Old 06-17-2013, 05:23 AM   #286
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Originally Posted by MAXVERT View Post
How do these work ( fit ) on a KTM 690.
Which mounting brackets for the fairing are recommended ?
I'll be using two 60's.
I see you can get them without the mounting holes drilled.
I'm sure with some fabrication these will fit on the 690.
Max
The fairing will mount on a 690 using the fender pins for the lower and fork brackets with straps (ernge) for the upper mount.
Very similar mounting to my SE
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 06-17-2013, 03:04 PM   #287
0theories
Oddometer: 299
In!
Going to order this to fit on a gen 1 KLR going through a little build-up Pretty excited!
Edit: Quick question: I'm going to order two fork bracket kits. Can I return one if I end up not using it? Thanks.
Enthusiastically skeptical...
KLR650, WR250x
Oregon to Panama RR (Guatemala actually...)
KLR Build Thread
0theories screwed with this post 06-17-2013 at 03:10 PM
0theories is online now   Reply With Quote
Old 06-17-2013, 08:51 PM   #288
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 466
Talking
Received fairing kit today with two 60's and dimmer. Plug and play is right. Great product, great service. Installed in just 20 minutes. Wind is smooth and felt good to me. Need more testing but stoked right now. Will take some time to adjust low beam to right height but pretty close out of the box.
Graniteone screwed with this post 06-17-2013 at 08:57 PM
Graniteone is offline   Reply With Quote
Old 06-18-2013, 06:53 AM   #289
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Yes you can return the fork bracket if you end up not needing it.
If you haven't decided on a front fender, the KTM ones are quite reasobbly priced (~$25). That way you can use the stock ktm pins on the fender for the lower mount. This will limit the adjustment of height.
Old 06-18-2013, 06:55 AM   #290
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Originally Posted by Graniteone View Post
Thanks for your business!
Awesome looking bike
Old 07-10-2013, 01:31 PM   #291
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 929
so I looked on adv monster and dont see the fairing. where do you order?
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 07-12-2013, 09:21 PM   #292
Bobby Ginger
Cat Herder
Bobby Ginger's Avatar
Oddometer: 1,050
Put my old fairing on my new six fiddy
2009 GSA 2008 Husky TE450 2006 KTM 950 SM
IBA 50407
Bobby Ginger is offline   Reply With Quote
Old 07-23-2013, 07:23 AM   #293
refokus
Just Learning
refokus's Avatar
Oddometer: 2,552
Nice, I would like this for the DR........
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 07-23-2013, 01:18 PM   #294
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,901
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 07-23-2013, 01:20 PM   #295
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,901
Old 07-23-2013, 02:01 PM   #296
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 546
wondering the same.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 07-25-2013, 08:51 AM   #297
azgsa
Apathetic
azgsa's Avatar
Oddometer: 1,380
Originally Posted by dirtyoffroad View Post
wondering the same.
http://www.globetrottin.com/Fairing-...ghts_p_22.html
Arizona Adventure Riding Group
azgsa is offline   Reply With Quote
Old 07-25-2013, 10:37 AM   #298
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
wondering the same.
Website updated.
Old 07-26-2013, 08:25 PM   #299
0theories
Oddometer: 299
Installed! (on 1st gen klr)
Got this baby mounted as part of a build. Took her for a ride in her native habitat. Rode some pavement too, to check out high speed. At 75 mph, nice clean, smooth air, much less turbulence than what I had. Super bright light (untested on road as of now). Total win-win.
KLR650, WR250x
KLR Build Thread
Old 07-27-2013, 05:03 AM   #300
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
That is a great looking KLR!
Times are GMT -7.   It's 08:17 PM.
