Old 05-27-2013, 02:01 PM   #1
brocktoon OP
brocktoon's Avatar
Oddometer: 257
Restoring Wixom Panniers
I'm restoring a set of rough Wixom panniers.
With some help from Boxer Metal I got the mounts refitted for a LBW /5, and painted them with POR-15. I've finally gotten around to stripping the paint off the bags themselves. So far, the easiest method BY FAR has been soda blasting:
I know dick-all about painting and have a few questions. The white underlayer appears to be primer. The soda blasting is not removing it (not without remaining on the area for a while, anyway). I've heard using a few coats of high-build primer with sanding in between will help smooth out some of the scrapes and scratches that have accumulated. Can I paint over the white primer, or do I have to get down to the bare fiberglass?
Also, any ideas what the rust-colored layer between the gray and the white might be?
brocktoon is offline   Reply With Quote
Old 05-27-2013, 02:57 PM   #2
Kanticoy
Oddometer: 304
Looks to me that the rust colored paint is your primer, and what you're seeing that is white is actually the gelcoat in which case you don't want to remove it. Sand the gelcoat with 320 until uniform, then hit with high build. Sand at 400, hit with sealer primer, sand again with 400 and then color coat and clear.
Sent from my DROID RAZR using Tapatalk 4 Beta
Kanticoy is offline   Reply With Quote
Old 05-27-2013, 05:15 PM   #3
Plaka
Brevis illi vita est
Oddometer: 4,608
The white stuff is the bare fiberglass. it's the gelcoat. Don't cut into it, it may be thin. Use spot putty and high build primer up from there.
Check out the VHT site for their line of rattlecan paints:
www.vhtpaint.com
Or you can get the good 2 part stuff from hot rod places. About $100 a kit.
Old 05-27-2013, 08:01 PM   #4
erimille
Oddometer: 62
I'd second Kanticoy's post. I followed this routine when restoring my Wixoms and was very pleased with the results. Pop the aluminum runners off and give them a nice run on a buffer. They shine up quite nicely. To reattach, I decided to countersink with screws and bolts (rather than rivits). The locks needed a bit of work, but managed to also get these back to a reusable state as well. A few ebay purchases later and I even managed to find the original lenses.
- http://potlach.org/2011/03/wixom/
Overall I've been very pleased with the addition of the Wixom rangers on my /5.
Keep at it! I think you'll be very happy with the results.
--e
erimille is offline   Reply With Quote
Times are GMT -7.   It's 11:53 PM.
