Old 05-31-2013, 08:05 PM   #1
Toddwmac OP
ADV addict
Toddwmac's Avatar
Oddometer: 283
Front Sprocket eating my chain guide?
Hey guys-
I cracked open my front sprocket to swap my 16T for a 17T and I saw the chain guide chewed up. Is this normal? There does not seem to be any other issues that I can find.
Is this normal?
08 ADV, 16tx45t
The old girl does get a bit or a work out.
KTM 08 990 ADV
HD Duece
WR 250R
Lost but don't care!
Toddwmac is offline   Reply With Quote
Old 06-02-2013, 12:23 AM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,987
Shit happens. You may have got a rock in there. The 16 th sprocket normally doesn't touch it. The 17 th will over lap, but there's a slight cutout to miss it.
Don't ride it like that, it will lock up the rear wheel when it lets go.
"Son, you can't do both"
Old 06-02-2013, 12:13 PM   #3
charlie264
charlie264's Avatar
Oddometer: 8,273
Normal. made that way....just looks like a lump of shite stuck on there.
Old 06-04-2013, 12:24 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,927
Yes it is normal.
However, you should make sure the bolts that hold this plastic piece on the swingarm, are properly bolt. These bolts have been reported to get loose and create the problem Zuber is referring to. There is a nice fix, installing a bolt from the top to the bottom, M6x100 of the swingarm, as these two bolts are aligned.
http://advrider.com/forums/showthrea...=551666&page=4
Cheers.
gefr screwed with this post 06-19-2013 at 11:14 PM
Old 06-19-2013, 10:52 AM   #5
Toddwmac OP
ADV addict
Toddwmac's Avatar
Oddometer: 283
Thanks guys! just back and will look into securing or replacing.
T
KTM 08 990 ADV
HD Duece
WR 250R
Old 06-19-2013, 11:27 AM   #6
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,150
Well actually...
I just replaced the chain slider on a 950.
It had completely worn though and came off in two pieces.
As stated before, it would have been BAD if it had come off and gotten in the rear sprocket while riding.
Something to check guys.
Q~
Times are GMT -7.   It's 09:41 PM.
