Farkles for the GS-W: Put 'em all in here
Discussion in 'GS Boxers' started by Emoto, May 29, 2013.
  1. At adventure
    At adventure AB
    Feb 4, 2013
    143
    Sydney, Australia
    #81
  2. Voz
    Voz Been here awhile
    Feb 13, 2012
    597
    Sydney, Australia
    Lack of riser is my biggest problem on the bike right now, can these be preordered?
    #82
  3. kindofblue
    kindofblue Ride it like you stole it
    Mar 19, 2007
    822
    Albuquerque NM
    Don't know. Consider emailing them. They're a small company and responsive to customers.
    #83
  4. kindofblue
    Mar 19, 2007
    822
    Albuquerque NM
    I've got 3k+ mi. on my GS w/the Wolfman bag on. The front straps wrap around the upper tubes of the frame. I've got them short enough that all the paint is protected by the bag's flaps in the front.
    On the rear, I took the surplus tail of the strap, wrapped it over itself and then took some double sided velcro tape and secured them w/the soft side out. I was concerned whether they'd rub the paint too but so far they're doing just fine.
    #84
  5. iride4u
    iride4u Been here awhile
    May 28, 2013
    350
    Loveland, Colorado
    BMW headlight Shield and BMW LED light bar. It looks worse then it is much of this is to hide wiring. As I have said many times before if you are doing any electronic work with a Can Bus bike you should use a PDM60 or another brand of fuse block. Here is a shot of the Skene P3s on the rear of the bike.
    This is the Twisted Throttle gear shift, I had to do some machining to make this fit. Twisted Throttle is aware of the fitment problems and will be making changes.
    BMW Adjustable Foot Pegs, these are much nicer then the stock set you do have to order a different set of springs. Also the rubber center section is on springs and collapses below the teeth when you stand on the pegs.
    The current mounting of my Clearwater Darlas, This will change when the mounts are available. They are great in the daytime making you more visible to oncoming drivers. I am still working out the wiring with the LED high beams.
    #85
  6. Emoto
    Emoto Sure, why not?
    Feb 24, 2004
    21,446
    SE Mass
    #86
  7. At adventure
    At adventure AB
    Feb 4, 2013
    143
    Sydney, Australia
    Voz you can get them from here is Oz -
    https://www.motorradgarage.com.au
    #87
  8. Stinez
    Stinez Rhymes with Heinz :D
    Aug 7, 2003
    49,742
    Nor Cal
    kindofblue - Thanks for the reply and the answers.
    FWIW I've always used clear background material to protect my painted parts.
    BUT I do think a well designed part shouldn't need them.
    Can you post a pic from the back so that I can see the pipe side fitment?
    I've ordered the vario's but if they're not in when I get the bike I may just move on to something else.
    Same goes for the crash bars.
    Same goes for the tank-bag.
    My dealer is a little disappointed as well because accessories is a big part of their business so without them only 2 of the 3 spokes (Sales and maintenance) are paying the bills.
    #88
  9. Emoto
    Feb 24, 2004
    21,446
    SE Mass
    Stinez, does this show you what you were looking for?
    #89
  10. Stinez
    Aug 7, 2003
    49,742
    Nor Cal
    Perfectly. :thumb
    PS Those bags make your butt look big. :evil
    #90
  11. Emoto
    Feb 24, 2004
    21,446
    SE Mass
    Good! You know what they say: Big butt, big...
    .... i got nothin'. :dunno
    #91
  12. Desert Skies
    Desert Skies One brick shy...
    Mar 2, 2004
    2,614
    Tejas
    fixd :thumb
    #92
  13. iride4u
    May 28, 2013
    350
    Loveland, Colorado
    Just added a Touratech large kickstand foot. I had to provide my own screws since the ones that were supplied were too short.
    #93
  14. GSAnderson
    GSAnderson Wandering Swede
    Nov 30, 2001
    2,824
    Miles away
    No issues with paint wear yet.
    Here's the front mounting point looking up under the fender:
    Back mount:
    #94
  15. kindofblue
    Mar 19, 2007
    822
    Albuquerque NM
    You're welcome. I agree. I usually do the same but what I'd applied on the tank for the aft straps didn't seem to want to stay put. I took the stuff off and haven't seen any damage to the paint or plastic yet.
    #95
  16. kindofblue
    Mar 19, 2007
    822
    Albuquerque NM
    That looks to be a more elegant solution that what I've done. I think I'll go with yours. Thanks!
    #96
  17. kindofblue
    Mar 19, 2007
    822
    Albuquerque NM
    At last. I received the Russell saddles today. Fit is perfect for me. I had them make the seat covers out of automotive fabric rather than vinyl or leather both of which I don't like because of the summer heat.
    #97
  18. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,241
    Big Sky Country
    BMW crash bars installed the day after delivery of R1200GSW; low BMW seat added this month as available from dealer.
    #98
  19. kindofblue
    Mar 19, 2007
    822
    Albuquerque NM
    Has anyone done DIY radiator guards? $140 for a set just seems a bit much.
    #99
  20. NLS
    NLS My bike needs washing...
    Jan 9, 2004
    3,204
    GREECE!
    Yes at least one has made and they look great.
    Cannot find the post.
    It is either in this thread or in that one:
    http://advrider.com/forums/showthread.php?t=657113
    (good luck with that, do a search)
