Old 03-07-2011, 03:20 AM   #16
buick driver
buick driver's Avatar
Oddometer: 89
Helpful people here
DR - ThumperTalk
www.DRRiders.com
just another dave in paradise
buick driver is offline   Reply With Quote
Old 03-20-2011, 10:57 PM   #17
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Dongie's outstanding build-up :
http://www.advrider.com/forums/showthread.php?t=654953
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 06-23-2011, 02:46 PM   #18
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,731
Nathan and Elena's Aussie Ride-About
Nathan and Elena's Aussie Ride-About... Legend!
http://www.advrider.com/forums/showt...2#post14321492
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John screwed with this post 06-23-2011 at 03:01 PM
Sleepy John is offline   Reply With Quote
Old 09-24-2011, 10:11 PM   #19
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,547
Spark plug – 8 ftlbs (96 in lbs)
Spark plugs:
Denso irdidium - 5364 (IU31)
Standard ngk - CR10E
NGK irdium - CR10EIX
Oil drain – 17.5 ft (210) – use 13mm socket
Oil filter cover – 8flbs (96 in) stock – 4ft (48) w/ AMP alum cover
Oil – 2.5 qt w/ filter (10w-40) – fill to top of view window, less than 2.5q
Valves – engine cold, every 7500 mi.
In: .08 - .13 mm (.003 - .005 in) - .004 ideal (Pro-Cycle has the tools)
Ex: .17 - .22 mm (.007 - .009 in) - .008 ideal
TDC inspection hole plug (look down in and find the T) – 16.5 ft (198)
Magneto/Generator Cover cap (loosen hot, rotate the motor CCW) – 11ft (132)
Valve access cover bolts – 4-7ft - general bolt spec, adjust hand tight
Valve tappet screw lock nut – 4ft (48) – general bolt spec, adjust hand tight
Handle bar clamp bolt – 16.5 ft (198)
Triple clamp bolts: upper – 21 ft (252) / lower 19 ft (228)
Steering stem (top of triple clamp) top nut/cap – 65 ft lbs
Front wheel axel – 47 ft : tighten first, cycle shocks 5x
Front wheel axel clamp bolts – 7 ft (84 in) : tighten next, top bolt first
Fork top cap – 16.5 ft (198)
Fork preload = 10-20mm
Fork oil height = 6.5” / 16 oz (5.9 lowered – need 2 qt)
Front brake caliper bolts – 19ft (228)
Fr brake Bleed nipple – 6 ft (72)
Fr Brake pad mounting pin – 13lb (156)
Fr brake hose banjo bolts – 16.5ft (198)
Rear brake caliper pad – 13 ft (156)
Rear wheel axel nut – 72.5 ft (cotter pin) / 79.5 (fuji nut)
Fuji Lock nut from 2008 and newer: 08319-2118a
Rear shock – upper bolt 40 ftlb , lower bolt 37 Nm (old cogent) 55nm (stock & new cogent)
Rear suspension linkage - Dog bones fuji-nuts (both) – 72.5 flbs
Rear suspension linkage – frame fuji-nuts – 58 ftlbs
Chain – 525, 110 link, 14/42 sprockets
Chain free play – 1.2–1.8 in (30-45 mm) 1.2 to 1.8 inches of slack in the middle of the chain
Chain stretch limit: Loosen your axle nut and adjust your chain so there is no play in it. Count out 20 pitches (21 pins) measure between the centerlines of the 1st and 21st pin. 319.4mm (12.6") is the service limit
Swing arm frame bolt nut – 55.5 flbs
Counter sprocket bolts - 4.5 ft lbs (54 in) (shoulder/raised area goes in towards engine)
Suzuki counter sprocket seal retainer – part# 24751-32E00
Rear Sprocket bolts – 19.5 ftlbs (234 in)
Cogent rear shock
-lower red adjuster – rebound, 42 click total, out/down is softer
-upper small adjuster – compression, out/CCW is softer
Quality Bearings:
-Front wheel bearings: SKF 6003-2RS
2 - 17 x 35 x 10
-Front wheel seal:
2 - 23x35x7 (09284-23001 – Suzuki #)
-Rear wheel bearings: SKF 6204-2RS
2 - 20x47x14
-Rear wheel seal (brake side):
1 - 26x47x7 (09283-26019 – Suzuki #)
-Cush Hub bearing: SKF 6205-2RS
1 - 25x52x15
-Cush Seal:
1 - 35x52x7 (09283-34003 – Suzuki #)
Two 6003-2RS
Two 6204-2RS
One 6205-2RS
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 02-15-2015 at 01:47 PM
eakins is online now   Reply With Quote
Old 12-15-2011, 08:51 AM   #20
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
I'm embarrassed to find that I neglected to add a link to this thread-Who has the most tricked-out DR ? by Zapp22. A great thread that I thought I had included a long time ago . A DR650 farkle-fest .
