Old 06-11-2013, 09:19 AM   #1
Flameout OP
Flameout's Avatar
Location: I'm right where I'm suppose to be all the time!
Oddometer: 275
Question iPhone 5 mount
What's the best I5 mount for the 990R? RAM?
Show pictures of yours mounted on your bike.
I'd be interested in a waterproof one as I'm trying a new GPS map app: Scenic Map Central USA.
Anyone tried this app?
Thanks, Walt
"Artillery lends dignity to what might otherwise be a vulgar brawl."
Frederick The Great (1712 AD - 1786 AD)
FOLLOW ME!
http://share.findmespot.com/shared/f...rytJ4p77xkQ75p
Flameout is offline   Reply With Quote
Old 06-11-2013, 09:57 AM   #2
Dan950ser
NW Shredder
Oddometer: 402
I'd like to see a mount for when it has the waterproof lifeproof case on it.
2007 KTM 990 SuperDuperEnduroR
2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 06-11-2013, 10:00 AM   #3
Flameout OP
Flameout's Avatar
Oddometer: 275
I found one of those! Google ram iPhone 5 lifeproof. Should find it.
FOLLOW ME!
Old 06-11-2013, 10:33 AM   #4
alongat
alongat's Avatar
Oddometer: 1,058
I use an iphone 5 with a lifeproof case and their "cycle mount" - it's ok and hasn't caused me any concern so far despite not being the most sturdy of mounts. The ball on the back is a ram-like ball but it's a smaller diameter so it's not compatible with anything that Ram makes. I've been thinking about modifying mine to accept the standard Ram mount so I can do away with the feeble compression ring style mount that it comes with and use my multitude of Ram parts. Apart from that, it's got a positive lock on top to keep the phone safe and locked in the mount and it allows the lifeproof access flap to be opened for charging while riding (though that compromises the water resistance).
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 06-11-2013, 04:30 PM   #5
Orangecicle
Orangecicle's Avatar
Oddometer: 2,459
Here's what I did with a 4S. The same can be done with a 5:
The case is a LifeProof, and the mount is a LifeProof bar mount. Both purchased off of eBay. I used this on the Great River Gravel Ride a few weeks ago with the Motion X GPS app. I did 250 miles there and 250 miles back using Google maps to guide me. I used Motion X GPS to follow the pre-planned tracks for the 270+ miles of gravel and dirt roads during the event. The trip back was in torrential rain. It all worked very, very well. The only complaint I have is that the LifeProof case adds a layer of glare to the screen that's a little tricky to deal with. I have a Zagg screen protector on the iPhone, and that tends to adhere to the inside of the LifeProof screen protector, which cuts down on the glare but doesn't solve the problem. The other issue is that you need to touch the screen every now and again to do something, such as zoom in to see if you are making the correct turn. That's hard to do without gloves. I found myself just taking off my gloves, which I hated doing on a ride that was at times a little sketchy. Still haven't solved that problem.
Motion X GPS rocks, by the way. It's the best solution I've ever seen anywhere. It will be that much better on the larger iPhone 5.
Also, I installed a USB adapter purchased off of eBay so that I can just plug up the iPhone charge cord directly to an appropriate power source and not have to worry about the phone's battery. The adapters are available from eBay for under $20.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle screwed with this post 06-11-2013 at 04:43 PM
Orangecicle is offline   Reply With Quote
Times are GMT -7.   It's 02:26 PM.
