Old 02-23-2013, 04:50 PM   #31
fuelish
Oddometer: 732
Seal-All will definitely put a hurting on some brain cells.
fuelish is offline   Reply With Quote
Old 02-23-2013, 05:44 PM   #32
CycleDoc59 OP
Wrench Rider
CycleDoc59's Avatar
Oddometer: 970
Originally Posted by backdaddy View Post
I did each spoke nipple with a glob of Goop, did 3 spokes at a time and let dry for about 20-30 minutes. I placed my wheel on a truing stand. I covered the spoke and the valley or indentation around the spoke, the Goop will flatten out as it dries. I did each spoke twice. When I put on the tire I had 2 that leaked. Had to redo them. I did my front wheel also, but inflating the front wheel and getting it to seat on the rim was next to impossible. The rear inflated no ptoblem at all. I have had one flat on the front, just pluged it, still going strong. Good luck.
You nailed it. That's the way to do it, except it's best to go all around, doing 1/3rd
at a time to give the Goop a chance to set, then let it sit overnight between each of
two more applications, still doing 1/3 at a time.
Difficult beads can be seated by using Murphy's Oil Soap (veggie based,
so won't hurt rubber), and warming the tire can help a great deal... Setting
new tires in the sun in summer or in the house in winter can make a big
difference. For really stubborn beads, I use a blaster, like this:
http://tinyurl.com/amu7q7l
CycleDoc59 is offline   Reply With Quote
Old 02-23-2013, 05:58 PM   #33
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,071
Vegetable oil certainly will damage most rubbers. I wouldn't use anything vegetable oil based on my tires. windex or dishsoap (1:2 with water) works just fine for tires.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 02-23-2013, 07:02 PM   #34
CycleDoc59 OP
Wrench Rider
CycleDoc59's Avatar
Oddometer: 970
Wow, you are out of touch. Murphy's has been used as
tire mounting lube for many years. You can catch up here:
http://www.alltiresupply.com/c-MFG_Murphy.html
Old 02-23-2013, 07:04 PM   #35
slackmeyer
slackmeyer's Avatar
Oddometer: 3,071
It may be that murphy's is fine as a tire mounting lube, but it's not true that vegetable oil based things are not harmful to rubber.
Edit: and second of all, the link you posted doesn't say anything about using murphy's oil soap for mounting tires. It's a link to murphy's tire mounting compound, and the companies have been separate since 1991.
Zak
ktm
old bmw
others
Old 02-23-2013, 07:35 PM   #36
CycleDoc59 OP
Wrench Rider
CycleDoc59's Avatar
Oddometer: 970
Says right here that the "Murphy's Original Tire Mounting Compound"
is "Thick vegetable based, jelly-like lubricant"
http://jtmproductsinc.net/murphys_ti..._mounting.html
I mount tires almost every day (3 today), and it's Murphy's every time,
for over 15 years. The tires are happy with it, and so am I.
Old 02-23-2013, 09:30 PM   #37
slackmeyer
slackmeyer's Avatar
Oddometer: 3,071
I'm sure they are, it looks like good stuff. I saw the words vegetable, oil, and rubber and reacted to that. murphy's oil soap for tire mounting is a new one to me, but I only do my own tires, maybe 1/2 dozen a year, and dish soap works well enough for that.
Zak
ktm
old bmw
others
Old 06-03-2013, 02:29 PM   #38
rattis
rattis's Avatar
Oddometer: 1,146
Question Alternative to Goop?
Are there any good alternatives to Goop that are available in Europe?
Maybe som Loctite?
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is online now   Reply With Quote
Old 06-03-2013, 05:18 PM   #39
the foolish fellow
UP FOR IT
the foolish fellow's Avatar
Oddometer: 140
alternative
http://www.contec7.co.uk/tec7-uses.htm
this would be great stuff.
990 adv
850 Le mans
Gl 1000
X5 3.0d
FE 450 BERG
the foolish fellow is offline   Reply With Quote
Old 06-04-2013, 04:43 AM   #40
Fast_Boy_Slim
Don't call me Wighty
Fast_Boy_Slim's Avatar
Oddometer: 3,046
Maybe som Loctite?
You can get it in the UK from here
http://www.palmermetals.co.uk/shop/c...cartridge.html
Go Jane Go
Treat your throttle and brakes like a pair of b**bies! You go grabbing them hard and you're going to get slapped. You want to massage them nice and smooth. That way the bike will kiss you. Chris Carr
Fast_Boy_Slim is offline   Reply With Quote
Old 06-04-2013, 09:29 AM   #41
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,917
The best so far
http://www.ebay.com/itm/Tubeless-kit...d8775d&vxp=mtr
Cheers.
gefr is online now   Reply With Quote
Old 07-26-2013, 08:59 AM   #42
Ahks
Oddometer: 2
New to spoked wheels of any type. Picked up a 76 xl250. Want to convert it to street only.
Visually comparing this wheel to a Ducati 916 wheel I have laying around and I don't think my wheel has a "safety bead" :(
I'm respoking my front hub to this, which is a rear hoop from the same bike :p My plan is to use it as a backroads tourer, 99% road, and the thing has a max speed of 70mph
Thoughts?
edit: link to the Duc wheel for reference http://i.imgur.com/BQ64rCG.jpg
edit2: after further research, I'm gonna give it a go anyway. A 70mph puncture with a tube would be the exact same result except it would deflate faster. The tire would be able roll off the rim just as easy with no air in the tube. It's a low power bike so I doubt at any point I'll be able to power the tire off the rim (as long as the bead is sealed properly).
Ahks screwed with this post 07-26-2013 at 09:20 AM
Ahks is offline   Reply With Quote
Old 07-27-2013, 05:43 AM   #43
Algarve Nick
Oddometer: 104
Off topic message to paochow. Tried to register on your site but it's not working. Just wanted to say that your comparison test of the Ulysses and 990 is spot on. I owned a 950 Adv between 2005/07 (wrote it off), then bought the Ulysses. I love both bikes and, actually, would now like a 99 Adv, which is why I'm hanging out on this site. Similar but very different bikes. Apologies to other posters following this thread.
Algarve Nick is offline   Reply With Quote
Times are GMT -7.   It's 02:10 PM.