While I'm at it, let me add another link, The DR650 Highway Touring Thread by planemanx15. Great ideas for making the DR a more capable mile eater .
Here's a buildup of a super clean DR650 motard setup: Will's Funster DR650 Project by willmeyer.
Krusty ... screwed with this post 04-02-2012 at 09:17 AM
Old 06-04-2012, 09:34 PM   #21
ER70S-2
ER70S-2's Avatar
Oddometer: 6,273
This is another inmate's idea and it worked well for me. I didn't like repeatedly using steel screws into alum on the oil filter cover. The solution is studs.
First thing I noticed is that the threaded holes in the clutch cover are deeper than the stock bolts, by about 6mm. What looks like a longer bolt, is actually a stud with a nut. The bottom one is the stock Zuki bolt.
This shows all 3 studs (cut/ground to length) screwed into the entire depth available, with the ground ends exposed. Sorry about the fuzzy pic, the camera was smarter than me when I took this pic.
After getting the length right, I flipped the studs to show the factory ends, drowned in Loctite (wiped off excess), and left to dry. DO NOT tighten the studs very tight, that will introduce an unwanted stress into the case bosses. The Loctite will take care of that.
Now, pritty and strong and steel on steel.
2004 DR650: 62,496 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 06-05-2012 at 05:45 PM
ER70S-2 is online now   Reply With Quote
Old 06-05-2012, 11:27 AM   #22
ag_streak
Tiene Ruta Cuarenta?
ag_streak's Avatar
Oddometer: 3,172
^ ^ ^ That's a cool idea, and thanks for the write-up!
2013 Triumph Tiger 800, 2012 Suzuki DR650, 2006 Suzuki V-strom Sidecar Rig
ag_streak is offline   Reply With Quote
Old 06-05-2012, 04:20 PM   #23
Heavy
Heavy's Avatar
Oddometer: 121
What size & length studs are they? Not to be lazy but it would be nice to have them in hand when I start the project.
There is never enough time or money to do it right the first time.
2008 DR650, 2006 V-Strom 1000, 2014 CB500X
Heavy is offline   Reply With Quote
Old 06-05-2012, 05:44 PM   #24
ER70S-2
ER70S-2's Avatar
Oddometer: 6,273
I knew then (Feb. 2010), but I don't remember now.
Remove your top bolt, chase the threads, bottom a longer bolt in the hole, measure what you'll need.
Stock bolt thread is 6x16mm. Looks like about 27mm. Buy 'em long, cut to fit.
2013 WR250R
Old 06-10-2012, 04:40 AM   #25
Heavy
Heavy's Avatar
Oddometer: 121
Originally Posted by ER70S-2 View Post
.........Stock bolt thread is 6x16mm. Looks like about 27mm. Buy 'em long, cut to fit.
Old 05-23-2013, 02:22 PM   #26
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,547
http://dr650-mods-reviews-tips.sportsontheweb.net/
Alaska
Old 06-06-2013, 06:35 PM   #27
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Another long overdue link. BergDonk is a fabricator and innovator, and is constantly finding ways to make the DR650 a better machine . Here's the link to his DR650 thread:
http://advrider.com/forums/showthread.php?t=646076
Krusty ... screwed with this post 06-06-2013 at 06:49 PM
Old 06-07-2013, 01:33 AM   #28
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Originally Posted by eakins View Post
That article needs to be edited.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 06-19-2013, 10:45 PM   #29
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Thumb
Thanks, Grifter, for this list of ride reports featuring the DR ...
Old 09-10-2013, 11:13 AM   #30
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Krusty ... View Post
http://shortwayround.co.uk/ by Jedi Master. (A RTW journey, still in progress. The trip started on a F650, but reliability issues led him to swap to a DR650 mid-trip . Of particular interest is the DR650 Preparation Page (http://shortwayround.co.uk/suzuki/). A very well thought out guide for what needs and issues to address and what to bring along for long distance travel on the DR.
A Solo Trip from Gibraltar to Australia (DR650s are for old ladies) by Linda Bootherstone-Bick
Just another Alaska ride by snowrider
Snowrider to Mexico by snowrider
Dirtbikes & Death Roads, 2200 Miles in Bolivia by RockyRoads
2 blokes, 2 bikes on the Silk Road
Lower Latitudes- Better Attitudes by Lone Rider
Chameleon DR650 by David Early
Europe to Timor Leste (2006-2009)
And thanks to you for digging up all the reports listed above and on Post
#11. Just shows the DR's history goes back quite a long way.
Times are GMT -7.   It's 10:08 PM.
