Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 06-14-2013, 07:53 AM   #1141
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,263
Originally Posted by advtenn View Post
Just so you know...It's labor intensive.
I found a really good youtube video showing how to remove the plastics, tank and filter.
It's not to bad if you take your time, just be aware of the plastic supply fitting on the bottom of the tank. I have touratech upper engine guards and I had to watch out for the clutch cable. It was getting stuck between the bottom of the tank and support bar above the radiator. I used a short piece of 2x4 to prop tank up to remove electrical and gas connections.
I used silicone spray for the stepper motor after taking air box off. Will see how it lasts. I also noticed the top of the stepper boot wasn't fitted into the groove cut into the top part of the stepper shaft
I have the snorkel and adapter off while I wait for the UniFilter, (any day now, I ordered it ten days ago) think it's an issue if I ride this weekend without either?.
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 06-14-2013, 08:15 AM   #1142
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 387
Eh?
Originally Posted by vanjoosten View Post
Wild@Heart makes a very nice adjustable one.
Very nice, but cost with shipping is $139.84.
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is online now   Reply With Quote
Old 06-14-2013, 08:28 AM   #1143
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,263
Speaking of spring, has anyone had issues with the side stand spring falling off when trail riding? I now carry two...
Lord John Whorfin
Old 06-14-2013, 09:44 AM   #1144
orv
Busted butt
Oddometer: 443
Got any breadcrumbs to find this video? TIA
orv is offline   Reply With Quote
Old 06-14-2013, 10:24 AM   #1145
PYG RYDR
PYG RYDR's Avatar
Oddometer: 387
Thumb
Here you go: http://www.youtube.com/watch?v=aBsuUqPoF2M
http://www.youtube.com/watch?v=Ws3jVIIpElM
And Muddy Sumps How To Videos: http://www.youtube.com/user/MuddySump/videos
BTW-edited with additional info.
PYG RYDR
MSTA-NVR
PYG RYDR screwed with this post 06-14-2013 at 10:31 AM
Old 06-14-2013, 10:28 AM   #1146
T
T's Avatar
Oddometer: 5,410
This vid will get the plastics/tank off. Once you get tank off PR's vid will finish you up.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 06-14-2013, 11:25 AM   #1147
advtenn
advtenn's Avatar
Oddometer: 1,364
I dont think it would be an issue at all, to ride with the snorkel removed. Just make sure you dont have anything under the seat (like a rag) that could be sucked into the air box.
I also lubed the stepper motor area while i was in there. BTW compressed air and WD-40 worked really well a few thousand miles ago. Saves the trouble of removing the tank and air box.
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 06-18-2013, 05:58 AM   #1148
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,596
Need some Rox Riser help... I have put off ordering a set and now I'm finally ready and there are so many different models, I'm not sure which to get!
Tiger 800XC uses the 1-1/8" by 1-1/8" and 2" and will fit without modifying stock cables? Does the vibration dampening model make a difference worth the extra money? Tried searching this thread and still searching...
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is online now   Reply With Quote
Old 06-18-2013, 06:07 AM   #1149
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
My standard ROX risers work fine with no issues with cables and vibrations.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 06-18-2013, 06:13 AM   #1150
rustynut2
Oddometer: 492
I tried the 2inch rox's for about a week. Vibration was not the problem, it was the cramps in my wrist. The stock bars are not swept back enough for me. The cure was the explorer bars with the 20mm riser. Drill 2 holes and good to go. I'll make you a deal on some almost new risers if you want them
Work harder, millions on welfare depend on you.
12 T800XC, 14 DRZ 400s
rustynut2 is offline   Reply With Quote
Old 06-18-2013, 06:24 AM   #1151
backwoodsKLR
Oddometer: 9,596
Just ordered a set of non-vibration ones... Had a $25 Amazon gift card I needed to use and got my Prime 2 day shipping for free! Ended up getting them for $58 after all of this!
ROX HANDLEBAR PIVOTING RISER 2"X1-1/8"X1-1/8" 1R-P2PP
2013 Tiger 800XC
Old 06-18-2013, 06:32 AM   #1152
rustynut2
Oddometer: 492
good luck with them. I ordered my explorer bars through Bike Bandit in case you need to know later.
ps, would have beat that price
Old 06-18-2013, 06:55 AM   #1153
backwoodsKLR
Oddometer: 9,596
And paid for 2 day shipping across the continent?
2013 Tiger 800XC
Old 06-18-2013, 10:01 AM   #1154
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 903
Little farkleing of the farkle... bar end action on a set of Tusk guards to clean it up a little. You have to get out the Dremel to mount these too, need to open up the bar clamps.
2013 Triumph Tiger 800 XC
2013 Husky TE 449
XCRider803 is offline   Reply With Quote
Old 06-20-2013, 12:47 PM   #1155
advtenn
advtenn's Avatar
Oddometer: 1,364
Upgraded Tool kit
I've been talking to my ride buddy BackwoodsKLR and we have been sharing tool kit ideas.
I'm getting ready for the "San Juan 500" dual sport ride in Colorado and have added to the list of tools that I carry under the seat of the Tiger. It's probably more than I need, but I seem to never have enough.
Since I have the room, I carry a 17" and a 21" spare tube.
I only carry the sprocket and breaker bar when I need to change sprockets after long super slab runs.
I still need to add a multi-meter and JB weld...I still have room for that.
Forgot to remove the knife for the group photo....
so here is where I keep it.
Times are GMT -7.   It's 12:50 PM.
