-23-2013, 02:46 PM   #1464
Gany
Oddometer: 353
Nasty! Did the MD survive the impact?
Question, how often is the reset/mode button used on the remote during a rally and is it during a special or a non critical stage? Heres a pic of my prototype, im pretty happy with the result. The extra button top right will not work with some clutches so will scrap that idea. Which leaves me with 4 buttons... With this 4 i was thinking i could either run trip 1 and 2 +/- buttons and use the mode buttons on the trip itself or elsewhere, or run trip 1 +/-& mode, trip 2 mode only (no+/-). What would be the most useful configuration?
Gany is offline   Reply With Quote
Old 05-23-2013, 08:50 PM   #1465
watagans300exc
watagans300exc's Avatar
Oddometer: 114
Attachment 314581
Awesome work mate.
When you are ready to sell a few, put me down for 2.
watagans300exc is offline   Reply With Quote
Old 05-23-2013, 11:45 PM   #1466
italrally
italrally's Avatar
Oddometer: 498
Originally Posted by watagans300exc View Post
Awesome work mate.
may be this is also not so bad :-)))
[/URL]
RallyRaid stuff and MD & MIGTEC roadbooks & RNS - Trip Computer & Alu-Supports & Carbonfibre plates for sale !!!
Design your own personal KENNY Rally Raid jacket !!!
italrally is offline   Reply With Quote
Old 05-23-2013, 11:47 PM   #1467
tileman
tileman's Avatar
Oddometer: 882
Attachment 314581
I saw these units today in the flesh. The photos don't do them justice, they are well thought out and the prototype's finish is top notch. Put me down for a couple as well.
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 05-24-2013, 02:14 AM   #1468
LukasM
Oddometer: 5,425
On the Tuareg Rally there were lots of trip-km resets during the day, so it was critical that you had good access to the reset/mode button. I only used trip 2 to count overall kms for the day, so basically never had to adjust it.
In my - admittedly limited - experience, I think the classic 3 button layout of the F2R, RNS, etc switches will work much better in practical application.
Old 05-24-2013, 04:01 AM   #1469
Gany
Oddometer: 353
Thanks for the responses! I just need to find an economical way of reproducing the housings. Anyone know what type of plastic is ideal for this application? The prototypes are CNC ABS plastic, however Im concerned that ABS will break too easily on impact. Any other plastics preferred to ABS? If I go the casting route instead of CNC, what about epoxy vs polyurethane?
Old 05-24-2013, 04:43 AM   #1470
tehdutchie
tehdutchie's Avatar
Oddometer: 1,870
Nope, unfortuantely not, the GPS holder bent inwards and this cause the MD Roadbook to collapse next to the electric motor.
Trying to fix that now with the spare roadbook that I have.
with regards to 'zero-ing' the ICO units, you might do it three times a day. More then 50 times a day you would be adjusting the totals, slightly up and down.
Times are GMT -7.   It's 04:36 PM.
