Old 06-12-2013, 01:09 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,577
Cool2 Back2Orange - NooB '02 400 EXC owner le questionies...
...looks like I'll be picking up a spankin' old 2002 KTM 400EXC'er this weekend from an inmate if all goes right. (props to Joel and ConTeacher)
130hours per the PO.
I'm gonna need to go through it stem to stearn.
All in all evidently a decently maintained bike that needs some LUV.
I figure I'll do:
valve check
wheel bearing check
swingarm bearing check
head bearing check
new tars
and a general scrubbin' an' spiffin'
Been reading all the EXC threadness, but still a few things to sort.
I'll have a few questions as well as I go along since there's no owners manual, like:
Recommended sparkplug? Should I use Iridium?
Oil weight?
Who's got a Scott's stabilizer I can buy from ya...
She looks like a real narsty dirtybike...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 06-12-2013, 02:42 PM   #2
bobfab
bobfab's Avatar
Oddometer: 1,499
my good friend just bought the same exact bike im
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 06-12-2013, 03:15 PM   #3
Droptarotter
Oddometer: 1,296
Hey Randy;
Make sure the chain adjuster are not seized. I drill a 1/8 hole in the bottom rear of the swing arm for a water drain.
The chains like to run what looks like really loose on these bikes......best way to adjust the chain for the first time is to remove the shock (it's easy) and raise the swing arm in line with the countershaft/swing arm pivot to get the proper tension.
There is a oil filter screen under the engine that needs to be torqued properly.......most guys do them too tight and bugger them up the next time they try to take them out.
If yours is buggered get a new screen with a bolt head.
Run 20/50 oil........I like Chevron Delo 400.......
Have fun!!
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 06-12-2013, 03:39 PM   #4
Baja Dad
Baja Dad's Avatar
Oddometer: 2,033
here is my 01 400 rebuild
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 06-13-2013, 08:15 AM   #5
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
..hooyah! Frame off resto...nice.
I promised myself I'm not going overboard on this one.
Gonna be a get dirty trailbike I can drop and not fret about.
Low budget but well maintained.
I do need a Scott's stabilizer'n some stuff though...
Old 06-15-2013, 05:50 AM   #6
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
...soon come...
Old 06-17-2013, 07:01 AM   #7
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
....got 'er done...
Old 06-17-2013, 07:04 AM   #8
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
it starts
first a scrub down, she's a dirty bitch but runs fairly well.
Needs huge TLC...
The PO move the ECU to under the seat. Some sort of mod I don't understand. I mounted back where it belongs on the steering head.
Questions to come...
Old 06-17-2013, 07:10 AM   #9
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
...there, that's better. Cleaned up pretty good.
Managed to get the valves set.
Intakes were tight
Exhausts were loose...
Turnsinals and brake light don't work
Turnsignal switch has been buggered.
It's got the TrickDualSport Light kit. Not sure how that's wired, much to sort there.
First question, is the adjuster knob on the carb (bot left) fuel mixture or idle?
Old 06-17-2013, 07:13 AM   #10
MotoChris521
Oddometer: 705
Idle speed
dreaming of moist soil
MotoChris521 is offline   Reply With Quote
Old 06-17-2013, 09:13 AM   #11
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
Thanks Chris.
Here's another:
Bike runs good but when running and you let it die, there's a top-end rattle ...noise during the last couple rpm's.
Sounds like a cam chain noise.
Not sure this is normal or a sign of something 'else'.
I have set the valves already but not run it yet.
Intakes were tight, exhausts where loose.
Over at KTM Talk someone suggested...
You are probably hearing the auto-decompression kick in.
This bike has the decompression cable disconnected..for what I do not know...
Old 06-17-2013, 10:42 AM   #12
bobfab
bobfab's Avatar
Oddometer: 1,499
My buddies is the exact same way. Decomp cable disconnected and a slight rattle at low "Shutoff" RPM's. Im all ears here!
CRF250L | KTM200SX
Old 06-17-2013, 11:56 AM   #13
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
me2
Old 06-17-2013, 12:25 PM   #14
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,360
The decomp is auto, makes no difference if the cable is connected or not. The noise is normal. About the decomp on pre 03 bikes though, is the stop on the cam gear. It's a bolt with a nylock nut on it. In 03 they changed it to a riveted pin. If the nylock nut comes loose and the parts fall out, it's not pretty. Very rare to happen but it has. The fix is a new cam gear which isn't terribly expensive, under $60 IIRC. You'll need a new cam in 200 hours or so as the water pump seal will groove the end of the shaft. I would just wait and do it all later.
If you follow the 400 discussions anywhere, you'll surely come across the mention of the 453. The 453 is the best RFS motor KTM never made. Basically it's the 400 crank (short stroke) with a 525 cylinder (and a special piston from Thumper Racing) and it bumps the displacement to 453cc. You toss the anemic 400 cam and use the 5521 cam (stock cam on 450 and 525 EXCs) and that gives you a great all around motor for low bucks. It's still docile on the bottom but it comes alive on top and revs out good due to the short stroke and the better cam.
At 300 hours you're going to start running out of adjuster as the intake valves get tighter and start knife-edging. Send your head to Dave Hopkins and have him do his stuff. Stainless steel Kibblewhite valves at the very least. If you are going to bump up the displacement, get the intake valves oversize by 1mm and unshrouded. You're then only an 806 (or my fav an 833) cam away from serious fun.
I love these motors. My favorite is the 540 but that's a long stroke crank so not quite the snap and smoothness of the short stroke crank. Ride it stock and enjoy it for now, it's an awesome bike.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK screwed with this post 06-18-2013 at 05:07 AM
GR0NK is offline   Reply With Quote
Old 06-17-2013, 01:15 PM   #15
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,577
yaeh baby! Now that's some relative info!
Thanks for that.
Who is he. How does one contact him, eh?
Times are GMT -7.   It's 12:10 PM.
