Old 06-12-2013, 09:58 PM   #1
b4thenite OP
b4thenite's Avatar
Oddometer: 214
dr 650 battery issue
Sir,
Please help me with following issue;
I started my DR for the first time in 3 month. It started, but soon as I push back the quick throttle knob, it coughs and dies.
Went through this couple of times, and the battery finally quits.
I got a brand new battery but due to lack of time, I had to pick up the battery when it was only 85% charged. Dude at the counter said go ahead and ride it for couple of miles and it should be ok.
I replaced the battery and it starts right away, but does the same thing. So kept the quick throttle knob out and rode it around 2k RPM for few miles.
I thought maybe I should do the valve check, so I begin to do the valve check.
After the adjustment, I put it all together and starts, and it does the same thing. Quick throttle knob out, it runs around 2k rpm, but soon as I push the knob back, it drops to under 1k and coughs a bit and dies.
At this moment I check the plugs, and see one of the plug hole is very messy. It's oily around the plug. It seems there were some leaks around spark plug holes.
So I changed the plug and go through it one more time. I ran it with quick throttle knob out and check the plug. It look like it was never fired. Mind you this was the brand new plug, but it seems it never fired.
At this time, the brand new battery quits too.
I jumped bike with the car and it starts right away. I check the plug again, and this time, it seemed it fired. So I thought, O.k.
But the throttle knob issue is still there. The Knob out, runs. But the knob back in, it drops under 1k and dies.
Is it the battery? or the rectifier? or something else?
Anyone with any idea, please help this poor soul.
Thank you for reading.
b4thenite is offline   Reply With Quote
Old 06-12-2013, 10:16 PM   #2
qkenf4u
Oddometer: 201
carb clean time.. need to clean the PILOT JET .. its plugged thats why you have to have choke on for it to run.
put battery on a charger at 2amp for 8hrs (put it on while you sleep) and it should be ok
qkenf4u is offline   Reply With Quote
Old 06-13-2013, 07:06 AM   #3
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,687
Carb issue.
Danjal is offline   Reply With Quote
Old 06-13-2013, 07:29 AM   #4
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,649
Sorry but this is an owner issue
You can't expect a neglected motor to perform without prayers
plugeye is offline   Reply With Quote
Old 06-13-2013, 11:56 AM   #5
dankatz
Oddometer: 326
Agreed! If you can't maintain idle it is likely a clogged jet. You can try pouring half a can of seafoam into a relatively full gas tank, running it for a quick ride and then letting it sit for 24hrs. But, manually cleaning the carb will be the ultimate fix.
dankatz is offline   Reply With Quote
Old 06-13-2013, 12:37 PM   #6
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 905
Dirty carb
try draining the fuel tank and carb bowl
put 4 oz seafoam mixed with quart of fuel in tank
let sit over night
try to run
if that dont work take carb apart and clean
I have had good luck with sea foam in small engines that have sat for a long time....my bikes get ridden
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 06-13-2013, 12:55 PM   #7
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,261
bad gas in the carb. i would start here before delving into electrics.
maybe a heavy dose a sea foam will work, but you might pull the carb and do a pine sol soak.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 06-13-2013 at 01:02 PM
eakins is online now   Reply With Quote
Old 06-13-2013, 01:01 PM   #8
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,261
Originally Posted by bobzilla View Post
Dirty carb
let sit over night
try to run
in addition to seafoam on the tank, top off with gas plus do this:
drain the float bowl (bottom screw).
pull the fuel hose of the inlet to the carb.
take out the small filter in the inlet pipe (it's plastic and fits inside the metal pipe)
put a piece of extra hose on the inlet leading to a small funnel.
pour seafoam into there until it's full.
put the filter back in
put the regular fuel line back on
let the bike sit over night. this will soak the jets hard w/ seafoam.
then connect bike via jumper cables to a car battery for extra starting and get the bike running.
this may work w/o pulling the carb and cleaning it.
Alaska
eakins screwed with this post 06-16-2013 at 02:34 PM
Old 06-16-2013, 11:20 AM   #9
rwf
rwf's Avatar
Oddometer: 120
This
"I was going faster than I ever went in my whole life, then I fell off." Little Fauss
rwf is offline   Reply With Quote
Old 06-16-2013, 08:29 PM   #10
b4thenite OP
b4thenite's Avatar
Oddometer: 214
Thank you for all your help.
I'd like to report back what I did, and what happened thereafter.
I took out the TM40 and cleaned it.
I took out the needle and cleaned it.
I took out a small screw under the needle and cleaned it.
I bought a bottle of seaform and used the entire bottle.
In the morning, bike started right away with the chock on, and it stayed on idle chock off. But it wasn't smooth.
So I decided to take a spin, and after about 4 miles, it died on me.
The battery was totally gone. Mind you this was a brand new battery.
A good Samarian helped me and I was able to start the bike right away with his jump.
After the start, I ran about 100 miles. I turned the bike off, and crossed my finger, and it started right away.
I haven't had any issue since.
So, conclusion.
I think I had low battery and also the carb issue.
Again, thank you for all you help. I could not have done it without your wonderful help.
Times are GMT -7.   It's 10:58 PM.
