Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 06-12-2013, 08:15 PM   #151
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
about 18mpg.. not very impressive. there is a guy who claims 25mpg with some radical timing and running 18+ AFR on cruise.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 09-02-2013, 04:44 PM   #152
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
UPDATE
Today I finished up wiring wasted spark ignition setup for the aircooled Type4 Vanagon 2.0L. The spark is much healthier than it ever was, as evident with a healthier idle. I am now idling at 40kpa.
It's time to start building that ignition map that will propel the van for the next 100k miles!
Old 09-03-2013, 08:42 PM   #153
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 867
Cool, let us know how it works - curious about your process for developing a map..
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is offline   Reply With Quote
Old 09-04-2013, 06:09 AM   #154
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Trial and error =)
Old 11-29-2013, 04:22 PM   #155
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Man, I love this... Soon I will be switching to touch screen tablet that will dock nicely into the ash-tray...
.... Just for shits and giggles...
Code:
3rd Gear
2100 RPM
65% Manifold Pressure (Load)
27.4  BTDC Ignition Advance
81F - Manifold Intake Temperature
113F - CTS Temperature as registered by thermoresistor located on the TempSensor II location
13.10v - System Voltage
16.2 - AFR
Can't wait to import GPS Speed, head temperature, oil temp 1, oil temp 2 onto the same screen using canBus... coolio
Old 11-29-2013, 05:32 PM   #156
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
I am not sure that the space shuttle is this advanced .
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 11-29-2013, 06:23 PM   #157
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Soon my van will be sporting a custom dash based on the New Lenovo (INTEL) tablet:
Lenovo Miix2 has Bluetooth, microUSB, and GPS, and its based on Intel processor, which means TunerStudioMS will run just fine!
Old 11-29-2013, 08:30 PM   #158
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
I am not surprised .
Old 12-01-2013, 12:06 PM   #159
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
order submitted for the Lenovo.. it will be here in couple of days.
Old 12-04-2013, 04:39 PM   #160
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Tablet is in....
Old 11-30-2014, 09:12 AM   #161
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
The tablet never worked out, and had to be returned. Several issues; long story short; it had very slow storage, intermittent WiFi even after W8.1 upgrade and driver updates, 32bit UEFI and a 64bit CPU (almost a year later, there is a work around for this), and a very inaccurate GPS that would only work on W8.1 via propriatery API.
Engine, Accessories and Brakes Update:
No news is good news. Couple of tweaks to the air filter. Most tweaks were to the tune files. Trying to nail cold-start, and etc. Almost there. Alternator is starting to weaken a bit. I think it's the regulator or wiring between the alternator and the starter. Going to measure resistance as soon as the van is off jacks. Recently I bought a Chevy CS130D alternator to adapt to the engine, but may hold off on that.
The next upgrade will be LEDs all around, including headlights. Currently the van has two halogen bulbs at 100W, and they suck a lot of juice.
Current project, installing disk breaks that were provided with limited instructions by the person assembling the kit:
It's amazing how easy is to change the pads on these calipers.
Old 11-30-2014, 10:05 AM   #162
Mr. Vintage
Family Dude
Oddometer: 867
Looking good. What are the rear discs off of?
Old 02-07-2015, 08:08 PM   #163
a1fa OP
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
The discs are from Audi 100 Quattro I believe.
Quick update, I did a bit of house keeping, and fixing things that didn't work quite right. While I was fiddling with the wiring, I used it as an opportunity to trim some excess, and tidy up a bit.
Two years ago I built a "temperature sensor" with a coupling that sits in factory temperature sensor location. What seemed like a good idea at the time proved to be very unreliable source of temperature reading for a modern fuel injection system in air cooled application. This spot is not very good for AFTER START ENRICHMENT, CRANK PW, or WARMUP ENRICHMENT. The TSII location requires you to also have fully working shroud fan thermostat -- something that has been on my to-do-list for the past 6 months.
Took this back to the drawing board, and came up with, what I think would be a good compromise between COLD START CRANK, ASE and WUE.. The L-Jetronic CRANK PW is controlled via Thermo-Time switch, capped at 68-74F. It's located under the intake plenum. L-Jet in working order has almost near perfect cold-starts, and almost shitty hot-starts (due to heat soak on the TSII).
Here is the spot I choose - #3 CYL TIN SHEET to CASE screw, just 2 degrees NW of the L-Jetronic Thermo-Time switch.
Before
TOP: My failed engineering project
BOTTOM: BOSCH Temperature Sensor (TSII)
After
New temperature sensor for new location.
a1fa screwed with this post 02-07-2015 at 08:13 PM
Thread Tools
Times are GMT -7.   It's 12:36 PM.
