Old 06-06-2013, 08:42 AM   #256
Cerberus83
The Wingman
Oddometer: 143
@John - I think that's the whole idea behind the USB cable: to let users set their own amperage.
However, now I'm confused about the price... $200 for the unit + $40 for the cable or does $200 get you the unit AND the cable? Also, $40 for the USB cable?? Seriously? Is it made by Monster Cables... can you post the pic of the cable?
Cerberus83 is offline   Reply With Quote
Old 06-06-2013, 08:50 AM   #257
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
and a GOOD picture- high quality, well-lit plenty of detail?
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 06-07-2013, 07:23 AM   #258
Cerberus83
The Wingman
Oddometer: 143
Not sure what's so funny? If you think spending $40 on a USB cable (that costs under $.20 to produce and sells for under $3) is reasonable to you, then I have plenty of shit to sell you...
Don't believe me?
Old 06-07-2013, 07:29 AM   #259
FakeName
FakeName's Avatar
Oddometer: 1,811
Don't believe me?
Easy, easy.
It was a joke about the photography services I offer.
Shhhhh. It's ok.
2014 500EXC Black
Old 06-07-2013, 10:33 AM   #260
Cerberus83
The Wingman
Oddometer: 143
My apologies
I still can't get over the price of the cable...
Old 06-07-2013, 04:43 PM   #261
John Smallberries OP
John Smallberries's Avatar
Oddometer: 1,285
Cable
My apologies
It looks like they could not find a way to use a standard USB cable connector on the PDM60 end (mini, micro, etc.), so they probably had to pay someone to tool up a special one. Given that they only sell a few thousand of these gadgets, they probably aren't making any killing - even at $40 per.
I am curious as to why a simple mini-USB wouldn't have worked. You have the problem of making it waterproof either way.
Hey Rowe guys - fess up!
Regardless - the new one is still on my "wanna have" list......
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is online now   Reply With Quote
Old 06-08-2013, 05:55 AM   #262
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 946
Originally Posted by John Smallberries View Post
Adam;
Very interesting. If I read your note correctly, you are able to calibrate a single channel on the new PDM60 to handle 20 amps. Did I get that right? This appears to be different than what I've seen written previously which implies a 15-amp limit to any individual channel.
From the RocketMoto website: "With custom programming, the current capacity of each circuit, up to 15Amps maximum, can be can be adjusted in .25A (1/4AMP) increments to meet your specific requirements."
If I can truly get a single channel at 20 amps - it may be worth the upgrade!
Correct. The latest firmware permits one 20A circuit. Does not increase the 60A max for the entire unit though. If you have a PDM60 that was sold prior to about February, we'll update the firmware for you at no charge, other than return postage. The firmware update also enable the USB cable programming.
We'll update our description on the site - thanks for catching that.
=Adam=
Like us on Facebook -- Follow us on Twitter
PM us for your *personal* ADVRider discount code to use at RocketMoto.com
Autocom | TPX Radar/Laser | Sena Bluetooth
| Hi-Power LED Lights
Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design
RocketMoto is offline   Reply With Quote
Old 06-08-2013, 05:58 AM   #263
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 946
Don't believe me?
We will send you a $3 USB cable. If you can figure out how to make that work, we'll pay you $10 each. That's a whole lot less than we pay to Rowe and you'll make a fortune on these.
=Adam=
| Hi-Power LED Lights
RocketMoto screwed with this post 06-08-2013 at 06:19 AM
Old 06-08-2013, 06:19 AM   #264
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 946
The PDM60 was never intended to be end-user programmable. These are programmed with a PIC debugger at the factory (or dealer), and it's not USB on output of the PIC-IT tool. That's the reason behind the non-USB header programming connector on the PDM60, and the new cable is not just a plain ol' USB cable. Perhaps on the next version of PDM60, whenever that is, the programming interface will be different. I've provided some input in this regard.
Hope that helps.
We'll update any Version 2 PDM60 - regardless of where it was purchased, to the new USB cable compatible firmware, for the cost of return postage.
=Adam=
| Hi-Power LED Lights
Old 06-08-2013, 06:48 AM   #265
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 536
I can drop mine off and pick it up when its ready if thats OK Adam.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 06-08-2013, 07:19 AM   #266
Oddometer: 1,285
Stebel problem solved: dumb-ass can't count!
Originally Posted by RocketMoto View Post
Why yours is tripping the 2x 15A circuits, I cannot say - it shouldn't - but you know that, already. I'd suggest calling Blake at Rowe Electronics.
I figured out my problem and can now wake the neighbors easily with my Stebel running through the PDM60. I had mis-wired the main connector (mine is the earlier version). I had the red wire (Circuit #4 - 15 amps) stuck in the hole for Circuit #3, which is only 5 amps!! So - I was just repeating my previous failure of trying to get 20 amps by combining a 5 and a 15: Andre-Marie Ampere will simply not allow this to work. I now have Circuits #1 and #4 properly tied together allowing two 15-amp circuits to feed a 17-20 amp load. All is good.
It also confirms Rowe's decision to eliminate the connector altogether: customer failure mode avoidance!!!
The PDM60 is the way to go - assuming you can follow directions!
Old 06-08-2013, 11:02 PM   #267
Squelch
Everyday People
Squelch's Avatar
Oddometer: 1,103
I've got some Gerbing's heated gloves and a jacket liner that I want to hook through the PDM60. Should I leave the fuse in the system, or does the PDM60 take the place of the fuse?
Also, with the PDM60, do I still need to run a relay for an aftermarket horn, or will the PDM60 handle it once I've programmed a 20AMP circuit?
Squelch is offline   Reply With Quote
Old 06-09-2013, 04:04 AM   #268
Oddometer: 1,285
answers
Gerbings: The PDM60 takes the place of the fuse - that's the idea.
Horn: The horn button on my 1200GS is not setup to carry 20 amps of current - so I used a relay. PDM60 current to the horn via a relay switched by the horn button.
Old 06-10-2013, 01:47 PM   #269
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 946
Give us a call. Swing over, and I can update it for you in just a few minutes.
=Adam=
| Hi-Power LED Lights
Old 09-10-2013, 07:14 PM   #270
BruceWA
Oddometer: 556
Anyone done a PDM60 installation on a 2013 BMW R1200GSW? Looking for info.
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Times are GMT -7.   It's 06:19 AM.
