Old 06-12-2013, 10:36 PM   #3631
GSMarc
GSMarc's Avatar
Oddometer: 1,053
Originally Posted by MoxNix View Post
I did notice the TT tank is no longer on their webpage. Holan or Markus tank for me then.
I read that the HPN tank puts too much weight on the under-dimensionned front fork.
To avoid unless if you change the fork.
I'm not a specialist, I just tell what I have read.
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 06-13-2013, 05:06 AM   #3632
Visian
Look out!
Visian's Avatar
Oddometer: 1,667
Well, it's only 3 gallons, or 18-ish pounds of extra fuel, not very much additional weight.
This is not to say that the stock for isn't under-spec'd, though. It does indeed suck. :not
And be sure to add steering head bearings to to the underspec'd problems.
'67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e
Visian is offline   Reply With Quote
Old 06-13-2013, 05:33 AM   #3633
oldfool
Oddometer: 591
hp2
I put the hpn tank on years ago and no problems, all though I also put in the upgraded fork springs and thicker oil with less air gap. Matter of fact I have had almost no problems with this bike at all in 50,000 miles of riding. Richard.
oldfool is online now   Reply With Quote
Old 06-13-2013, 11:00 AM   #3634
Bullsnake
Oddometer: 84
What is the be all - end all for the front end if running the HPN tank? Is anyone running uprated Ohlins or similar on the front, and what about triple clamps and bearings?
I have been riding motocross since I was a wee tyke, and am Currently 40. At 6'1" and 260lbs I am not what you would call "dainty", and am looking to upgrade any weaknesses that the bike may have. It's a lot to take on right away, but as you all know the older a bike gets the less there seems to be available for it, and I would like to get it set up for a long term run in my fleet. I will be riding it regularly, and depending on my love affair with the bike I may whittle it down to one and sell my new GS WC. With three kids and three different companies I unfortunately don't have the time to devote to the kind of travel the GS is built for.
CAN'T WAIT FOR THE BIKE TO SHOW UP!!!
Gotta get away from this thread for awhile - it's gonna drive me crazy!
Can't keep away though...
Bullsnake is offline   Reply With Quote
Old 06-13-2013, 03:33 PM   #3635
OK Lucinda
Oddometer: 315
Bobby from BMW Atlanta has detailed a fork conversion here on ADV.
http://advrider.com/forums/showthread.php?t=655685
My front end followed his work. I sourced the lower clamp and progressive springs through him. He has two HP2's. The one I saw when I was through there used Ohlins inserts though, which he said he loved.
OK Lucinda is offline   Reply With Quote
Old 06-13-2013, 03:42 PM   #3636
OK Lucinda
Oddometer: 315
Another thing you could do if you're worried about weaknesses is upgrade the whole frame. HPN takes your existing frame and beefs it up in known tender spots. The downside is that you can no longer use a Holan or Touratech rack for panniers as the attachment point at the pegs is no longer available.
Old 06-13-2013, 04:06 PM   #3637
Bullsnake
Oddometer: 84
Thanks for the replies OK Lucinda!
I noticed that service on the HPN site - has anyone ever done this? What is the usual turnaround time?
Old 06-13-2013, 07:10 PM   #3638
gkaan
Bikes on the Brain
gkaan's Avatar
Oddometer: 505
Contact Dave at fast bike industries. He is a former ohlins factory mechanic and they have a cartridge kit which fixes the front end for less than the 950se full conversion.
gkaan is offline   Reply With Quote
Old 06-13-2013, 10:36 PM   #3639
GSMarc
GSMarc's Avatar
Oddometer: 1,053
perhaps some ideas here
http://www.touratech-usa.com/Adventu...ler-Adam-Shani
another fork option here
http://www.specialthings.it/bmw/bmw-...p2-enduro.html
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 06-14-2013, 08:04 AM   #3640
OK Lucinda
Oddometer: 315
It seems there are some suspension experts on this thread. I'm not one of them. I had the 950 conversion done up front, Ohlins rear. I didn't do the Ohlins front insert because I was told it couldn't be serviced as needed with an rtw in mind. The initial set-up was a bit harsh but with cautious tweaks improved things somewhat. But it's never been right.
The bike's still somewhat harsh, has a tendency to plow in the super soft a bit still and truthfully I've lost confidence in the changes I'm making to try and adjust things without making something else worse, which is what happened after my last session. Arggh.
So I've been reading around in the web and have yet to find one good, comprehensive step-by-step guide to suspension set-up. The guides I've found sometimes even contradict each other. The one thing I have out here is time to read and work at it.
Does anyone have any suggestions? I'm sure I'll get flamed for having a nice HP2 and not the knowledge to dial it in, but that's how it is. I am trying hard however. Working with someone on-line would be the best solution. How to repay the favor might be difficult, but I'd work at figuring that out too.
The alternative is finding a good tuner in Panama or Colombia to work with who could teach me something about this black art. But I think finding someone close is a long shot, but who knows.
Old 06-14-2013, 07:52 PM   #3641
mike cummins
OUTBACK RIDER
mike cummins's Avatar
Oddometer: 722
suspension
white power on front and they are great so far. Head them set up properly.
cp2 on rear and it does the job over the rutts and bumbs and the occassional air. Im not a fan of the tripple clamp as it doesnt stay tight and i find myself adjusting it after a rough track. I reckon a great improvement is the bringer billet clutch and brake assembles.
mike cummins is online now   Reply With Quote
Old 06-14-2013, 11:30 PM   #3642
HunSolo
Mad Monk
Oddometer: 392
Suspension set up
There was a beauty of an article on suspension set up in the excellent Brit mag "Bike" a couple of months ago. I hung onto it because I thought it was so useful. If you can't find it online, PM me and I'll email it to you after I return home on Monday.
HunSolo is offline   Reply With Quote
Old 06-15-2013, 08:57 PM   #3643
AMG7Col
Oddometer: 1
Hello, new HP2 enduro guy from South America
Hello everyone ive been reading every single post from this thread, all the 243 pages, im from Colombia South America i owned an HP2 enduro and i just love it, this is a country were you can ride a lot, landscapes for motorbiking are just great, here in Colombia there are only 4 HP2, the only extras of mine is the full system carbon fiber Remus, hope you like it,
ps/ looking forward to its paint job
ps2/ how can i post pictures, thank you
Remember, dreams come true
AMG7Col is offline   Reply With Quote
Old 06-15-2013, 10:18 PM   #3644
GSMarc
GSMarc's Avatar
Oddometer: 1,053
ps2/ Option 2, linking an image from another hosting service is the only option.
have a look here.
I hope you will enjoy your HP2E
http://www.advrider.com/forums/showthread.php?t=919
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 06-16-2013, 06:36 PM   #3645
Ristretto
HP2pilot
Ristretto's Avatar
Oddometer: 175
Haven't visited this thread in a while. How a 'bout some shades of blue, from Malibu
Brian
Brian Aghajani Photography
Moto Photo collection
Beautiful Portraits collection
Ristretto is offline   Reply With Quote
Times are GMT -7.   It's 04:31 PM.
