Old 06-10-2013, 01:35 PM   #1
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
XR400R, XR600/650 wheels swap.
So who here KNOWS what years and models are compatable? I am getting that 2001XR400R and would love to know which of the 600 650 wheels will fit right on without the axle swap too. I read somewhere (but can't find it) where quite a few years of the XR600R wheels bolt right up and heard the XR650 wheels MIGHT as well.
Reason is I would like a set of dirt wheels after I have my stock hubs powdercoated and laced to SM wheels.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 06-10-2013, 02:09 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,078
The front wheel on your XR400 uses a 17mm axle as does the 1993 and forward XR600 and XR650l.
Looking at the parts fich the XR400 has a 17mm rear axle where the XR600 and XR650l has a 20mm axle.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-10-2013, 04:24 PM   #3
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
So can you swap the rear if you use the 600 axle?
Old 06-10-2013, 05:20 PM   #4
joexr
Oddometer: 3,773
And a real big hammer.
Old 06-10-2013, 06:48 PM   #5
skahuna
Oddometer: 65
My 2003 400 has a 650L rear wheel... I remember it being slightly different but it bolted right up
skahuna is offline   Reply With Quote
Old 06-10-2013, 08:25 PM   #6
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,691
Check this out mang....
http://www.oem-cycle.com/HondaXR200RBIKEID.shtml
http://www.oem-cycle.com/HONDAXL250BIKEID.shtml
http://www.oem-cycle.com/HONDA650LBIKEID.shtml
side scroll over to the axle and hub columns, should give ya a crossover on what parts fit other years and displacements...
"If someone has a gun and is trying to kill you, it would be reasonable to shoot back with your own gun." ~ The 14th Dalai Lama
S.t.t.G. is offline   Reply With Quote
Old 06-10-2013, 08:26 PM   #7
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,618
Fronts
Its my understanding that late model xr250r, and xr600 xr650r xr400 fronts are all interchangeable. Also old xr250l fronts work too, its the first use of that style hub.
here is a xr650r version
In fact I concluded if it looks like this it will work. there is 2 maybe 3 different castings they used but the intent is the same.
Jayrod1318 is offline   Reply With Quote
Times are GMT -7.   It's 01:09 AM.
