Old 06-11-2013, 04:24 PM   #91
BergDonk
BergDonk's Avatar
Oddometer: 3,785
I fitted a GSXR1000 muffler to my DR with positive results and FWIW posted up the exercise here:
http://www.advrider.com/forums/showp...&postcount=464
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-03-2014, 11:36 PM   #92
1989THEARK
1989THEARK's Avatar
Oddometer: 372
FMF Powerbomb
Since this is the thread about exhaust.
Does the powerbomb add any torque to the DR
From all the research i've done.
A smaller tube keeps exhaust gas velocity up initially
(Im not talking about back pressure as back pressure does not in itself make torque)
so this adds to the low end torque when revs are low.
But the Powerbomb from looks is a larger diameter tube with an expansion chamber that supposedly aids in moving exhaust faster. Is there any truth to this?
1989THEARK is offline   Reply With Quote
Old 07-24-2014, 01:10 PM   #93
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
I mounted my 02 GSXR Muffler (40) with a Procycle mid pipe.
Worked out great! As always with PC, the fit, finish and execution are awesome.
http://www.procycle.us/bikepages/dr650.html#exhaust
At first it was lining up well but I loosened the header pipe bolts at the motor. At the header pipe to mid pipe frame mounted support, the rubber insert and metal collar stays in place.
I also had some issues removing that alum. trim piece at the header to mid pipe connection. The bolts where frozen on there and they are small & soft allen sized that will strip easily. At first I used my hand hammered impact tool with an socket allen bit. you have one of these right? you should! went back and forth between tighten and loosen and still no go. I then sprayed some Kroil (you should have this too!) in there and applied directed heat with a low flame straight into the bolt head. I applied Kroil a few more squirts and more heat. Then I went back to the impact tool and a few back and forth tighten and loosen hits knocked the bolt loose. If I had tried to just muscle the bolt loose it would have stripped and then my work would have been 3x the time drilling out those bolts. Button nose allen bolts strip easy!!! You have been warned.
I solid mounted the PC collar (smaller side up) to the pipe but all the other bolts were put together loose and then tightened at the end. My header to mid pipe washer was in great shape (as expected) but my muffler did not have a seal ring so I ordered that too from PC.
Be aware, if you have a 01 or 02 (040) muffler the factory mount tab needs to be removed without a doubt! The PC round the muffler strap sits right where the factory tab is. I used an angle grinder, cutoff off wheel & sanding wheel. Not sure about the other years and models?
As you can see in the pic the end of the pipe sits a few inches before the end of the bike and tight against the rear fender. I added 1 additional thick washer to the strap spacers (at the frame) to move it out say 2mm off the fender as it was touching it.
I'd say eyeballing the pics, with the PC mid pipe, the muffler sits back farther on the bike than with the Jesse mid pipe. My muffler ends a few inches ahead of the rear of the license plate light.
What you gain with the PC mid pipe is a slip joint held tight with beefy springs so the muffler can expand and contract with heat. Seems the Jesse mid pipe has the muffler fix mounted with his hanger bracket and over time the muffler will expand and contract and you'll find the hole on the factory muffler bracket will be enlarged over time.
I use a Giant Loop Coyote bag over the rear of my rear seat (strapped to front edge of rear rear at the top) strapped to my passenger pegs. This puts pressure on the side panel. I put a GL hot spring guard on my muffler as seen. On the side panel there is a round rubber spacer and I have this hit the muffler just below the hot spring. When pressure is applied to the side panel both the hot spring and the rubber spacer work together to keep the side panel safe.
Bike sounds great, as expected! And runs much better! It revs out easier.
Thanks Jeff!!!
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 07-24-2014, 01:16 PM   #94
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
Good question as those that have tried oversized headers have reported (on drriders.com) a loss of low end power, but of course better top end? The stock header seemed to produce the best power for lower rev dual-sport riding. I'd suspect the same from a powerbomb header, but i don't know. They might really work best on MX bikes that are revved to the moon.
Of course if you are a street/highway rider who revs high, then that header might be beneficial. I suspect most want low and broad power delivery however from their DRs.
Out the back end, of course, anything is better than that heavy tank of a stock muffler. Having had that in my hand yesterday again all I can say is WOW it's unreal how overweight that thing is!
Alaska
Old 08-17-2014, 05:39 PM   #95
Stevesgonewalkabout
Oddometer: 7
Hey all,
Time for a stupid question.
If the stock GSXR can is lighter and better performance than the stock DR can, and the gsxr has aftermarket cans which are (supposedly) lighter and offer better performance than the stock GSXR can, why do people not put aftermarket gsxr cans on their DR?
I feel like I'm missing something blindingly obvious, but I only thought about it because of the rarity of k1/2 gsxr stock cans, and the ease of getting aftermarket ones from a wrecker.
Stevesgonewalkabout is offline   Reply With Quote
Old 08-17-2014, 05:45 PM   #96
ER70S-2
ER70S-2's Avatar
Oddometer: 6,874
The GSXR silencers never need repacking, they're multi-chambered baffles, no fiberglass or stainless steel wool packing. And they aren't as LOUD as aftermarket.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 08-17-2014, 05:58 PM   #97
Gh0zt36
n00b for life
Gh0zt36's Avatar
Oddometer: 1,184
Id like to get a 2 bros M7 vale when I get a spare 300 hundo . Anyone have one ? how ya like it ?
