Old 06-09-2013, 05:03 PM   #1441
Yellow Iron
Yellow Iron's Avatar
Oddometer: 3,054
Tried to load maps to the GPS for an upcoming trip.
Cleaned up the bike and started packing
Bigger Better Faster More----4 non blondes
Feel the Power of the Wheel
Yellow Iron is offline   Reply With Quote
Old 06-09-2013, 05:30 PM   #1442
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,395
Went for a ride with a friend and then came home and swapped out the old cam chain tensioner for the new one. Whew!!
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 06-09-2013, 05:42 PM   #1443
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 2,993
Changed the oil and filter, put the car tire back on the rear, put a new ME 880 on the front. Rubber on the sidecar looks fine for the trip to Oregon and back even loaded up with Barley and all our camping gear. Put a coat of wax on the hack. Started moving all the stuff I'm taking on the trip into the shop. Will do the 24k service next week, then pull the rig into the shop and start packing, and repacking, and reorganizing, and fiddling with the weight balance.
This is going to be an awesome adventure. Just me and the dog. Vermont to Washington/Oregon via a very scenic 5800 mile route...then 4000 miles on the return trip. Seeing some old friends along the way and hoping to meet several new friends as well.
I got a sidecar to travel with my dog. He never complains, is delighted to be with me, approves of my dietary choices, is a social butterfly who helps me meet folks, appreciates a good beer, snuggles better than my wife, and hangs on my every word as if it's the most profound thing he's ever heard. TravelsWithBarley.com
Boondox is offline   Reply With Quote
Old 06-09-2013, 07:25 PM   #1444
Callisto224
Callisto224's Avatar
Oddometer: 990
Originally Posted by JimVonBaden View Post
Has been for years.
Jim
Is this for all the 1200Gs's or just the recent years? Say, 2010 and newer.
I think the listed spec on my 2009 is 220ml but I've also seen 180ml. Confused, I went with 200ml when I changed mine last year. Haven't had any problems so far. Any idea what symptoms I'd see if it had too much oil?
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 06-09-2013, 07:49 PM   #1445
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,785
All R1200 bikes and the K1200/1300 take 180ML, and have.
Most likely you won't have an issue, but if you do a leaky seal is the general symptom.
Jim
JimVonBaden is online now   Reply With Quote
Old 06-09-2013, 07:57 PM   #1446
JimVonBaden
"Cool" Aid!
Oddometer: 51,785
Added this to my bike!
Helped lay to rest an old friend here:
My friend:
Jim
Old 06-09-2013, 08:17 PM   #1447
Ghostie
Cereal Killa
Oddometer: 69
Originally Posted by I GS 1 View Post
R1150GS
Converted my R1150GS speedo and rev counter. I much prefer the white faces
Is that a Bicycle Computer? The Cateye
Ghostie is offline   Reply With Quote
Old 06-10-2013, 12:24 AM   #1448
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 628
Yes. The OEM speedo with its magnetic drive isn't all that accurate (Over reads badly). I installed the Cateye before I started using the Garmin with GPS. I can set it even to compensate for tyre wear and I like the digital readout. The Velo 8 is one of the few that reads up to 300 kph - most only do 100 kph.
I GS 1 screwed with this post 06-10-2013 at 12:42 AM
I GS 1 is offline   Reply With Quote
Old 06-10-2013, 03:34 AM   #1449
mikegc
mikegc's Avatar
Oddometer: 1,605
What have you done to your GS or GSA today
Jim
Godspeed, Paul Mihalka.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 06-10-2013, 09:39 PM   #1450
bigbadandugly
Oddometer: 405
Installed some SW-Motech bar risers on my GS tonight! The bar position feels great!! I was surprised to see that only two of the four clamp bolts actually secure the bars to the triple tree. In a full lock right turn the added height causes the clutch cable to be too taught, so that is tomorrow's epic project - drop the fork tube and re-route the clutch cable over the top triple clamp and not under it.
One of the reasons I installed the bar risers is because the steering damper install required that the lower bar clamp to bo reversed. This had the effect of moving the too far bars forward. The bar risers allowed me to put the bar clamp back in the original fashion.
BigBadAndUgly
Current: 2012 R1200GS
Past: 2009 Moto Guzzi Stelvio, 1979 Suzuki GS750L, XR350R, DT125, CT70
Dyno testing of a PC-V + Full Akropovic system on an R1200GS
bigbadandugly screwed with this post 06-10-2013 at 11:03 PM
bigbadandugly is offline   Reply With Quote
Old 06-10-2013, 11:07 PM   #1451
ACD
old nOOb
ACD's Avatar
Oddometer: 265
One of the reasons I installed the steering damper is because the steering damper install required that the lower bar clamp to bo reversed. This had the effect of moving the too far bars forward. The bar risers allowed me to put the bar clamp back in the original fashion.
Missed the group buy by a few days... Any chance of a second waive?
Can you tell me about the install - did you do it yourself? How hard was it? I was considering hyperpro just because install was easier. Did you give it a workout yet, can you comment on prformance? Thanks
ACD is offline   Reply With Quote
Old 06-11-2013, 09:40 AM   #1452
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,264
Filled the tank. 7.5 gallons into 305 miles.
RID recorded all the bars lit, full.
Until I rolled it off the centerstand. Then one bar down. German accuracy.
Rode to work.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head screwed with this post 06-11-2013 at 04:01 PM
Mr Head is offline   Reply With Quote
Old 06-11-2013, 03:45 PM   #1453
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 210
Originally Posted by mikegc View Post
Godspeed, Paul Mihalka. Mike
An inspiration to us all! Notice the Million Mile Badge on the windshield...
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee is offline   Reply With Quote
Old 06-11-2013, 04:28 PM   #1454
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
Hope this is the right place to ask. Dealer wants $400 for first service for a 2013 gs1200 water cooled. What does the first service entail? I have changed oil and filter etc myself on other bikes.
Got places to do and things to be.
'14 1200 GSA
seatec is offline   Reply With Quote
Old 06-11-2013, 04:32 PM   #1455
trapperj
Oddometer: 480
Service
Reckon it's in the owners manual...not trying to be a smart ass....if you don't have a OM there may be something you could download online perhaps?
trapperj is offline   Reply With Quote
Times are GMT -7.   It's 07:34 PM.