Don't eat the yellow snow
Gh0zt36 is offline   Reply With Quote
Old 08-17-2014, 07:35 PM   #98
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,414
Just saw this...
I put a Powerbomb on mine to compliment the Q4 I had been running. I took it off after about 30 miles. I didn't like what it did to the bike at all. For me, it took all the bottom-end away and moved it way up top. I went back to the stock header and sold the FMF header to an inmate.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 08-18-2014, 02:53 AM   #99
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,652
Gixxer pipe
Yeah and the fun police can't tell it's not a genuine pipe for the DR by looking at it, cause it's got Suzuki stamped on it, and they are therefore less suspicious.
I have thought about looking for a decent (cheap) secondhand after market GSXR pipe tho, now that my bike is set up to bolt one straight on.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 01-02-2015, 04:03 PM   #100
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,125
Kind of dead in here... Oh well. Someone may look from time to time.
Little info on the Yosh RS-3 on a DR that someone might (or might not) find useful.
[IMG][/IMG]
Mongle is offline   Reply With Quote
Old 01-03-2015, 04:20 PM   #101
1989THEARK
1989THEARK's Avatar
Oddometer: 372
Just my 2 cents
Video's are a horrible judge of sound.
to me it wasnt that bad.
maybe if you tried talking in the video
while you had it idling it could have given a better reference
of the sound
Here's my video for reference.
At no time was i yelling or needing to raise my voice very much
this was all shot with my phone.
regarding sound you could try making the opening smaller.
less flow. less sound. Fresh packing helps. You could also try getting a stock exhuast i know trophy hunter has one.
There is also 3 for free on DRRIDERS.com
Also. what kinda oxygen sensor or air fuel sensor are you using?????
if its a self heated oxygen sensor then your location makes sense.
if its one that uses the exhaust pipe to heat it i can't imagine the oxygen sensor
would warm up very quickly at all or even stay heated.
I've worked on cars for some time and i have found that if the sensor does not get to at least 700 degree's
its not very responsive and there by not very accurate.
If its an Air fuel sensor then it has its own way of working and i apologize for the misunderstanding.
Also you should find out what kinda air fuel sensor it is.
Some are better than others.
For instance in most kits i have found people use an outdated Bosch sensor.
while Bosch has not changed there sensor to a newer more responsive sensor.
if i'm not mistaken you should be able to connect the newer one
to your setup and whatever driver it has should accept it.
JIM JEFFERIES:
The Bible should be one sheet of paper and on that sheet of paper it should say, Try not to be a cunt.
If you do that, everyday you'll be a good person.
1989THEARK screwed with this post 01-03-2015 at 04:29 PM
Old 01-07-2015, 02:21 PM   #102
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,125
of the sound
Good points. The overall sound while loud isn't bad- the popping on decel is amazingly loud- especially around town/buildings
Already has the quiet insert inside. Think it is just over an inch opening in it.
Yeh, that is what I traded for this thing. Stupid is as stupid does. I do like a little louder just for shits and grins.
It is from Innovate Motorsports. And yes it is self heating. I use it on our fuel injected performance boats- records rpm, a/f, throttle position, MAP, and has a few other things I don't typically use. I only used the A/F on the bike.
It takes 20 samples per second... I think that should be responsive enough. I like to see 500-600 degrees. 700 not bad. Over 900 and you have to run a heat sink or it causes sensor damage.
I don't remember off hand who makes the actual sensor. It is a 5 wire wide band. I have actually had good luck with Bosch sensors in other stuff. Hell, they are one of the few companies that actually make their own sensor. Many others farm the job out.
Like your video. Out of curiosity: Why do you have springs on a bolt on muffler?
Old 02-24-2015, 07:16 PM   #103
rockard
rockard's Avatar
Oddometer: 40
muffler
Originally Posted by NordieBoy View Post
Looks like a mega bomb with an end cap added...
It's an White Brothers E-series
When the power of love overcomes the love of power the world will know peace
Jimi Hendrix
rockard is offline   Reply With Quote
Old 05-18-2015, 12:51 PM   #104
SDIZZY
N00b
SDIZZY's Avatar
Oddometer: 337
2 Brothers Racing m7 exhaust mid pipe usable for x40F0x
IF I have a FMF header and a 2 Brothers Racing m7 setup on there now, do I need a new midpipe to use the x40f0x, or am I good to go?
SDIZZY is online now   Reply With Quote
Old 05-18-2015, 03:01 PM   #105
hrspwrfiend
hrspwrfiend's Avatar
Oddometer: 32
midpipe should be good to go, you'll just need a flange welded to it to bolt the gixxer can to.
2012 DR650
Good judgment comes from bad experience ... and most of that comes from bad judgment.
hrspwrfiend is offline   Reply With Quote
Times are GMT -7.   It's 01:48 PM.
